55 Ford Fairlane Refresh and Driver Resto Blog Begins!
Posted By Daniel Jessup 12 Years Ago
Daniel Jessup
Posted 10 Years Ago
Posts: 2.0K, Visits: 131.2K
I got into the garage early this morning, cleaned it out, washed the car with dish detergent as well as I could (before tackling this body work), and took the 55 out on the street in front of the house a few hundred yards or so - it is has been a while since she moved out of the garage (not since I installed the Hurst shifter). The floor shifter works like a new one and I was reminded that the 292 with goodies has a lot of get up and go!
The fellas at the print shop where our church prints millions of Bibles a year gave me some leftovers of an industrial roll of high grade paper - this is excellent masking material! I mounted it above the workbench on 2x10's with conduit running through the middle to act as an axle. The weight of the roll is a little over 50 lbs. Probably more paper than I will use, but it's there and it is 36" wide.
On to the grinding when I get back next week!
Daniel Jessup
Red Lion, Pennsylvania
Daniel Jessup
Posted 10 Years Ago
Not too much to post today, but with this most recent paint job on the inner fenders AND the recent delivery of brand new front end sheet metal hardware it is just about time to start putting it all back together up front.
Any tips on getting this front end back together? One question I had was about the large pad underneath the "U" shaped radiator support. When do I tighten that one down? that pad is pretty thick as new, but it was as flat as a pancake when I removed it.
I assume everything begins in the reverse order of how it was all removed. Begin with the radiator support, attach both air dams and then attach both fenders?
Daniel Jessup
Daniel Jessup
Posted 10 Years Ago
Got a few things done this weekend after being out of state for a whole week...
First plan was to make gaskets for the air tubes and vents. You can take a look at the photos - I had some neoprene stock lying around and a sheet of 1/8" rubber matting from a Canadian supplier, eh?
The holes were punched out with an old socket - seemed to work well and we saved a little dough on the "manufacturing" this weekend.
I used the sealer pictured above to seal all of the gaskets at the air tubes, but i used only the large gaskets themselves at the screen/air dam position.
I also began installing the rubber grommets for the wiring harness to come soon. The kit pictured below is extremely handy for your firewall, fenders, and other sheet metal holes where you will have wiring pass through. With an electric fuel pump, electric fan, A/C to come in a year or two, etc, there will be plenty of extras what with relays and all the like. I have a Rebel Wiring Harness that I will use on this car for more circuits as needed.
Back to the inner fender/air dam assemblies. Basically I decided to assemble the air dam, vent tube, air deflectors (small tubes that direct the flow of air), and the inner fender while all parts hung from my paint rack. Before I could get to hardware though the rubber splash guards had to be installed - you know the ones - they have those pesky staples that hold them in place. I had saved my old guards and referenced the original holes from the staples, punching small holes with an awl so that I could push a staple through. After doing that, the holes were lined up perfectly (well, as perfectly as the factory had done so!) and the staples were pushed through their original holes and then hammered down on the other side while a vise grip kept it tight. I am HAPPY with the installation and they are holding tightly.
More in the next post... don't want to exceed any limits on pictures and what have you BigGrin
Daniel Jessup
Daniel Jessup
Posted 10 Years Ago
A little word about hardware. I had broken quite a few of the old pieces of hardware, be it a J nut for the fenders, a nut/bolt combo that I had to gorilla in two to remove it, etc.
I decided to purchase a kit that was advertised as being all of the nuts and bolts you need for the front end sheet metal....
Do not be confused here. Every little bolt, washer, nut, etc, came in that box on the left AND WAS NOT BAGGED. The separation was done by yours truly, and alas we found that pieces are missing. First up:
If you know your fenders, the above picture is the hardware needed to bolt the rear of the fender at the middle THROUGH THE BODY and access the nut by removing the kick panel. Note - we have enough to do one fender... thankfully I saved everything so I am sure I have what I need, just have to dig it out.
