Opinions on best ZDDP additive
Posted By 58rancho 14 Years Ago
Posted 14 Years Ago
Last Active: 10 hours ago
Here’s a link to  a thread where some private testing that was done with various additives is discussed.  The author concludes that the oil film strength typically ends up being compromised when additives are added.
http://speedtalk.com/forum/viewtopic.php?f=1&t=31791&sid=92fcb0c59f66c826e8eeaf64e41d4896#p378825
Frankenstein57
Posted 14 Years Ago
Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)
Posts: 131, Visits: 891
This information was on a newsletter I received, the author does an analysis of approximately 20 oils. He states all the technical information to back his work. I've been using the shell rotella, he says he wouldn't walk across the street for it. Its a good read anyways
thanks, Mark
TDR57_Oil.pdf (421 views, 166.00 KB)
Posted 14 Years Ago
Interesting article. I'm glad I've chosen to use and stick with VR1 with no additives.
jrw429
Posted 14 Years Ago
Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)
Posts: 124, Visits: 4.3K
Here is a rebuttal to the www.speedtalk.com posting by the developer of ZDDPlus.
http://www.turbobuick.com/forums/threads/an-oil-test-that-shows-zddplus-may-not-help-richard-c-please-look.380082/page-2#post-3049361
I certainly am no tribologist, but he seems to be speaking from a place of knowledge.
Jim - Erie Colorado, 1957 Country Sedan
Posted 14 Years Ago
Posts: 3.7K, Visits: 498.2K
Frankenstein57 (11/23/2012)
The problem with this study (I have seen it before) is that the CI oils are probably out of production at this point of time. At 1100 or more PPM the Rotella still seems to be ok for flat tappet engines. It certainly has more PPM of ZDDP than any oil back in the 50's, '60's or somewhat later had.
I use Rotella in both of my YBlocks. One car (a 56 Bird 312) made a trip to Oregon and back (from NJ) at continual speeds of 65-70 MPH (2800 to 2850 RPM's) with no adverse effects. The other car, while not as extensively used, has made a number of shorter trips, again at the same speeds, with no adverse effects.
Now if I were racing a car, I would probably use a racing oil. Whether its true or not, I have heard that racing oil in a street car is not the answer as racing oil has a different set of additives than a street oil. True???????
Hutz 292
Posted 14 Years Ago
Posts: 228, Visits: 1.1K
I have been using Joe Gibbs racing oil in my Y since I built it and works great.  I called Joe Gibbs oil and talked to them and they created this oil specifically for flat tappet cams.  It is HR15W-50 racing oil.  It is formulated for older flat tappet engines and has high levels of zinc and phosperous and is recommended in applications that mey sit for a period of time.  This oil has worked great and I use it in sub zero temps here in North Dakota and has protected my engine very well.  They are very helpfull on the phone also. Here is the link to the oil I use inmy Y.
http://www.joegibbsracingoil.com/products/highperformance/hr3.html
Posted 14 Years Ago
Jim.  Thanks for posting that link.  It’s a good rebuttal to the prior link and as such, gives a different view of what’s required in the testing of the oils and additives for engines in general.
DANIEL TINDER
Posted 14 Years Ago
Last Active: 17 minutes ago
Posts: 1.8K, Visits: 154.5K
I still have a large stock of Rotella obtained before they reduced the zinc level. Will stick to my plan of alternating with low detergent racing oil.
6 VOLTS/POS. GRD. NW INDIANA
Craig Seyfried
Posted 14 Years Ago
Hitting on all eight cylinders (22 reputation)Hitting on all eight cylinders (22 reputation)Hitting on all eight cylinders (22 reputation)Hitting on all eight cylinders (22 reputation)Hitting on all eight cylinders (22 reputation)Hitting on all eight cylinders (22 reputation)Hitting on all eight cylinders (22 reputation)Hitting on all eight cylinders (22 reputation)Hitting on all eight cylinders (22 reputation)
Posts: 22, Visits: 218
I have been using Joe Gibbs Hot Rod Conventional 10-30 Motor oil for about 3 years. It has the proper amount of zinc for flat tappet camshafts and lifters and it has anti-corosion additives for vehicles that are in storage for extended periods of time. I believe that this oil coats all the internal parts of the engine and you never have a dry start up after extended periods of storage. My 56 Customline has about 45,000 original miles on the 272 and runs great and uses no oil. I do change the oil about every year and that oil has about 1,000 per year on it. My other Ford a 1960 Fairlane 500 has a 427 side oiler engine and I drag race it at Bandimere Speedway. Leonard Vahsholtz and I built the engine, and I run Joe Gibbs full synthetic oil 10-30. I used to run Brad Penn oil and after running the J.G. oil the oil pressure increased 5 lbs. The J.G. oil is pricey but how much does it cost to replace the cam and lifters?
        Sheriff of Mayberry, Craig Seyfried
