little things the gramlins run off with
http://forums.y-blocksforever.com/Topic99548.aspx
By The Bat out of hell - 12 Years Ago
Whent out into the garage looking for something simple to do,found a dirty set of Acsul yellow plug wires that looked like if I cleaned them up some ,would be great to use on strating up my new old y-block motor just got as a test,so start cleaning and there looking real good,tell I'm near done and note crap there are only 7 plug wires and a short coil wire, nuts nuts,look every were for way too long,an no other plug wire to be found. Geeeez I hate it when that happens no big deel,just what gramlin run off with it!
__________________
By Talkwrench - 12 Years Ago
Trust me those gremlins are very common.. Far more as you get older!
By paul2748 - 12 Years Ago
They really raise the devil with tools that you just laid down.
By pegleg - 12 Years Ago
Or your car keys!
Talkwrench (2/18/2014)
This means my future is hopeless. If I loose something, it is gone. Not even buying a replacement will coax it out of it's hiding place.
By lyonroad - 12 Years Ago
The Bat out of hell (2/17/2014)
__________________
BOH I just went through my cache of used plug wires and found 4 Yellow Accel High Temp Super Stock Radio Suppression 8mm plug wires. If any or all of these would work for you you are welcome to them. I wiped them down and they don't look to bad. I can stick them in the mail.
Oops I almost forgot. 3 are 30" in length and one is 33". the 33 incher and one of the 30 inchers have a slightly angled boot. The other two are straight.
By ian57tbird - 12 Years Ago
I find those gremlins always hide my glasses as well.
By rick55 - 12 Years Ago
I have been doing my car longer than I can remember and have parts spread all over the place.
I seem to spend half my time looking for something and then when I find it, it is generally in the first place I looked, though I didn't see it the first time round. Then once I find it I get distracted, put it down and then forget where I put it. Drives me crazy!
The cycle continues.
Been there done that. As a matter of fact I have small bag of assorted rubber grommets. Anybody have a a clue as to where I put them?
Sometimes I find them later and say to myself "ok that's where they are" . Then when need them again I can't remember where I saw them last.
