Here’s a call for dual quad intakes for a dyno test
http://forums.y-blocksforever.com/Topic77437.aspx
By Ted - 14 Years Ago
I’m in the process of gathering up carbs and intakes for an upcoming Ford Y-Block dual quad intake test.  The dual quad intakes on hand thus far for testing are the Edelbrock 255 and 257, 1956 Ford, 1957 Ford, Edmunds, and Fenton.  It would be a plus to see the Weiand and Offenhauser dual quad intakes also represented during this test.  Plans are to test some of the intakes with a variety of carbs including the new Demon Street Fighter carbs so there should be lots of information available once the test is concluded.
If anyone has a dual quad intake they would like to see tested during this dyno session, just get back with me and we can determine if this is something different or simply a duplicate of one that’s already on hand.  I could also use another 1956 FoMoCo intake as the one I have here has been heavily modified and would not be a good comparison to the stock ’57 model I have.  My contact information is at www.eatonbalancing.com .
By Oldmics - 14 Years Ago
Can any sort of test be considered for the different shapes of dual quad air cleaner assemblys at the same time?
Or are those such a small part of the equation that its not worth doing?
Oldmics
That’s a Yes for potentially testing some of the different air cleaners.  In a best case scenario, all air cleaners would need to be tested on a single manifold simply to reduce testing variables.  But if the air cleaners are for different carburetor center to center spacings, then examining the percent change in power outputs when comparing air cleaner versus no air cleaner would help to evaluate air cleaner performance from one intake to another.  I’m sure the type of carburetor is also a player in the air cleaner design as the Teapots have been quite sensitive to air cleaners that are too small or restrictive around the choke area.   I suspect that was just one of the engineering considerations as to why the ’57 dual quad air cleaners were the large round units versus the oval shaped air cleaners that were used in 1956.
I did dyno test a customer’s dual quad equipped Y that repeatedly made more power using a home-made air cleaner versus running without an air cleaner.  While this particular dual quad set up was using Edelbrock carbs, it was determined that the power improvement was not as much related to the air/fuel mixtures but were instead to the redirection of air flow into the carbs.
Here are carb center to center spacings on some of the intakes currently on hand.
Edelbrock FM255             – 8 ¾”
Edelbrock 257                  – 7 1/8”
Edmunds DM-427           – 8 9/16”
1956 Ford EDB-9425-C – 7 5/16”
1957 Ford ECG-9424-D – 7 5/16”
By Grizzly - 14 Years Ago
Ted,
One thing that really impresses me about the y block is the vintage speed aspect, I mean what could be more impressive than a multiple carb setup.
Whilst I'm too far away to loan you anything, I see that my 257 is allready represented, what are you looking for in terms of components or assistance in conducting this test.
Your work on testing different engine components for y blocks is really impressive and much appreaciated.
thanks
Warren
Warren.  Looks like there will be two 257 intakes represented, one that’s stock and one that’s fully ported.
By mongo - 14 Years Ago
hey , if the edelbrocks work good, I will blow the dust off of mine, and polishing and grinding, will ber lurking Ted
Still need a Weiand and Offenhauser dual four intake for the upcoming intake manifold dyno test.  Can also use a 1957 dual quad air cleaner to test against some of the other air cleaners that are in the works to be tested.  If you have one of these items you’d like to loan for the test, feel free to contact me.  My contact information is at www.eatonbalancing.com .
By suede57ford - 14 Years Ago
I have some Lincoln Teapot carbs if you need some to compare against other carbs.
Still need a Weiand and Offenhauser dual quad intake for the upcoming dual quad dyno test.  If you know of one hanging loose that I can borrow, get hold of me and I’ll arrange for shipping.  Contact info is at www.eatonbalancing.com .
By PF Arcand - 14 Years Ago
Ted: I wonder if people like Jerry Christiansen, Bruce Young or Michael Henaults out in California might have a line to the intakes you are looking for??
