Here’s a call for dual quad intakes for a dyno test
Posted By Ted 14 Years Ago
Rated 4.8 stars based on 3 votes.
Bob's 55
Posted 13 Years Ago
Posts: 287, Visits: 1.0K
Ted, Nice display of duel 4 barrel set ups w00t Like the aluminum fabbed high rise.
Thought I would share a couple of pictures of a piece of "Garage Shelf Art" that a friend has;
BOB
ecode ragtop
Posted 13 Years Ago
Supercharged (443 reputation)Supercharged (443 reputation)Supercharged (443 reputation)Supercharged (443 reputation)Supercharged (443 reputation)Supercharged (443 reputation)Supercharged (443 reputation)Supercharged (443 reputation)Supercharged (443 reputation)
Posts: 285, Visits: 3.4K
Ted, I guess Vic. and I are driving down from Ill. to share in the fun of the 2x4 tests. I will bring a 57 round E code air cleaner, also a 56 Merc. intake and a couple of carbs, you can look at. Tom
  JUST A MIDNIGHT CRUISE DOWN THUNDER ROAD!!! TOM DRUMMOND MIDWEST DIRECTOR 57 FORD INTERNATIONAL
Oldmics
Posted 13 Years Ago
Posts: 710, Visits: 78.1K
Tom
The addition of that 56 Merc intake would be awesome.That is the only missing link from the original Ford/Merc intake lineup from the 56-57 era.
That Merc intake is such a different design that it will e interesting to see how it preforms.
I will be sending out my pile of stuff on Monday which will include 2 of the original/correct carbs for that Merc intake.
Should be a good test all around.
Oldmics
Posted 13 Years Ago
Posts: 4.6K, Visits: 39.4K
I never new there was a difference between the Ford and Merc intakes. That will be interesting to see. Chuck
ecode ragtop
Posted 13 Years Ago
Old Mic. Are you sending down a purolator air cleaner? or a 56 oval? Tom
Oldmics
Posted 13 Years Ago
Tom
I am sending an oval and the Purolater.
Can also send a Bird dual quad air cleaner.
Are you bringing the passenger car dual quad air cleaner?
Let me know if I should also send the Bird unit.
Thanks,Oldmics
UPDATE - BIRD STYLE DUAL QUAD AIR FILTER ALSO SENT FOR TESTING  Hehe
Posted 13 Years Ago
Bob.  Thanks for the pics.  That does give some other ideas for carb placement options and the linkage required to make them work.
Special thanks to all that sent the extra Teapot carbs and related parts so that some additional carbs could be put together for the tests.  I have installed some of the new ‘orange’ accelerator pump cups from Daytona Carb Parts and those are definitely an improvement over the older black cups that have been coming in the Teapot carb kits.  Finally have some Teapots shooting fuel like they should.
The testing is scheduled to start on the morning of Monday, January 14th.  If all goes well, then three days of testing is expected to make a large dent in the amount of testing planned.  If it takes a fourth day, then so be it.  Picking out the pairs of carbs to be used for a majority of the testing could prove to be cumbersome depending upon jetting, linkages, and who knows what else.
The first round of tests will be with the ported 113 heads on the engine and then they get changed out to a set of aluminum heads for the real workout.  While the ported iron heads will likely give a good idea on how the different manifolds compare to each other, the thought process here is to force any restriction issues the intakes have by freeing up the head flows even more by using the aluminum heads.  When I did my first round of carb tests on the dyno mule back in day one, I had used the older style Hedman two tube headers and the lack of response to carb changes and ignition timing was in a large part due to the restriction taking place in the exhaust.  The EMC project made big strides in the exhaust area so I feel confident that this will be a very definitive intake manifold test.
Posted 13 Years Ago
Do you remember Charlie Dover's setup?
http://www.y-blocksforever.com/expo09/cm0904/content/charliem0904_090_large.html
Posted 13 Years Ago
aussiebill (abbreviated) ...A pair of teapots modified to Karol Millers recommendations? Are these recent recommendations or from and old article? or is an article of the mods in the near future? ...I would love to know what the mods are on the teapots mentioned, I'm sure once the tests are done that may be possible.
This is to echo aussiebill's previous entry. After mining the Forum archives to learn what modifications to make to '56 Ford/Mercury single quad application Holley 4000s so that they function satisfactorily in a dual quad configuration, I would greatly appreciate any additional information that might further improve their performance.
That said, I can understand Ted's waiting to publish Karol's modification info until the dyno test results are obtained. One of the things I value enormously about the information shared on this Forum is that there are few unsubstantiated entries.
Thanks to Ted for all his time and effort related to accomplishing yet another series of comparative testing AND to all those who have sent equipment to Ted to permit the testing.
ecode ragtop
Posted 13 Years Ago
Old Mic. I would like to see if there is any difference from the bird to car aircleaner, if you want to send it. I am bringing the 57 car e-code. Tom
