Two small nags
Posted By pops 14 Years Ago
Posted 14 Years Ago
Last Active: 6 days ago
Specs for output sise of resistor are 5.5-6.5 max so you are OK there.A thought regarding distributor breaker plate ground.There is a copper braide wire inside distributor which goes from breaker plate on top to under it and grounds it to distributor.Have  a real good look and make sure it has not broken under the plate causing intermittent loss of ground when the distributor plate turns as  timing advances.That has been seen on more than a couple of occasions causing loss of power.
aussiebill
Posted 14 Years Ago
Posts: 1.8K, Visits: 11.4K
pops (6/30/2011)
I have an open mind because I'm a little lost. I'm not convinced it is the timing, but noting that it appeared to have 55 degrees of advance in it at idle left me scratching my head. And the more I retard it, it seems to be more and more sluggish.
I'm open to try anything that I have the test equipment and the ability to attempt.
Here is what I can tell all about the car. I bought it in October 2010 and have driven it about 500 miles since.
'56 Thunderbird with a '57 312 engine and Ford 'O Matic trans
Holley 4bbl list 80457-5 Date Code 1786 (appears to be an after market 600 cfm carb from the list number)
'57 dissy with tach drive
PerTronix Ignitor -"Ignitor" is written on the module (does NOT say "Ignitor II")
Autolite 46 plugs
I feel I have identified #1 at TDC by the white mark on the lower pulley. There are 4-5 graduations in the pulley above the white mark. There are NO graduations below the white mark. The white mark was at the pointer with the rotor pointing to #1 cylinder on the dissy.
The car has had a stumble/hesitation starting off from a stop early on.
Stabbing the throttle gets me beyond the hesitation
The car surges when at a steady cruise speed of 55-65mph
Letting off or pressing the throttle further clears the surging until you stay at a steady cruise speed for a little while again. Then the surges re-emerges.
My test equipment consists of a timing light that also measures RPMs. The light has buttons to advance or retard the light
I have a cheapo dwell meter, and I have a vacuum gauge.
To help with diagonisis, get vacuum reading at idle and that may give ballpark indication of part of problem.Wink
 Down Under, Australia
pops
Posted 14 Years Ago
Turbocharged (60 reputation)Turbocharged (60 reputation)Turbocharged (60 reputation)Turbocharged (60 reputation)Turbocharged (60 reputation)Turbocharged (60 reputation)Turbocharged (60 reputation)Turbocharged (60 reputation)Turbocharged (60 reputation)
Posts: 60, Visits: 538
Autolite 46 plugs
pops (AKA) Clay
'56 Thunderbird
Pete 55Tbird
Posted 14 Years Ago
Posts: 721, Visits: 93.2K
Pops
Can we start over please. Tell us what car, what transmission, what year? The car ran well for 500 miles with only a couple of minor items and the it suddenly did not run well ? Is this correct?
And now you are convinced that the problem is the timing, right? May I suggest that you first find the Ford factory mark on your pulley and that you put a paint mark on this so you can see it.
Try to determine if your Pertronix is Ignitor or Ignitor II (they are different) Ignitor will use a ballast and runs on reduced voltage not full 12 volts.
Try to keep an open mind about the cause of your problem it might be a lot of different things so do one thing at a time. Start with the engine timing and when that is set then find out what else is going on with your car. Pete
pops
Posted 14 Years Ago
I can confirm the red wire going to the dissy is getting 12V (on the incoming side of the ballast resistor) and the coil is getting just over 6V via the ballast resistor.
And I THINK I can now confirm the white mark is TDC. Took #1 plug out, brought the white mark to the indexing point, felt air pushing out of spark plug hole, took off the dissy cap and the rotor is pointing to #1 cylinder. Also, there are 4-5 graduated marks above the white mark each about am eighth inch apart. So, I think the white mark is TDC.
While I had the plug out I took a pic of it.
pops (AKA) Clay
'56 Thunderbird
pops
Posted 14 Years Ago
Okay guys, I will get #1 to TDC on the compression stroke to confirm the position of the white mark, and will also confirm the red wire is getting 9-12VDC and report back.
Thanks for sticking with me on this.
pops (AKA) Clay
'56 Thunderbird
RB
Posted 14 Years Ago
Last Active: 4 Months Ago
Posts: 658, Visits: 16.7K
If you are running a pertronix, make sure the red wire is getting 12v and not reduced voltage from the ballast resistor. The pertronix needs 9-12v to function properly.
Posted 14 Years Ago
Last Active: 9 hours ago
Posts: 3.7K, Visits: 323.2K
Pops:
You said there is awhite paint mark at what you assume is TDC.  Better verify that, someone may have put the dot at 42  degrees and used it to check total advance.  If it's at about 40 and you add 10 to that for the initial setting, you'll have 50 degrees at idle.  Way too much.
pops
Posted 14 Years Ago
I made a new discovery last evening. I brought the timing down to 8 BTDC and readjusted the idle to 550-570. All of this with the carb plugged at the vacuum advance port. A test drive resulted in pretty sluggish low speed the hesitation from any stop was very evident, and the surging continued at cruise speed.
I then decided to open the distributor for the first time since I purchased the car. I found it has an PerTronix Ignitor conversion installed. Would having this require any changes in my investigation tests to find out why this car isn't running well?
SIDEBAR:
Turning the distributor counter-clockwise to bring the initial timing down to 8 degrees had a scary side effect. During the test drive, when I pressed hard on the throttle, the throttle suck partially open, causing a immediate stain in my shorts. I had to quickly get my foot under the gas pedal and lift it up. Once back in the garage, further inspection found that the tach drive cable got tangled in the throttle linkage holding partially open. This was not an issue when the distributor was turned much further clockwise. I modified the routing of the tach cable to prevent this from happening again.
pops (AKA) Clay
'56 Thunderbird
Posted 14 Years Ago
Couple of things I wanted to mention.Initial timing at 16 is too much.8-10 maximum.You should also regap the points however I am not sure if resetting used points to the specs is correct procedure because they are used.You should try it and then check the dwell and see if its correct.Changing the point gap after setting timing will change the timing.Total timing advance adding initial+vacuum+centrifugal should total preferably 42-44 max.How long have the points been in service?Not a bad idea to replace with a new set depending on how old yours are.Also backing the timing down to 8-10 will bring the idle speed down so you may have to bring it back up.Before you do too much more I would get the points situation fixed up as the points have a lot to do with how well your ignition system works.Without proper dwell the the coil does not build up sufficient spark.You should replace both points and condensor as a set.
