Flaminroosta
Visits: 58
Thanks Ted. The carburetor is definitely the teapot/firebox. I'll order the kit for the Holly 4000 4V.
"What a waste of thumbs opposable, to build machines disposable." - A.D.
Posts: 7.5K,
Visits: 205.8K
Flaminroosta
Visits: 58
The carburetor that came with the car is marked ECZ 9510 - H. The "H" stands for Holly to my knowledge. When I look up the casting number ECZ 9510 for a rebuild kit, it brings me to the Holly 4000, and all components don't look like they will match up with the carburetor I have. Does anyone know what carburetor came stock with the 312? I don't want to order the wrong rebuild kit.
Yall have a good Sunday.
Zach
Posts: 3.3K,
Visits: 238.8K
One of the things to keep in mind about 312s is the torque spec's for the Main Caps. If you take them apart for any reason. do not over tighten the main cap bolts!!. Unfortunately, some early 1956 manuals printed spec's that were far too high, this could resultl in stripped bolts or worse, a cracked block! The 1957 manual states max 105lbs. To be safe, the Street Rodder series years ago,recommended max 90 lbs.
Larry D
Visits: 1.4K
That's a 312.
Larry D
Winnipeg, MB Canada Eh!
'58 Custom 300 Tudor
'56 Crown Victoria
'61 Starliner Z Code
'51 Ford Victoria
Flaminroosta
Visits: 58
 The Main Caps read ECZ-6329-4
Oldmics
Visits: 78.1K
Sometimes when they set that long the valves stick . Easy enough since you already have the top end opened up to pull the valve covers and make sure that the valves will move.
Avoid bending some pushrods if the valves are sticking.
Welcome to Y Block world. Oldmics
Dobie
Visits: 22.0K
Flaminroosta (11/20/2015)
All the Casting marks I have found are labeled ECZ-B. Heads and manifolds are interchangeable between 292 and 312 and will all have the same casting number depending on the year. The B intakes are about the best Ford made.
Flaminroosta
Visits: 58
Flaminroosta
Visits: 58
Thanks Lou. I don't want to miss certain details like that. As of now I have the intake manifold and carb off. Do yall think it's necessary to pull the heads off for a more detailed cleaning or should I just flush it and hope for the best?
