Y block Billy
Posts: 1.6K,
Visits: 5.2K
I just picked up a motor which was out of a T bird and was supposed to be a 312 but ended up a 292 (B9AE) block. However, it had a tach drive distributor (55-56 style) a set of steady rest, Bird dual exhaust manifolds, front pulley etc which I will not need since I do not own a bird. Reasonable offers accepted on parts. On another note, I just took apart a 1964, 361 Truck motor and the distributor housing on that also had provision for tack drive which with correct internals would probably work for a 57 later setup, anybody ever try this?
Y block Billy
Posts: 1.6K,
Visits: 5.2K
Forgot to mention I have the oil pan also!
Last Active: 56 minutes ago
Visits: 38.2K
Last I heard you were getting your oil changed! How are you? We don't need anymore scares this year. Chuck
Posts: 1.4K,
Visits: 179.6K
Hi Bill,
It sounds like you're back at it already! GREAT!
Regarding the 361 distributor, does the distributor gear have 13 or 14 teeth? Also, does it have a neoprene seal where it seats in the block?
Sounds like you may have a few parts that I'm looking for. I forget where you are geographically. -Maine? Interested because of shipping factor.
Regards,
Y block Billy
Posts: 1.6K,
Visits: 5.2K
No Shotcuts, If using the 361 Tach drive distributor housing you would need the Y block shaft and gear since it is longer than the FE, the housing is the same. there are a couple other nuances that may come in to play also like the end of the distributor is a larger diameter on the 361-391 so when they go with a regular distributor in a 361 block they normally bush down there, so to use it in a Y the end may have to be turned down. You would also need the distributor shaft from a Y with the teeth for the tach drive so finding one of those may be just as hard as finding a complete distributor. but then again many people damaged housings removing them or rolling blocks around and there may be more shafts out there than housings.
Y block Billy
Posts: 1.6K,
Visits: 5.2K
I guess I should have posted this in Classifieds, Ted, Can you move it?
Last Active: 35 minutes ago
Posts: 7.4K,
Visits: 205.7K
Y block Billy (5/13/2013) I guess I should have posted this in Classifieds, Ted, Can you move it?Done.
John Mummert
Visits: 7.5K
Billy, I need the oil pan and a T-Bird crank damper if you still have them. email me with a price fordperf@earthlink.net