Grizzly (12/7/2012)
Ted, ...... Whilst I'm too far away to loan you anything, I see that my 257 is allready represented, what are you looking for in terms of components or assistance in conducting this test. .....
Warren.  There’s typically always some extra hands available for these kinds of tests.  And most of those that help are ready to get their hands dirty as this is something out of the ordinary that doesn’t come along very often for most.  As far as parts and expenses, the forum members have been generous in throwing in extra bucks to cover gaskets, miscellaneous parts, shipping, and fuel.  And without the loan or donation of some of the various intakes and carbs in this kind of test, there would simply be too many unanswered questions.  For myself, there are always learnings out of these tests which are applied to future engine builds.  And these tests always generate great fodder for future magazine articles.
PF Arcand (12/19/2012)
Paul.  Did get in touch with Michael Henaults and the others and there are no different 2X4 intakes on their ends.
But to keep interest level high, here are a couple of pics of just a few of the dual quad setups being readied for this test.  Thanks to all thus far for carbs, intakes, and parts for this test.  It would not happen without help from all.
By Grizzly - 13 Years Ago
Ted,
What carbs do you plan on running in the test. From your photo's I see an assortment of holley teapots, early carters, edelbrocks, demon, I guess with adaptor any four barrel carb could be run but this will mean a lot of changing out.
If you don't run most of the common ones there will be people asking about the one's that weren't run?
Big test this one w00t
cheers
Warren
By Ted - 13 Years Ago
Grizzly (1/1/2013)
Ted,  What carbs do you plan on running in the test. From your photo's I see an assortment of holley teapots, early carters, edelbrocks, demon, I guess with adaptor any four barrel carb could be run but this will mean a lot of changing out.
Warren.  Not all the carbs will be tested on all the intakes.  But all the intakes will be tested with at least the same set(s) of carbs and as another test, one intake will be selected to test all the different carb pairs.  Well maybe two intakes depending upon how the Holley model 4160 carbs do.  Intake manifolds can be evaluated against each other this way while the carbs can also be compared to each other as a separate test while saving wear and tear on the engine and the guys doing the testing.
Right now there are original dual quad Teapots, a pair of Teapots modified per Karol Miller’s recommendations, Lincoln Teapots, Mercury WCFB’s, Buick/Olds WCFB’s, 450 cfm Holleys, 660 center squirter Holleys, Carter/Edelbrock 500’s, and Demon 625 Street Fighters.  Still working on a pair of Rochester 4V carbs but they are being problematic.  The key here is to run both old school and new technology carbs in this test.  There is a wide enough range in carbs at this point to at least get a feel for what cfm requirements are best either from a daily driver or racing standpoint.
And I have a known good pair of 780 Holleys set up for dual quads off of my 390 FE that I can use if at least one of the dual quad manifolds looks like it can stand to be overloaded and the carbs installed in the inline manner.  The model 4160 Holleys only install in an inline fashion on the wider spaced dual quad intakes.  The Edelbrock 257’s and Ford manifolds have too close a carb spacing to use the model 4160 HoIleys without special offset carb adapters.  On the other hand, the Edmunds, Fenton, and Edelbrock FM255 intakes can take the Holleys as an inline setup without issue.
I did spend a couple of days just sorting out many of the carbs individually on a stock ‘B’ intake so it’s at least known that the carbs do run okay by themselves.  Gary Burnette stopped by and spent some time helping with some of that.
There’s going be enough variety in the carbs that are tested in both style and cfm where interpolation of the results is expected to give some kind of indication how carbs not tested will fare.
By Y block Billy - 13 Years Ago
A pair of teapots modified to Karol Millers recomendations? Are these recent recomendations or from and old article? or is an article of the mods in the near future? I know Drylakes has been in touch with him, It would be great that our Hero come out and play!
How did Gary end up in your neck of the woods?
