50 amp 12volt generator
Posted By DualQuad312 12 Years Ago
alanfreeman
Supercharged (953 reputation)Supercharged (953 reputation)Supercharged (953 reputation)Supercharged (953 reputation)Supercharged (953 reputation)Supercharged (953 reputation)Supercharged (953 reputation)Supercharged (953 reputation)Supercharged (953 reputation)
Posts: 385, Visits: 6.4K
Jeff, do you mean the bolts that hold the generator housing to the bracket? Alan
Marv, How do you like the FAST system? Easy to tune?
marvh
Posts: 513, Visits: 16.7K
pegleg (1/26/2014)
Really good, the idle is unbelievable, you can hear every cylinder firing the same as the other, fuel economy is steady about +22 mpg running 70 mph with 3.25 rear end. I am going to install a 3.00 this spring as I sold my trailer so don't need the lower ratio for towing power anymore so should get even better mileage.
Tuning is simple just follow the instructions and it has a learning feature.
The only problem I have had so far with the Fast system was with the TPS which did not have the rubber moisture seal on the wiring harness plugin. It got wet when I washed the engine. I installed a new TPS, found the plugin seal in the kit box loose, installed it and have had no other problems.
I would never go back to a carburetor system now.
NoShortcuts (1/8/2014)
Hi Bill,
I'm suspicious that the generator was a police equipment unit. I've got photocopies of a '50s Ford parts catalog list of police specific components that a friend sent me this past Fall, but I can't put my hands on it tonight.
It may be a couple days, but I'll get back to you one way or the other on what I find after I locate the catalog listing...
Sorry for the delay on this, Bill. January 8th WAS a while ago.
The ‘1955-56-57 Ford passenger car and Thunderbird Chassis Parts and Accessories Catalog’ has the following listing for passenger car applications (no ‘Bird) with all engines (6 and 8 cylinder) on page 328:
-56/ 15 volt 60 amp.generator part no. B6A 10002-B to be used with a B5C 10505-A regulator
-56/ 15 volt 50 amp.generator part no. B6A 10002-D to be used with a B6A 10505-C regulator
-56/ 15 volt 60 amp.generator part no. B6A 10002-G to be used with a B6C 10505-A regulator
__________________________
The ‘1949-1959 Ford Car Parts and Accessories Text Catalog’ has the following listing for passenger car applications with all engines (6 and 8 cylinder) on page 507:
-56/59 B6A 10002-B 60amp. with regulator as above; generator is identified as 'Ford'
-56/ B6A 10002-D 50 amp. with regulator as above; generator is identified as 'Bosch'
-56/59 B6A 10002-G 60amp. with regulator as above; generator is identified as 'Bosch'
In addition to 30 amp generators, there were some listings for applications with 35 and 40 amp generators. ALL of the 35 amp applications specified that they were with vehicles with A/C. No notes were included regarding the ‘WHY’ of the 40, 50 or 60 amp applications.
The ‘1949-1957 Ford Police Interceptor Parts List’ that I had been looking for (dated February 1957) also shows on page 39 what is identified in the two sources above:
There is something to what John mentioned regarding alternators. The ‘1949-1959 Ford Car Parts and Accessories Illustration Catalog’ shows an exploded view diagram of two different alternators. On page 360 they show an exploded view of the 1956/59 ‘typical’ alternator (15 volt 100 amp.) and on page 361 they show an exploded view of the 1956/ typical alternator (15 volt 30 OR 50 amp.)
While these Ford ‘Illustration Catalog’ pages reference alternators, the Ford ‘Text Catalog’ parts number listing only has the category, ‘generators’.
I had an acquaintance who used to interchange the words motor and generator the way some people interchange the pronunciation of the word tomato. MAYBE the individuals who compiled the ’49-’59 Ford ‘Text Catalog’ thought that a generator and an alternator were the same thing!?! They do both generate electriicity... Rolleyes
Marv, Please think about doing an article for Bruce Young in the Y block Magazine or a tech article here. I suspect that there would be some interest in this.
