By 55 GLASS TOP - 8 Years Ago
Hello, can someone help me with the proper color of the sheet metal under the hood of my 1956 Club Sedan, I have decided to detail the engine compartment and I want to repaint all the black sheet metal stuff ,the air horns the mud guards the radiator support you know all the black stuff. I was going to use satin Chassis Saver brand paint but I was told it would cloud up after some time . Just wanted to know if anyone knows what paint and color it was originally .
By 62bigwindow - 8 Years Ago
All the ones I've seen are body color. I'm sure someone with more knowledge can let you know for sure.
By Lou - 8 Years Ago
If you are talking about the inner fender panels, etc i used "Chassis Black"
Is that a gloss or semigloss or a flat do you have a brand or paint number . I have seen many cars some with gloss some with out I am looking to put whatever was there when new. Thanks for the reply
I used it on my 56 Glass Top , I bought at the Ford Nationals from Eastwood, I believe it was a semigloss.
I was told the stuff does not hold up well to ozone exposure I guess the limited time the hood is up is ok with the paint
Ozone is a molecule in the air. Having a hood open or closed will have no affect on exposure.
UV light, on the other hand, does affect materials that are not designed for it and the underside of a closed hood would be out of direct exposure. That's one possibility.
By paul2748 - 8 Years Ago
I use either Krylon Satin Black or Rustoleum semi gloss. I did my 64 with the Krylon and it came out super - a real nice finish. As for proper color, I know the TBirds were painted body color for all the underhood sheet metal while the add on parts (power brake, heater parts) were satin/semigloss black.
I don't know about the sedans, but they were painted in the same shop as the TBirds.
I misunderstood your question. The firewall is body color and the rest is semi gloss black. I used Rustoleum semi gloss black on my inner fenders,core support and latch panel.
Yes I meant uv exposure my mistake about the ozone. I want to make sure I use the right color and it won't be bothered by gasoline
I've always used just a rattle can semi-gloss. Different brands but they all seem to cloud over after time, my three cars are all daily drivers so it maybe from the constant under hood heat. As an experiment the last ones I painted on my 57 I used an epoxy made for BBQs, After three years it still looks good and hasn't clouded. And paints they make today aren't like the old enamels of days gone by..
By Rono - 8 Years Ago
On my 56 Customline, the inner fenders, upper radiator shroud/valance and lower front stone guard were all powder coated gloss black. The coating is very tuff and won't chip or scratch very easily so rust can't take hold. Not affected by UV or water and cleans easily.
Rono
I'd be surprised if you can find a coating that isn't bothered by gasoline. The best course of action there is to clean off any gasoline asap.
Some powder coat is more UV resistant than others but none are totally resistant. Ask your powder coater about the options and properties of the product he uses.
I have had my powder coating on the engine bay parts for about 8-9 years now with no fading that I can see. I didn't know that some were more UV resistant than others. I would guess that the home powder coating kits you can buy do not give you the same quality result as that of an industrial application and that the industrial powder coat applications would most likely be more resistant to damage than any paint you could buy.
Rono