Y block Billy (1/3/2013)
Karol was by and saw what I was doing and pointed out some of the Teapot mods that he had performed on a dual quad setup for one of his record runs.  The pair of L1161-2 carbs that have been modified per his recommendation and then ran individually on the dyno mule have really strong lowend torque curves.  And the horsepower numbers equal those of the Lincoln Teapots even with the A/F numbers showing on the lean side with 50-73 jets.  I’ll not concern myself with jetting corrections until I have two of them running together.  Gut feel says the air fuel mixtures will fatten up some with two of them running as a pair.  And it will be interesting to see how those two carbs run in comparision to the pair of original List#1134 dual quad Teapots that are sitting here.
Gary happened to be in San Antonio on personal business and made it a point to drop by.  The problem with dropping by is you’re likely going to be put to work if I’m doing something Y related.  Can’t understand why no one hangs around when Brand X engines are being worked on?????
Ted:
The answer is obvious.  Quit working on the brand x stuff.
Years ago my brother-in-law and I had a general repair shop.  His Dad (my F.I.L.) was a toolmaker in a gm factory.  We began to relate how many more gm cars we worked on compared to Fords, and how more serious the problems with the gms.  He didn't believe us, so he started keeping a little notebook.  After a while he admitted that we were telling it like it was.  He hated to say so.  So, I guess if you still want to eat and feed your family, you'll have to keep working on the other kinds.
By lyonroad - 13 Years Ago
Believe me if I was ever able to get to Lorena Texas it would be an honour to be "put to work" (although at your peril).
By aussiebill - 13 Years Ago
Ted (1/4/2013)
Ted, very gratifying to keep Kariol still involved in the y blocks and share some of his knowledge and storys, would love to meet the man, i would love to know what the mods are on the teapots mentioned, i,m sure once the tests are done that may be possible. As you know the lincoln teapots are hard to come by and if these mods equal them then theres HP to be gained. Thank you and best wishes for the new year.Smile
Beleive me Ted it was a pleasure to do the same as Gary did when I worked in the area, also to see Chucks engine run on the dyno before he did!!! I still have to get him the videos of it.
Also Great that Karol could stop by, that must have been a blessing!
By MoonShadow - 13 Years Ago
If I can ever get motivated to drive to Maine! Chuck
By Bob's 55 - 13 Years Ago
Ted, Nice display of duel 4 barrel set ups w00t Like the aluminum fabbed high rise.
Thought I would share a couple of pictures of a piece of "Garage Shelf Art" that a friend has;
By ecode ragtop - 13 Years Ago
Ted, I guess Vic. and I are driving down from Ill. to share in the fun of the 2x4 tests. I will bring a 57 round E code air cleaner, also a 56 Merc. intake and a couple of carbs, you can look at. Tom
By Oldmics - 13 Years Ago
Tom
The addition of that 56 Merc intake would be awesome.That is the only missing link from the original Ford/Merc intake lineup from the 56-57 era.
That Merc intake is such a different design that it will e interesting to see how it preforms.
I will be sending out my pile of stuff on Monday which will include 2 of the original/correct carbs for that Merc intake.
Should be a good test all around.
Oldmics
I never new there was a difference between the Ford and Merc intakes. That will be interesting to see. Chuck
Old Mic. Are you sending down a purolator air cleaner? or a 56 oval? Tom
Tom
I am sending an oval and the Purolater.
Can also send a Bird dual quad air cleaner.
Are you bringing the passenger car dual quad air cleaner?
Let me know if I should also send the Bird unit.
Thanks,Oldmics
UPDATE - BIRD STYLE DUAL QUAD AIR FILTER ALSO SENT FOR TESTING  Hehe
Bob.  Thanks for the pics.  That does give some other ideas for carb placement options and the linkage required to make them work.
