Y-BLOCK WEST SHOOTOUT - May 4-5
Posted By John Mummert 13 Years Ago
1
3
4
5
6
7
9
John Mummert
Posts: 916, Visits: 7.5K
Here are specs on the motor:
Bore: 3.82" Racetec 7.5 cc dome
Stroke: 3.75" Crower lightweight 42lbs
Rods: 6.30 Crower Maxi lite 300M
Heads: Mummert Angle milled version 56cc 1.96x1.52 valves ported
Cam: ISKY custom grind 260@.050 intake 254@.050 exhaust .590int .572int
Lifters: Trend tool steel ( these take 5/16 ball, important to know when ordering pushrods)
T Chain: New Mummert Nitrided 9 way roller set
T Cover: Interceptor marine cover, this was used in anticipation of new shortened timing cover that accepts factory Y block pump.. We figured one of Teds new water pumps would look real good on it.
Rockers: New Mummert 1.7 rollers
Pushrods: .080" wall Smith Bros. 8.08" effective length
Springs: Beehive
Valves: 1.96" Ferrea Hollow stem intakes 1.52" Mummert OEM valve reduced o.d.
Manifold: Mummert alum. ported
Carb: Proform 850
Oil Pump: NOS Modded to drop oil through cover do to the fact that oil filter will no longer fit.
Block: 1956 292 lightened 14lbs
Fuel: VP110 Oil: Kendall SuperD with Lucas break in supplement
Compression: Just over 13.0:1 static
As far as Dynamic goes we didn't worry about it too much seeing that its not a pump gas engine.
We may do some testing with some other fuels later that have proved themselves in the ATV world. But for now she just had to get running. Sunday was the last racing weekend before the SHOOTOUT.
Theres more weird stuff but this should get things rolling.
http://ford-y-block.com
Archangel007
Normally aspirated (27 reputation)Normally aspirated (27 reputation)Normally aspirated (27 reputation)Normally aspirated (27 reputation)Normally aspirated (27 reputation)Normally aspirated (27 reputation)Normally aspirated (27 reputation)Normally aspirated (27 reputation)Normally aspirated (27 reputation)
Posts: 17, Visits: 1.1K
Excellent specs John, well done!! BigGrin
What static and dynamc CR's did you end up with in the end??
"Not speeding Officer, qualifying!"
bird55
Posts: 1.1K, Visits: 58.8K
"Oil Pump: NOS Modded to drop oil through cover do to the fact that oil filter will no longer fit."
John, Sounds great! I'd like to hear more about your above statement AND how did you get 14 lbs out of the block? Not trying to steal any secrets just curious. BigGrin Any pics of the oiling setup??
John Mummert
I thought I'd throw in some pics of the engine and carhttp://forums.y-blocksforever.com/Uploads/Images/73cbec1c-231a-41e2-82d0-0fc7.JPG
Part of removing weight from the block included the filter mount so it had to be done this way.http://forums.y-blocksforever.com/Uploads/Images/a4ec2058-b190-408e-a17a-1739.JPG
More weight reduction in the pan rail
http://forums.y-blocksforever.com/Uploads/Images/60c553bd-639c-4c0c-b890-8a08.JPG
Finally assembled. Late Thursday
http://forums.y-blocksforever.com/Uploads/Images/f9375281-bd57-4122-8e32-fc8c.JPG
On the engine stand Thursday, on the dyno Friday, at the track Sunday.
John Mummert
More pictureshttp://forums.y-blocksforever.com/Uploads/Images/b0956105-3071-4448-838e-7391.JPG
Crower rods and Racetec Pistons
http://forums.y-blocksforever.com/Uploads/Images/7dff9f5d-c7b0-4b6e-aa6d-e926.JPG
More weight reduction from pushrod openings
http://forums.y-blocksforever.com/Uploads/Images/0b119662-9476-4791-b69c-4e44.JPG
Checking the new rockers for fitment. Steel shims added to protect rockers later.
John Mummert
More Eye candy
http://forums.y-blocksforever.com/Uploads/Images/cdf81dec-5e4f-4374-abe3-0f1b.JPG
http://forums.y-blocksforever.com/Uploads/Images/133613c7-e2ba-47fc-b3e9-164a.JPG
On the Dyno Friday
http://forums.y-blocksforever.com/Uploads/Images/f08c9b88-90ff-4b80-8e62-0371.JPG
In the car Saturday night. Off to Barona for the Antique Drags on Sunday
Last Active: 1 hour ago
Posts: 4.6K, Visits: 38.5K
Gee John all this time I thought you were fired up to help us support OUR passion for the Y. But look at you now! Wild looking coupe. Is that time for a 1/8 mile or does John H. now have the worlds fastest Y? Now, no more excuses, you guys HAVE to come to Columbus this year. Chuck
Just another thought, didn't one of our member show up with a car transporter one year? What if we could get a group of cars togather and trailer out. Combining cost would be a deal maker and the trip could be made with several drivers. Just a thought!
When I was a kid we had fast cars and hot rods in the midwest but it always seemed that the real action was on the west coast. Long summers make some of the difference but here I am again, 70 years old and all the action seems to be on the west coast AGAIN! Chuck
John Mummert
Chuck, definitely 1/8 mile. At present our 1/4 mile time would be 10.20 more or less. For now a weight reduction plan for the car and some new rear gears. Trying to get to 9.99 1/4 mile time.As to Columbus: That's up to John Hildebrand
http://forums.y-blocksforever.com/Uploads/Images/068d4429-caae-416a-92f4-c53c.JPG
John H, car owner and driver
People are always talking about their "Bucket List" today. I can't imagine an avid Y's guy that wouldn't have Columbus on that list. On the local tracks you find a few "I used to run one" and even the occasional Y's guy in arms but at Columbus "we are the world". Full immersion in the Y-block passion for 3 whole days. Surrounded my some of the best, and fastest, Y-Blockers in the world. I put it right up there with Bonneville! Chuck
3
4
5
6
7
9
