Stock cam lift
Posted By DryLakesRacer 10 Years Ago
Posted 10 Years Ago
I did a search but did not find the stock lobe lift for any of the stock camshafts. Does anyone have them for the different years and engine sizes? Thanks
Posted 10 Years Ago
By the book, the 1957 272, 292, and 312 4V V8 camshafts had 0.272” lobe lift on the intakes and 0.285” on the exhaust.
Posted 10 Years Ago
Posts: 287, Visits: 1.7K
there are only 2 stock cams 57 and all the rest.57 is272 int,285 ex.which according to ford gives 400 int and 420 ex with 1.54 rockers.the other cam gives 360 with 1.43 rockers and 384 with 1.54.i dont have the lift for this cam itself.
Posted 10 Years Ago
From the 1955 Service Manual, the 272 & 292 V8 camshafts had 0.264” lobe lift on the intakes and 0.262” on the exhaust.
chiggerfarmer
Posted 10 Years Ago
Supercharged (177 reputation)Supercharged (177 reputation)Supercharged (177 reputation)Supercharged (177 reputation)Supercharged (177 reputation)Supercharged (177 reputation)Supercharged (177 reputation)Supercharged (177 reputation)Supercharged (177 reputation)
Posts: 85, Visits: 3.8K
Ted, is there anywhere here in Waco that can grind a cam to that stock 57 spec?
Tom from the chiggerfarm located in the beautiful Heart of Central Texas
When you cannot dazzle others with your brilliance, baffle them with bullcorn! BigGrin
Posted 10 Years Ago
Thanks that's what needed. JD
Posted 10 Years Ago
chiggerfarmer (1/4/2015)
Tom.  I’m not aware of any cam grinding equipment remaining in the Waco area.  I have toyed with the idea of having Isky make a reproduction ’57 grind though as the E4 ground on 112° lobe centers is still just a tad big on some applications.  The E4 on 112° lobe centers is still worth 10-15 HP over the factory ’57 grind so it’s tough to go backwards sometimes.
Posted 10 Years Ago
What about the bigger E and F code cam?  Or was that over the counter and not factory?
Oh, in the Eichman book, .290 and .290 lobe lift.
Y block Billy
Posted 10 Years Ago
Posts: 1.6K, Visits: 5.2K
If this works from my phone i will post a cam spec paper published by Mummert some time ago!
55 Vicky & customline
Y block Billy
Posted 10 Years Ago
It worked but you will have to turn your laptop/monitor on its side to read it. Damn phones!
