Talkwrench
Visits: 23.2K
stuey
Last Active: 10 Months Ago
Visits: 3.8K
i have a 56 f100 and all the fittings are 45* i purchased my kit from Inline Tube and is similar to the other ones shown on your link. i've had no problems although i have bent the tolley bar. would love a hydraulic version but can't justify the expense considering how often i might use it. the 37* version is for the later AN (army and navy??) fittings utilising the stainless tubing. http://www.inlinetube.com/ inline tube link may prove interesting reading stuey
slick56
Visits: 4.5K
[b]stuey (11/26/2013)the 37* version is for the later AN (army and navy??) fittings utilising the stainless tubing. To avoid confusion, the 37 degree flare is not limited to stainless. It can be steel or aluminum. If your vehicle is stock, all of the flares are 45 degree and the brake lines use a double flare. I can't recommend a tool but I think you are on the right track. The ones you typically find at the parts store are junk.
lyonroad
Visits: 3.1K
Talkwrench the unit you are looking at looks way fancier than the one I use. Mine is the KD unit shown in the right margin of the ad you posted. It works well enough if you are careful and patient. Mine is probably closer to the junk Charlie is referring to than the one you are looking at.
Mark
The Master Cylinder
Visits: 6.2K
Talkwrench, I was just on ATD website. They have a PDF of the instructions and the ATD-5483 looks really nice. I like the way it lines up everything and holds it in a straight line. I may get one of those myself to replace my "typically found at the parts store junk". Haha, not really, I have an older Snap-on flaring tool that has been used a lot of use and has seen better days.
Talkwrench
Visits: 23.2K
Barry L
Visits: 6.7K
Recently got one of these from Brake Quip http://www.brakequip.com/tools.html Once the tubing is cut and deburred, you can make an excellent double flare in seconds... a little pricey, but does beautiful work. The tool is vice mounted . Clamp in the tubing, select the punch from the rotating turret, pull the lever, select the finish punch to set the flare, pull the lever again, unclamp and you're done. Takes longer to explain it here than to make a flare. The tubing holders don't mar the tube . Only short coming is the ability to flare close to an angle (bend in tubing) as the tube clamping dies are about 1 to 1 1/2 inches long. The optional 37 degree tooling is for AN fittings that use ferrules and a single flare....aircraft style. Barry
slick56
Visits: 4.5K
Article on YouTube on tool i bought from eBay for $60. He gets to the nitti gritti about 2:55 http://www.youtube.com/watch?v=iUDyEu_NYK8
South Australia
ian57tbird
Last Active: 4 days ago
Visits: 21.7K
Check out what RIDGID has. They have some very good tube forming tools. They usually have a couple of different ranges of quality.
