Y block clutch?
Posted By Trevwood 14 Years Ago
Trevwood
Posted 14 Years Ago
Normally aspirated (35 reputation)Normally aspirated (35 reputation)Normally aspirated (35 reputation)Normally aspirated (35 reputation)Normally aspirated (35 reputation)Normally aspirated (35 reputation)Normally aspirated (35 reputation)Normally aspirated (35 reputation)Normally aspirated (35 reputation)
Posts: 25, Visits: 245
Ok, I've got the toploader, it came with everything that came off the back of the 289.
I would think that I would have to use the Y block bell housing and fly wheel. Yes?
Which means the hole the box inserts into will have to be reamed out about 5mm so it will fit.
If not what do I use? Trev.
aussiebill
Posted 14 Years Ago
Posts: 1.8K, Visits: 11.4K
Trevwood (12/16/2012)
The opposite applies, remove gearbox front cover , hold in lathe and machine cover to fit hole in bellhousing. Smile
 Down Under, Australia
Trevwood
Posted 14 Years Ago
Ok, thanks Smile
