little things the gramlins run off with
Posted By The Bat out of hell 12 Years Ago
The Bat out of hell
Supercharged (164 reputation)Supercharged (164 reputation)Supercharged (164 reputation)Supercharged (164 reputation)Supercharged (164 reputation)Supercharged (164 reputation)Supercharged (164 reputation)Supercharged (164 reputation)Supercharged (164 reputation)
Posts: 68, Visits: 355
Whent out into the garage looking for something simple to do,found a dirty set of Acsul yellow plug wires that looked like if I cleaned them up some ,would be great to use on strating up my new old y-block motor just got as a test,so start cleaning and there looking real good,tell I'm near done and note crap there are only 7 plug wires and a short coil wire, nuts nuts,look every were for way too long,an no other plug wire to be found. Geeeez I hate it when that happens no big deel,just what gramlin run off with it!
__________________
"The Bat" out of hell
50's & 60's hotrodder
retired speed shop owner,built and design hotrods, racecars
airbrush t-shirts, engine balancing
Miami fl.
Talkwrench
Posts: 898, Visits: 23.2K
Trust me those gremlins are very common.. Far more as you get older!
Posts: 3.7K, Visits: 497.9K
They really raise the devil with tools that you just laid down.
Or your car keys!
Talkwrench (2/18/2014)
This means my future is hopeless. If I loose something, it is gone. Not even buying a replacement will coax it out of it's hiding place.
lyonroad
Posts: 703, Visits: 3.1K
The Bat out of hell (2/17/2014)
__________________
BOH I just went through my cache of used plug wires and found 4 Yellow Accel High Temp Super Stock Radio Suppression 8mm plug wires. If any or all of these would work for you you are welcome to them. I wiped them down and they don't look to bad. I can stick them in the mail.
Oops I almost forgot. 3 are 30" in length and one is 33". the 33 incher and one of the 30 inchers have a slightly angled boot. The other two are straight.
Mark
1956 Mercury M100
1955 Ford Fairlane Club Sedan
Delta, British Columbia
ian57tbird
Posts: 502, Visits: 21.7K
I find those gremlins always hide my glasses as well.
rick55
Supercharged (658 reputation)Supercharged (658 reputation)Supercharged (658 reputation)Supercharged (658 reputation)Supercharged (658 reputation)Supercharged (658 reputation)Supercharged (658 reputation)Supercharged (658 reputation)Supercharged (658 reputation)
Posts: 550, Visits: 4.4K
I have been doing my car longer than I can remember and have parts spread all over the place.
I seem to spend half my time looking for something and then when I find it, it is generally in the first place I looked, though I didn't see it the first time round. Then once I find it I get distracted, put it down and then forget where I put it. Drives me crazy!
The cycle continues.
Rick - West Australia
lyonroad
Been there done that. As a matter of fact I have small bag of assorted rubber grommets. Anybody have a a clue as to where I put them?
Sometimes I find them later and say to myself "ok that's where they are" . Then when need them again I can't remember where I saw them last.
Mark
1956 Mercury M100
