thundercat
Visits: 5.2K
I finally finished my project.. Ive been sneaking out nightly to test & tune . Got my state inspection sticker last Thursday and drove 250 miles to & from Car Show in Northern Pa on Sunday. It still needs to learn fine tune but not bad. Runs pretty good.. Its the same 312 .060 that has about 1000 miles on the short block. It was built with the blower in mind about 3 years ago with dished Racetec pistons . I installed Mummert heads with the chambers opened up a little by John M. I used his short cover and shortened the damper about an inch. Shortened the alt. bracket also. The crank sticks thru the damper & the aluminum blower drive adapter I made so I had to bore it out and use longer crank bolt.. I used MSD EFI as all my other parts are MSD [ dist, coil, wires, boxes] you can control timing and retard timing as boost increases . This was my first attempt at EFI....It was worth the effort & cost to me.. A side note : I had to settle for "HUFD 312" License Plate as Pennsylvan  ia will not let you use "BLWN 312" No Way !!... Steve McD THUNDERCAT
Mars , Pennsylvania
thundercat
Visits: 5.2K
Mars , Pennsylvania
thundercat
Visits: 5.2K
Lindsay Shoemaker "Y-Bloke" Intake from Australia They are made well. Only thing I altered was to drill two pipe thread ports near the top where thermostat goes for senders.....Steve McD
Mars , Pennsylvania
Talkwrench
Visits: 23.2K
speedpro56
Posts: 1.3K,
Visits: 9.2K
As beautiful as it gets!
-Gary Burnette-
62bigwindow
Visits: 14.3K
Looks great! Had a chance to stretch it's legs yet?
Durham Missouri
Last Active: 4 hours ago
Visits: 38.4K
I've posted twice about linkage but it seems to disappear. Do you have close up pictures of your throttle linkage? Did you use a bell crank or cables? I'm going to work on my blower motor this winter as far as rigging up linkage etc. And could use some ideas. Chuck
thundercat
Visits: 5.2K
Thanks for nice comments and THANKS TO ALL for help from this site both directly and from past information "Searches"... I have about 350 miles now has quite a bit more power and throttle response... Throttle linkage I reused the cables from before to see how they would work , just made new brackets...May try a mechanical throttle this winter as throttle doesn't return exactly same each time[ a very small amount] probably from "S" turn in cable...I will post if it works better..  Steve McD
Mars , Pennsylvania
Lord Gaga
Visits: 183.3K
BEAUTIFUL!!
"FREE SAMPLE"
Visits: 38.4K
Thanks, that's the picture I needed to see. Are you running an AOD? I have the same style cable on mine. Lokar suggested I just get longer cables and move the linkage up like you have. I would think that would work but will watch the cable turns. The manual bell crank seems doable but the AOD kickdown may still need a cable. I would like to have a solution before I put the engine in the car. Chuck
