Y-BLOCK BOOK
Posted By stuey 13 Years Ago
slick56
Posts: 463, Visits: 4.5K
Glad i pre-ordered, just found this on Amazon..
South Australia
'55 customline
Posted 5 Years Ago
First Time Poster
Posts: 1, Visits: 7
HEY EVERONE:  JUST A COUPLE OF QUICK QUESTIONS. WHEN I REBUILD MY 272 I AM  GOING FROM A ROAD DRAFT TO A VALLEY PAN WITH P.C.V. BY JOHN MUMMERT. I WAS WONDERING ABOUT A BLOCK OFF PLATE FOR THE EXISTING ROAD DRAFT, BUT AFTER BIT OF RESEARCH I READ THERE WAS ONE PERSON WHO ALSO KEPT THE ROAD DRAFT AS WELL AS THE P.C.V. ANY THOUGHTS ARE APPRECIATED.
T.D
Posted 5 Years Ago
Posts: 1.9K, Visits: 195.0K
This is Ted’s latest post on PCV. Half way down, all the links.
http://forums.y-blocksforever.com/Topic159033.aspx#bm159038
And no, you probably don’t want to leave that open.
Joe-JDC
Posted 5 Years Ago
Last Active: 15 minutes ago
Posts: 798, Visits: 23.3K
Positive Crankcase Ventilation needs any incoming air to be filtered.  Drawing air from the road draft tube would be counterproductive to that need.  Joe-JDC
Posted 5 Years Ago
Posts: 2.0K, Visits: 306.7K
http://forums.y-blocksforever.com/uploads/images/bb344934-4048-4324-bde6-edd9.jpg
Posted 5 Years Ago
Re Road Draft cover.. If you have a scrap pce of say 3/16" or 1/4" Aluminum about 4" x 3" you can make a cover with a hacksaw & grinder or file. Drill holes, make a gasket, & your good to bolt it on. I think I used the existing bolts... As noted don't leave the road  draft cover open.  With the oil filler cap screen & the draft cover open, there probably wouldn't be enough vacuum for the valve to operate properly..
