Here’s a call for dual quad intakes for a dyno test
Posted By Ted 14 Years Ago
Rated 4.8 stars based on 3 votes.
Posted 13 Years Ago
ecode ragtop (1/7/2013)
Old Mic. I would like to see if there is any difference from the bird to car aircleaner, if you want to send it. I am bringing the 57 car e-code. Tom
Hi Tom,
I've done a comparison of two original '57 Ford dual quad air cleaner housings for the 'Bird and the passenger car. I'm understanding that there are numerous reproductions out there...
The housing bases are identical. The passenger car bottom base was simply rotated 180 degrees for use on the 'Bird.
The upper housings are 'related' to each other. The total height of the two upper housings are identical. However, the height dimension of the domes differ by one inch. Because the top section of the air cleaner housing was also rotated 180 degrees for use on the 'Bird, the stamping 'FRONT' on the top of the one dome was also rotated 180 degrees and is relocated to the position of the opposite dome from the passenger car unit.
Again, the total height of the passenger car and 'Bird air cleaner upper housings are the same. Because the domes on the 'Bird upper housing are one inch taller than the domes on the passenger car unit, the height of the side 'skirt' of the passenger car air cleaner housing is one inch taller than the 'skirt' on the 'Bird housing.
Related to the difference in the height of the side 'skirt' of the two upper housings, the original passenger car air cleaner element was taller than the 'Bird element.
Hope this helps! Smile
ecode ragtop
Posted 13 Years Ago
Supercharged (443 reputation)Supercharged (443 reputation)Supercharged (443 reputation)Supercharged (443 reputation)Supercharged (443 reputation)Supercharged (443 reputation)Supercharged (443 reputation)Supercharged (443 reputation)Supercharged (443 reputation)
Posts: 285, Visits: 3.4K
No short cuts, I understand the difference between the Bird and car E aircleaners, My thought was would there be any power difference, when they were both used on the same engine. Thanks Tom
  JUST A MIDNIGHT CRUISE DOWN THUNDER ROAD!!! TOM DRUMMOND MIDWEST DIRECTOR 57 FORD INTERNATIONAL
Posted 13 Years Ago
ecode ragtop (1/8/2013)
DUH! Sorry, Tom. I misunderstood your post. Blink
Regards,
ecode ragtop
Posted 13 Years Ago
Noshortcuts, Thanks for your help.Tom
Posted 13 Years Ago
I'd be interested in how a '57 'E' 'Bird air cleaner housing performed with a '57 'E' code passenger car filter element compared to any of the other air cleaner assemblies that Ford offered. It would seem that there would be less restriction to air flow to the carburetors...
Unfortunately the application information would not work on the little 'Birds because of hood clearance. Ermm
Oldmics
Posted 13 Years Ago
Posts: 710, Visits: 78.1K
And it may run worse due to the fact that more air flow could lean out the mixture.
Now if it was jetted up and had more air flow. Wink
Ted has lots of toys and options to play with - thats for sure.
By the way-good call on the Bird and passenger air filter comparisons  Smile
Oldmics
aussiebill
Posted 13 Years Ago
Posts: 1.8K, Visits: 11.4K
Ted (12/6/2012)
I’m in the process of gathering up carbs and intakes for an upcoming Ford Y-Block dual quad intake test.  The dual quad intakes on hand thus far for testing are the Edelbrock 255 and 257, 1956 Ford, 1957 Ford, Edmunds, and Fenton.  It would be a plus to see the Weiand and Offenhauser dual quad intakes also represented during this test.  Plans are to test some of the intakes with a variety of carbs including the new Demon Street Fighter carbs so there should be lots of information available once the test is concluded.
If anyone has a dual quad intake they would like to see tested during this dyno session, just get back with me and we can determine if this is something different or simply a duplicate of one that’s already on hand.  I could also use another 1956 FoMoCo intake as the one I have here has been heavily modified and would not be a good comparison to the stock ’57 model I have.  My contact information is at www.eatonbalancing.com .
TED, all of us y block effected, inflicted, fans sit by for your results, like an expectant father in the waiting room. I havent heard or seen there was an OFFY 2x4 and was eager to see pic  of one if anyone here has one. I do have local CAIN 2 x4 intake if interested but as not a regular item may be not be relevant in your test programme. It is open plane and suit high rpm use more than cruising i would think. Smile
 Down Under, Australia
aussiebill
Posted 13 Years Ago
Ted, these are 2 Cain intakes, basically the same except for minor casting changes, thought you guys might be interested to see unusual ones from over here.Smile
yyy
mctim64
Posted 13 Years Ago
Last Active: 5 Months Ago
Posts: 2.4K, Visits: 5.0K
Called Ted's shop today.  Wouldn't come to the phone, he was busy with the dyno.  Wonder what he found? BigGrinWink
Oldmics
Posted 13 Years Ago
Probably coundnt hear the phone with all that dual quad air flow rushing around. Tongue
It will be a good story when its told -fur shure!
Oldmics