Next up... this little photo:
When bolting the air dams to the U support of the radiator, I discovered that there were none of the shorter bolts included in the kit. All were the same size, and too long for the U support (bottom'd out pretty easily with room to spare at the head). YOU WILL NEED the smaller bolts I have pictured - these are half of them.
Kits may save time because you don't have to sit and measure, count, inventory every little piece you need, but when the kit does not meet your needs... well, that ain't fun. Sad
Said kit ain't cheap either.
Ok, rant over. That was basically the worst of it today with the installation.
Note the photo immediately above. The 6 longer J nuts are in the picture being shown against the shorter size of most of the J nuts that go on your front end (the 5/16" diameter J nuts anyway, you do have some smaller 1/4" elsewhere) well, anyway they go on the inner fender at these locations, 3 a side:
Here are some photos of my makeshift battery tray, battery, and starter solenoid removed and both sides of the inner fenders and air dams/tubes installed! Wink
Next up is to get the seals on both sides installed (if your eyes are pretty good you may have noticed in the photos that these are not yet attached) rear splash guards installed, work on the gravel pan and get it ready to install, ready the bumper brackets, and then grab the fenders to see what we've got! :eek:
Daniel Jessup
Daniel Jessup
Posted 10 Years Ago
Got around to installing what Ford called the "anti squeak seal" on the inner fenders. I used the original holes for the staples and a little bit of sealant where I thought it was needed. Only had enough to do one side. I guess when I ordered this stuff last year I obviously did not read very well - needed two "kits" to get one car completed.
It has been so hot out here lately I decided to work on the fenders in the basement this evening. They both needed to have all of the hardware and stainless removed. I was amazed to find the original clips had held the SS to the fender so tightly. When I began removing the nuts on the under side they began disintegrating - this is about 1/3 of the dust. The driver's side fender was much worse than the passenger side concerning surface rust. You can really see the rust after the SS trim was removed... and of course the original Sea Sprite Green and Snowshoe White.
I feel embarrassed to say that I cannot make out completely what the original shape of the clips actually is supposed to be. I do have some idea. It looks as though there are 10 a side of course, but the two at the very front had a very different shape/size to them. I got out a Restoration Specialties Catalog and looked at clip number 2517 - that looks like the original 8 one each side, but I have no idea about the other two. Anybody have any ideas? Or is there a better clip somewhere?
Daniel Jessup
Daniel Jessup
Posted 10 Years Ago
Not too much time spent in the garage lately, I have been traveling out more than I have been at home. I did get a chance to get in to things a little bit tonight before I head out to Easthampton, Massachusetts tomorrow (anyone live out that way? Wink)
It shouldn't surprise me but I keep finding bits and pieces of sheet metal, brackets, etc that need to be welded up. Take for instance the gravel pan here. I had forgotten that the side piece pictured had just come right off with the passenger side fender. It looked to be spot-welded to the pan, but as you can see when I started it needed to be "straightened up".
I ended up fitting it several times and doing some hammer work to get it nice and lined up. After that I drilled some small holes to the small apron piece and then put the vise grips on to keep it tight and in place.
I don't think it is going to come apart any time soon. I did make sure to clean up as much of the surface rust as possible on both parts to give me a clean weld.
Next up was some blasting work in the cabinet on small brackets and the aprons that go over the top of the upper control arms.
Daniel Jessup
Daniel Jessup
Posted 10 Years Ago
These thin sheet metal flanges and the rubber was not on the 55 when i disassembled the front end a long time ago. I had to pick these up from another 55. So.... I had to find out that the flanges are specific to each side (drivers or passengers) and of course the rubber guard has to match as well. The originals were stapled, but the new ones came in without any staples. When I got to looking at, the cap screws should keep everything nice and tight so we will forego the staples on these pieces.
I cleaned up some of the grille and gravel pan brackets as you can see but before painting I had to weld up the cracked piece. I guess it will hold, the welds looked like they went straight through.
