PCV conversion
Posted By 55F1Y 13 Years Ago
55F1Y
Posted 13 Years Ago
Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)
Posts: 16, Visits: 273
Is there a way to replace the draft tube an a warmed up 292 street engine.
"Anything worth having is worth working for"
joey
Posted 13 Years Ago
Posts: 204, Visits: 5.4K
http://forums.y-blocksforever.com/Topic16557.aspx?Keywords=installing%20pcv
http://forums.y-blocksforever.com/Topic73520.aspx?Keywords=installing%20pcv
http://forums.y-blocksforever.com/Topic53365.aspx?Keywords=installing%20pcv
http://forums.y-blocksforever.com/Topic35391.aspx?Keywords=installing%20pcv
Posted 13 Years Ago
And here are more links.
Blocking off the road draft tube
Crankcase evacuation
Finned valley pan and PCV valve installation
Installation of PCV valve into the top of the block
Installation of PCV valve at top and rear of block 2
Modifying valve covers for PCV valve installation
Valley pan PCV valve installation
Valve cover baffle for PCV valve
Why a PCV valve or system?
'59Edsel
Posted 13 Years Ago
Supercharged (422 reputation)Supercharged (422 reputation)Supercharged (422 reputation)Supercharged (422 reputation)Supercharged (422 reputation)Supercharged (422 reputation)Supercharged (422 reputation)Supercharged (422 reputation)Supercharged (422 reputation)
Posts: 163, Visits: 3.5K
So I take it this is recommended eh?
http://oi43.tinypic.com/vyxn49.jpg
Johnny Mainline
Posted 13 Years Ago
Supercharged (91 reputation)Supercharged (91 reputation)Supercharged (91 reputation)Supercharged (91 reputation)Supercharged (91 reputation)Supercharged (91 reputation)Supercharged (91 reputation)Supercharged (91 reputation)Supercharged (91 reputation)
Posts: 57, Visits: 486
I drilled and tapped the block. However, the AC valve cv726 mentioned in the post isn't made anymore, and they go for around $30.00 on epay, one person had it at 150.00
http://www.ebay.com/itm/1966-1967-PCV-Valve-NOS-/300748729179?pt=Vintage_Car_Truck_Parts_Accessories&hash=item4606056b5b&vxp=mtr
Crazy huh... NAPA quit making their replacement version. I went to 4 other stores looking for that valve, each place broke out their books and couldn't find one like it either.
The closet one is NAPA's part CRB29255, it looks just like the AC part but it flows the opposite direction. So, I drilled and tapped a 1 inch carb-spacer, screwed the threaded side of the valve to it, and put a nipple in the block. It looks pretty clean, and my Holley pretty much hides the valve completely. I can try and post a pic here in a day or so.
-Johnny
Portland, OR
Posted 13 Years Ago
Last Active: 31 minutes ago
Posts: 3.8K, Visits: 33.3K
Another good reason to install a PCV and block the road draft tube is you won't have that gas smell in the garage after it sits for a day.I installed one on mine using the T-Bird valley pan.I have a 390 Holley which has a hookup for a PCV valve.I used a PCV from a 78 or so Zephyr/Fairmaont 4 cylinder.Works well.The first PCV I used from a 302 Ford flowed too much air at idle and really messed up the idle mixture.Trial and error.
Teros292
Posted 13 Years Ago
Supercharged (150 reputation)Supercharged (150 reputation)Supercharged (150 reputation)Supercharged (150 reputation)Supercharged (150 reputation)Supercharged (150 reputation)Supercharged (150 reputation)Supercharged (150 reputation)Supercharged (150 reputation)
Posts: 129, Visits: 12.3K
There was article in newest Rebel Rodz magazine about adjustable PCV valve.
Tero from Nurmijarvi, Finland
56 Country Sedan, 61 F-100, 61 F-600, 55 F-620, 52 Mercury
