Temperature gauge
Posted By slick56 12 Years Ago
slick56
Posts: 463, Visits: 4.5K
I would like to install an aftermarket temp gauge in addition to the factory gauge, where would be a good (easy) place for the sender unit?
I thought of either in one of the block drain plugs, or the unused plug on the water pump.
South Australia
The Horvaths
Posts: 96, Visits: 1.3K
Does your intake manifold have a tapped hole near the thermostat?
skygazer
Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)
Posts: 112, Visits: 1.5K
Before I installed a heater, I installed the sender for an aftermarket mechanical temp gauge in the heater fitting on the top of the manifold. This worked pretty well.
When I got around to installing the heater, I put a tee fitting in the rubber bypass line under the thermostat... I used a copper tee, and brazed in a threaded adapter for the sending unit. It would just fit in the middle of the rubber hose, with extra clamps on each end. This was pretty simple and cheap, but the temperature readings seemed a little low. Then again, it may just be the cheap gauge.
I eventually drilled and tapped a hole in the manifold near the heater fitting. It may not look stock, but it is about as direct a temperature reading as I can get.
slick56
The Horvaths (1/16/2014)
Yes, that is where the heater hose plumbs into.
South Australia
marvh
Posts: 513, Visits: 16.7K
Here is a previous discussion on installing an additional guage.
http://forums.y-blocksforever.com/Topic78534.aspx
marv
slick56
marvh (1/16/2014)
marv
Thanks Marv, I searched the posts but never thought to look for "sensor".
I have a B manifold, am a bit reluctant to modify a good original part?
Is that a Mummert manifold on yours?
South Australia
dbird
Posts: 279, Visits: 4.0K
I added a threaded insert to the right head instead of the cup plug by the distributor. Easy, no drilling, removable and fairly cheap, about $15 from Mac's, other Thunderbird suppliers probably have them for about the same price, though shipping might be an issue.
marvh
slick56 (1/16/2014)
marvh (1/16/2014)
marv
Yes It is a Mummert manifold.
slick56
dbird (1/16/2014)
Is the right head already threaded in that position (under the plug)?
South Australia
slick56
slick56 (1/17/2014)
dbird (1/16/2014)
Sorry dbird. mis-read reply.
South Australia