Special thanks to all that sent the extra Teapot carbs and related parts so that some additional carbs could be put together for the tests.  I have installed some of the new ‘orange’ accelerator pump cups from Daytona Carb Parts and those are definitely an improvement over the older black cups that have been coming in the Teapot carb kits.  Finally have some Teapots shooting fuel like they should.
The testing is scheduled to start on the morning of Monday, January 14th.  If all goes well, then three days of testing is expected to make a large dent in the amount of testing planned.  If it takes a fourth day, then so be it.  Picking out the pairs of carbs to be used for a majority of the testing could prove to be cumbersome depending upon jetting, linkages, and who knows what else.
The first round of tests will be with the ported 113 heads on the engine and then they get changed out to a set of aluminum heads for the real workout.  While the ported iron heads will likely give a good idea on how the different manifolds compare to each other, the thought process here is to force any restriction issues the intakes have by freeing up the head flows even more by using the aluminum heads.  When I did my first round of carb tests on the dyno mule back in day one, I had used the older style Hedman two tube headers and the lack of response to carb changes and ignition timing was in a large part due to the restriction taking place in the exhaust.  The EMC project made big strides in the exhaust area so I feel confident that this will be a very definitive intake manifold test.
Do you remember Charlie Dover's setup?
http://www.y-blocksforever.com/expo09/cm0904/content/charliem0904_090_large.html
By NoShortcuts - 13 Years Ago
aussiebill (abbreviated) ...A pair of teapots modified to Karol Millers recommendations? Are these recent recommendations or from and old article? or is an article of the mods in the near future? ...I would love to know what the mods are on the teapots mentioned, I'm sure once the tests are done that may be possible.
This is to echo aussiebill's previous entry. After mining the Forum archives to learn what modifications to make to '56 Ford/Mercury single quad application Holley 4000s so that they function satisfactorily in a dual quad configuration, I would greatly appreciate any additional information that might further improve their performance.
That said, I can understand Ted's waiting to publish Karol's modification info until the dyno test results are obtained. One of the things I value enormously about the information shared on this Forum is that there are few unsubstantiated entries.
Thanks to Ted for all his time and effort related to accomplishing yet another series of comparative testing AND to all those who have sent equipment to Ted to permit the testing.
Old Mic. I would like to see if there is any difference from the bird to car aircleaner, if you want to send it. I am bringing the 57 car e-code. Tom
ecode ragtop (1/7/2013)
Hi Tom,
I've done a comparison of two original '57 Ford dual quad air cleaner housings for the 'Bird and the passenger car. I'm understanding that there are numerous reproductions out there...
The housing bases are identical. The passenger car bottom base was simply rotated 180 degrees for use on the 'Bird.
The upper housings are 'related' to each other. The total height of the two upper housings are identical. However, the height dimension of the domes differ by one inch. Because the top section of the air cleaner housing was also rotated 180 degrees for use on the 'Bird, the stamping 'FRONT' on the top of the one dome was also rotated 180 degrees and is relocated to the position of the opposite dome from the passenger car unit.
Again, the total height of the passenger car and 'Bird air cleaner upper housings are the same. Because the domes on the 'Bird upper housing are one inch taller than the domes on the passenger car unit, the height of the side 'skirt' of the passenger car air cleaner housing is one inch taller than the 'skirt' on the 'Bird housing.
Related to the difference in the height of the side 'skirt' of the two upper housings, the original passenger car air cleaner element was taller than the 'Bird element.
Hope this helps! Smile
No short cuts, I understand the difference between the Bird and car E aircleaners, My thought was would there be any power difference, when they were both used on the same engine. Thanks Tom
ecode ragtop (1/8/2013)
DUH! Sorry, Tom. I misunderstood your post. Blink
Regards,
Noshortcuts, Thanks for your help.Tom
I'd be interested in how a '57 'E' 'Bird air cleaner housing performed with a '57 'E' code passenger car filter element compared to any of the other air cleaner assemblies that Ford offered. It would seem that there would be less restriction to air flow to the carburetors...
