MarkMontereyBay
Visits: 3.8K
I read that in the past, 292 Y block cranks were modified to stroke 289 and 302 SBFs. Wondering about the history of that and if the forged version crankshaft in heavy trucks were used.
Have been looking around on the web and found that Jack Rousch used a 292 Yblock crank to stroke the anemic 302 79 Mustang Indy Pace Car.
57 Black Tbird 312/auto
Posts: 3.3K,
Visits: 238.8K
The part about Rousch using a 292 crank for a SBF stroker in 1979 is interesting. Would be interesting to know more about that?
Last Active: 4 days ago
The forged steel cranks were used for the SBF strokers back when the only stroker cranks available for Small Block Fords were steel billet. Once the aftermarket started making inexpensive cranks for the Small Block Ford, using a modified 292 truck crankshaft in the SBF just went away. I thought I heard somewhere that the Indy SBF's used a modified 292 truck crank back in the Sixties. Maybe someone can help to confirm this?
Visits: 323.8K
Ted: Maybe you were thinking of another project from Ford. When they were going to provide an Indy pace car ('64 Mustang maybe) with a 289 they decided they needed more inches for more speed. 302s weren't here yet, so they stroked a 289 with a 292 crank. I have an article somewhere in a Hot Rod magazine. Maybe I can find it.
aussiebill
Posts: 1.8K,
Visits: 11.4K
Hoosier Hurricane (11/23/2012)
Ted: Maybe you were thinking of another project from Ford. When they were going to provide an Indy pace car ('64 Mustang maybe) with a 289 they decided they needed more inches for more speed. 302s weren't here yet, so they stroked a 289 with a 292 crank. I have an article somewhere in a Hot Rod magazine. Maybe I can find it. Just another use for worn journal 272/292 cranks here in Australia in the 70,s was to modify and stroke them to use in speedboats with local 308 ci holden V8 engines, common in local cars, these were done by Ken Waggot of Waggot cams, i know because they brought any cranks i had over the years, i dont recall what capacity they increased to but were popular. Regards bill.
Posts: 3.3K,
Visits: 238.8K
This is interesting stuff.. especially so I can annoy some SBC afficonados with it. Anyway, a long shot thought, is it possible, that since the taller deck 351 SBFs, are from the same family of engines, as the 289-302s, could their cranks be modified to provide stroker cranks for Y-Blocks?
Visits: 323.8K
Paul: I looked into that, it would be too much of a project for me to undertake. The 351 crank has too short a front snout, too short on the back end and has no flange to mount the flywheel. Also, the center main thrust surfaces are .010 farther apart than the Y. The 351C has the same thrust width as the Y, but still has the length problems at both ends.
aussiebill
Posts: 1.8K,
Visits: 11.4K
PF Arcand (11/24/2012) This is interesting stuff.. especially so I can annoy some SBC afficonados with it. Anyway, a long shot thought, is it possible, that since the taller deck 351 SBFs, are from the same family of engines, as the 289-302s, could their cranks be modified to provide stroker cranks for Y-Blocks?I might be wrong but with all the theoreticall machining and adapting to make a used 351 crank into a substantial stroker, wouldnt it be cost effective to get new modlex crank or similar and know its right?
Last Active: 38 minutes ago
Visits: 39.4K
Aren't the Holdens the scrubs of down under? That means they used Y cranks to wake up scrubs? Wow! Chuck
LordMrFord
Visits: 9.3K
351's flange is just there where rear seal should be, so you have to to move flange (or replace to Y's flange) or machine the block's sealing area to get o-ring around the flange like SBF and make long adapter to flywheel. In both way it is very hard. Am I right?
 Hyvinkää, FI
