PCV conversion
http://forums.y-blocksforever.com/Topic83235.aspx
By 55F1Y - 13 Years Ago
Is there a way to replace the draft tube an a warmed up 292 street engine.
By joey - 13 Years Ago
http://forums.y-blocksforever.com/Topic16557.aspx?Keywords=installing%20pcv
http://forums.y-blocksforever.com/Topic73520.aspx?Keywords=installing%20pcv
http://forums.y-blocksforever.com/Topic53365.aspx?Keywords=installing%20pcv
http://forums.y-blocksforever.com/Topic35391.aspx?Keywords=installing%20pcv
By Ted - 13 Years Ago
And here are more links.
Blocking off the road draft tube
Crankcase evacuation
Finned valley pan and PCV valve installation
Installation of PCV valve into the top of the block
Installation of PCV valve at top and rear of block 2
Modifying valve covers for PCV valve installation
Valley pan PCV valve installation
Valve cover baffle for PCV valve
Why a PCV valve or system?
By '59Edsel - 13 Years Ago
So I take it this is recommended eh?
By Johnny Mainline - 13 Years Ago
I drilled and tapped the block. However, the AC valve cv726 mentioned in the post isn't made anymore, and they go for around $30.00 on epay, one person had it at 150.00
http://www.ebay.com/itm/1966-1967-PCV-Valve-NOS-/300748729179?pt=Vintage_Car_Truck_Parts_Accessories&hash=item4606056b5b&vxp=mtr
Crazy huh... NAPA quit making their replacement version. I went to 4 other stores looking for that valve, each place broke out their books and couldn't find one like it either.
The closet one is NAPA's part CRB29255, it looks just like the AC part but it flows the opposite direction. So, I drilled and tapped a 1 inch carb-spacer, screwed the threaded side of the valve to it, and put a nipple in the block. It looks pretty clean, and my Holley pretty much hides the valve completely. I can try and post a pic here in a day or so.
By oldcarmark - 13 Years Ago
Another good reason to install a PCV and block the road draft tube is you won't have that gas smell in the garage after it sits for a day.I installed one on mine using the T-Bird valley pan.I have a 390 Holley which has a hookup for a PCV valve.I used a PCV from a 78 or so Zephyr/Fairmaont 4 cylinder.Works well.The first PCV I used from a 302 Ford flowed too much air at idle and really messed up the idle mixture.Trial and error.
By Teros292 - 13 Years Ago
There was article in newest Rebel Rodz magazine about adjustable PCV valve.