Unfortunately the application information would not work on the little 'Birds because of hood clearance. Ermm
And it may run worse due to the fact that more air flow could lean out the mixture.
Now if it was jetted up and had more air flow. Wink
Ted has lots of toys and options to play with - thats for sure.
By the way-good call on the Bird and passenger air filter comparisons  Smile
Oldmics
Ted (12/6/2012)
TED, all of us y block effected, inflicted, fans sit by for your results, like an expectant father in the waiting room. I havent heard or seen there was an OFFY 2x4 and was eager to see pic  of one if anyone here has one. I do have local CAIN 2 x4 intake if interested but as not a regular item may be not be relevant in your test programme. It is open plane and suit high rpm use more than cruising i would think. Smile
Ted, these are 2 Cain intakes, basically the same except for minor casting changes, thought you guys might be interested to see unusual ones from over here.Smile
yyy
By mctim64 - 13 Years Ago
Called Ted's shop today.  Wouldn't come to the phone, he was busy with the dyno.  Wonder what he found? BigGrinWink
Probably coundnt hear the phone with all that dual quad air flow rushing around. Tongue
It will be a good story when its told -fur shure!
Oldmics
charliemccraney (1/7/2013)
Charlie.  Thanks for the reminder on Charlie Dover’s dual quad setup in his ’56 wagon.  His wagon was quite streetable with the dual quads and the carb linkage exhibited some really nice engineering for the sideways turned carbs.  The working cruise control is also a nice touch.
Bill. Thanks for the pics of the Cain dual quad manifold. Design wise, it resembles the Cain single four intake.
An Offy dual quad was not made available so that one obviously will not be tested during this session. I do have an Edelbrock 257 here that has had its plenums hogged out and that by itself will give a rough idea of what the Cain manifold might be capable of. I suspect lowend torque values will be dismal. The modified Edelbrock manifold does still have some divider material left at the ports whereas the Cain intakes have no port dividers at all so that must be taken into account. Here’s a picture of the modified #257.
http://www.y-blocksforever.com/forums/Uploads/Images/b63683de-10e7-4b24-90e6-7099.jpg
Testing is in process and is currently taking place with the ported 113 iron heads on the engine.  Teapot carburetor jetting is a time burner though.  It takes about as long to rejet a pair of Teapots as it does to do an intake manifold change so you see where the time goes in a hurry.  The factory ’57 setup though is a well engineered piece as delivered from the factory as it is an easy 45 horsepower improvement over the ‘A’ manifold with a single Lincoln Teapot.  But there’s still lots of carbs/intake combinations left to test and at some point, the aluminum heads will go on the engine to retest the better intake/carb combinations.
Once the testing is concluded, I’ll post some kind of chart that allows an ‘at a glance’ comparision.
Not wanting to distract from Ted's testing but I came upon this article when doing some researce. http://www.mustangandfords.com/techarticles/engine/mdmp_1206_dual_quad_carburetors_testing_part_1/viewall.html
http://www.mustangandfords.com/techarticles/mdmp_1207_dual_quads_twin_win_or_double_trouble_part_2/trans_am_dual_quad_intake.html
I had always thought that dual quads were down just a bit on a single four but this test is showing them 25hp up. I wonder if the technical advatages that were avaliable in the 60's was available during the 50's and learnt when working with the Y block?
Cheers
Warren
Grizzly (3/6/2013)
I had always thought that dual quads were down just a bit on a single four but this test is showing them 25hp up. I wonder if the technical advatages that were avaliable in the 60's was available during the 50's and learnt when working with the Y block? ...Warren
What I’m seeing so far in the dual quad testing is that the ‘made in the Fifties’ dual quad intakes as a general rule easily outperforms the factory single four barrel intakes for the time and especially the Teapot 4V intakes by a bunch. But when compared to the Blue Thunder or Mummert aluminum single four intakes, the old school dual quad intake manifolds do come up short. If a new dual quad intake was to be designed with the same modern technology that’s used to make the BT and Mummert intakes, then the potential is there for an increase in performance.
