I went with the FE fuel pump and small Holley 4 barrel ( I think it was the 390). It runs great around town and on the highway, with no vapor lock. Drove it that way in the dry heat of Utah and humidity of SC.
It had an electric pump and the original dual mechanical when I got the car. The electric was right under the drivers door in the fuel line. It kept stalling while out on the drive. Apparently, the electric has to be right at the gas tank, best description is that they push better than pull. Someone told me they actually pull too good and create a void due to the line not keeping up with demand of the pump.
Also went with the Newport Engineering electric wiper motor, since the vacuum motor was just insufficient.