Got quite a bit to do... hopefully in September I can get down to cleaning up the fenders and getting that body work done. I have ordered the drivers side anti-squeak seal from two different companies, both back ordered - :confused: fun stuff.
About to place an order from C&G, but their dash bezel seals are on back order too. Sad I guess everyone else is like me trying to get things done this month!
Daniel Jessup
Daniel Jessup
Posted 10 Years Ago
It's been a very busy August - traveled thousands of miles literally and been in several different states. Nope, not vacation either - all work/church ministry related in training people. I have not been home very much at all. This weekend I am "off" like many of us so I decided to hit it hard with the 55 Ford and do as much as I can.
First things first - take a look at the sandblaster nozzle and stopper. Think it's time for a new one? Rolleyes
Found new parts at the local TSC and we are good to go.
On the Gravel Pan, I really wanted to find an Argent color that I could use but did not want to go the spray can route. I favor my gun as much as I can. So what to do? Let's see.... time to experiment and make our own. Here is a photo of the two colors I mated. The top is Rustoleum Aluminum and the bottom is ACE hardware gray.
I put some of the dark gray in with the aluminum a little at a time and voila!
The photo of the headlight adjuster frame and the gravel pan together give you a point of reference. Hard to tell on a digital photo, but the headlight adjuster frame is Rustoleum Aluminum and the gravel pan is my Argent color. I like it, and I like the fact I can spray what I need through my gun.
Then it was on to tackling the passenger side fender. The PO had a pet chipmunk that had wallowed out a hole for the antenna. You can see how this hole was all cobbled into the fender here...
I guess it's not too bad, but I did not want to put an antenna there when I repaint... planning on using just one rear antenna. At any rate, it was time to cobble it back to flush with the sheet metal! BigGrin
I am no professional welder, but I will show what I did. You professional body men chime in here please. I am sure there is more of this work I will have to tackle at different points soon.
Basically, I took a wire wheel and cleaned both sides of the metal, inside and out.
Then it was on to an air grinder so we could smooth out the hole.
After that, I took a stiff piece of paper and copied the circle shape with a pencil, cut out the shape, and then transferred that to a piece of sheet metal the same thickness as the fender.
After some judicious grinding and shaping, we had a good fit to the hole. So i got out a magnet and put it flush with the fender like so...
One tack weld and away we went with several. You can see from the photos that I blew a few out... if I had more experience I am sure it would have went better.
I would have had it all pretty flush and looking really nice but I got carried away with my grinder - pretty dumb to do actually. Don't follow my lead. It should be pretty easy to fill though with a skim coat when it is time to prep this fender for paint. I would like to get all of my welding done and then prep each piece for primer.
Hopefully I can get more done on this fender soon.
Daniel Jessup
Daniel Jessup
Posted 10 Years Ago
On the installation of the gravel pan, or as Ford called it, "the stone deflector" I set out the hardware ahead of time, with two washers, a nut, and a bolt per hole. 12 holes across the front of air dams. 7/16" head on this hardware.
I also broke out some of these strips of caulk from 3M - thanks for the tips fellas. This stuff is easy to work with and seems to be industrial strength.
Just put the strips down the length of the air dams before fastening the gravel pan and then lined up all 12 holes to snug down the hardware enough to leave it there until I get the fenders back on.
I also reassembled the headlight buckets with their springs and adjuster screws.
What do you guys use for headlights beyond the original setup? I would like to go the relay route and with some Halogens. Can anyone give some good reviews on what they have or maybe some installation tips?
Daniel Jessup
Posted 10 Years Ago
Haven't done anything to upgrade the headlights yet.  There are LED headlights now, and tried and true H4 halogen.  For sealed beams, there are usually a couple options for brightness and that should allow for the easiest installation.  I use Sylvania Silver Star sealed beams on my Firebird.  They are quite a bit brighter than the standard version.  They do draw more power, close to H4, so relays would be a good idea to go along with a higher powered sealed beam.