A case in point is a Ford 390 I recently dynoed with the 427 single four Sidewinder intake, the C8AX dual quad tunnel wedge intake, and an Edelbrock Victor single four manifold. While the C8AX manifold with any of three different pairs of carburetors easily outperformed the Sidewinder intake on the order of 15-20 HP (dependent upon which carbs were used), the Edelbrock Victor single four manifold was still worth a couple of HP over the C8AX. That’s just modern intake design technology coming to the forefront.
By yalincoln - 13 Years Ago
http://forums.y-blocksforever.com/Uploads/Images/a489df70-3158-47f3-b85a-6df8.JPGhi ted, can you send me a copy of your findings, thanks, wayne. here's my intake-
yalincoln (5/14/2013)
hi ted, can you send me a copy of your findings, thanks, wayne. ....
Wayne. Do you still get the Y-Block Magazine? The iron head dual quad test results are in the latest issue (#115) while the aluminum head test results are coming out in the next issue (#116). Part III of that article will cover the results from the various air cleaner testing which will be in issue #117. I’ll be posting the condensed results of that testing here on the site after YBM issue #116 hits the stands. If you don’t get the YBM, just email me and I’ll send you a copy of the magazine article. The preferred email address to use is at www.eatonbalancing.com under contact information.
I'll add that the Edelbrock FM255 dual quad intake is a good manifold to use both in regards to its performance and its wider carb spacing which accommodates the use of more carburetor designs than the narrower carb spaced Edelbrock 257.
By Fairlane Mike - 13 Years Ago
Ted (3/6/2013)
Grizzly (3/6/2013)
A little off topic, what were the power figures on that 390, Y-Blocks and F.E.s, my favorite! (With an occassional 385 series thrown in!) Thanks, Mike.
By Archangel007 - 13 Years Ago
I hope John (Mummert) is reading this and is already in the midst of manufacturing a dual-quad intake for us Y-Blockers...BigGrin
Fairlane Mike (5/19/2013)
.....A little off topic, what were the power figures on that 390. Y-Blocks and F.E.s, my favorite! (With an occassional 385 series thrown in!) Thanks, Mike.
That 390 is 0.030” over with Edelbrock heads and runs on pump gas. With the Ford Sidewinder intake and a 750 Holley carb, 448 HP @ 5600, 426 TQ @ 4500. With the C8AX dual quad intake and a pair of 780 carbs, 465 HP @ 5700, 438 TQ @ 5500. And with the Edelbrock Victor 427 intake using a carb adapter and a 750 vacuum secondary Holley instead of a Dominator carb, 467 HP @ 5600, 447 TQ @ 5300. I'll add that fully porting the C8AX intake to match the heads cost some torque numbers but the horsepower numbers remained the same. The C8AX numbers above are the ported numbers.
Impressive figures; especially when you go from 2 carburetors to only ONE, and have slightly more power! A little more on topic, is the aluminum block project for Y s dead?
Fairlane Mike (6/1/2013)
Dont believe it was ever going to be aluminum, a cast iron one was in the works, he just needs confirmed interest to commit to making them.
I wonder if there would be interest in an aluminum one. Maybe with a raised deck, really thick all over to withstand nitro!
Fairlane Mike (6/2/2013)
Mike, if you check back on projected features of proposed new block, everything you need is covered but the aluminum one you dream of would suffer same probs as iron one, to produce these to be affordable to more than a handfull of racers is what stops them. I,m sure we can all dream up exotic parts but to manufacture such requres a lot more money than you couild imagine for little or no return! theres other folks here that manufacture parts and know the reality of it. Smile
Ditto on what Aussie Bill says. There would undoubtedly be some interest in an aluminum block but having it actually happen is where things get dicey. For one off or niche projects, it takes someone with a personal passion to get these off of the drawing boards.
For the proposed iron 4.125” bore capable cylinder wall blocks for the Y, Verne Schumann needs a commitment for 35 or so to make it financially feasible. He’s having difficulty getting that number of commitments but part of the problem has been in getting the word out to the masses. This is something that needs to hit the mainstream publications rather than just a few internet forum boards. Once Verne has enough people interested in blocks, then a finished block could be ready in as little as nine months.
If anyone is interested in one of the new iron Y blocks, just give Verne a call and get your name on the list. Here’s the link to the past thread giving some of the more pertinent details.
http://forums.y-blocksforever.com/Topic76753.aspx
By ian57tbird - 13 Years Ago
I couldn't commit to a block at this stage but it could be on the future wish list. Does anyone know close it is to the magic number for production?
ian57tbird (7/12/2013)
It’s been awhile since I’ve checked but at that time Verne was about half way there. But interest has been so slow that it may not happen. Part of the problem stems from prospective buyers for this block not stepping up to the plate and committing. These same people would like to first see the block in production and then purchase one once it is a proven piece. Verne is not asking for any money down but would like to have a rough idea what the interest level is with people putting their names down on the list as potential buyers. Verne already makes blocks for other applications so this is not a new venture for him.
John Mummert had similar ‘upfront interest’ issues on the Y heads to make it financially viable but he went ahead on his own and made it happen. Now that the heads are in production, sales have been steady with no let up insight. I’ve no doubt that once a big inch Y block is out there outperforming all other similar displacement engines, the same will also hold true for the new blocks. Rough math for a 427 cubed Y has it easily making over 600 HP on pump gas with a streetable compression ratio. And then an engine fully prepped for racing would be considerably higher than this. Race built Y’s are now crowding the 600 horsepower mark so that gives an idea of what a big cubic inch Y is potentially capable of.
The Y Block is a very heavy small block, and even at 400+ cubes it would still not be a light weight for its capacity. I was wondering why an aluminium block was not considered. I'm not sure if it is fare to draw comparisons, but as an example 427 ford blocks seem to be priced about 20% more in aluminium as compared to cast iron. I realize that it is only a small market and that both would not be realistic. Would there have been problems with reliability for people using then for high HP race applications or would it be to difficult to engineer for a small production.
ian57tbird (7/13/2013)
However, it has been proven to be able to take considerably more abuse than a stock small block. I wonder how the weight compares to an aftermarket iron small block that can handle 600+hp? That would be a more apples to apples comparison where higher power is concerned. For average street use, it is a heavy engine, though.
A quick look on the Summit site indicates 195lbs for a Ford and 175lbs for a Chevy Dart iron small block. Mummert indicates 155lbs for a bare Y block in his tech info.
I have only heard, no experience, that the average stock small block can handle 450hp at the most, at which point failure isn't really an if, but a when. Can anyone with real world experience confirm this?
TED, i agree with your remarks, the thought that mostly crosses my mind is the unknown with the remainder of the components for this new block assy. Bit like making a cake and not knowing the recipe, i think most curious or potentialy interested folks would like to see what components this new block will run with, i.e, all stock y block parts and obviously what we need to achieve its max capacity. I then think follks could weigh up the $ input to suit their commitment, just my thoughts! I would like a block!Smile
At a quick look the weights for the new blocks listed seem to be correct. I am wondering though if the weight listed for the Y Block is correct on the Mummert site. The Y Block is shorter but has a deck height almost the same as a BB Chev, they weigh in at 250lbs-260lbs and with the extended skirts on the Y I couldn't imagine it to be light. To put it in perspective even the new 302w high performance block weighs in at 163lbs and they are a tiny block in comparison. I don't want to say anything is wrong as I have never weighed one but it doesn't seem to add up when the long block is listed at 535lbs. I would have guessed closer to 255lbs than 155lbs. Does anyone else have thoughts or knowledge on this?
