distributor and other upgrades
Posted By 55fordf100 14 Years Ago
Lord Gaga
Posted 13 Years Ago
Last Active: 10 Months Ago
Posts: 470, Visits: 183.3K
GREENBIRD56 (2/18/2013)
I just woke up to the realization that providing an additional (and parallel) path to ground from the negative post of the coil shouldn't do much to the controller module. All of those little electrons just wander home by the shortest route - and if that avoids the transistor temporarily - no big deal.....
You're right! I did a test on another car with the HEI conversion and "all those little electrons" did indeed seem to wander home by the shortest route. lol.
I've most of parts gathered now and am almost ready to make the change over. I thought of something else;
Are resistor secondary wires required? And if so, will Taylor spiral core wires suffice? THANKS
"FREE SAMPLE"
scott5560
Posted 13 Years Ago
Supercharged (77 reputation)Supercharged (77 reputation)Supercharged (77 reputation)Supercharged (77 reputation)Supercharged (77 reputation)Supercharged (77 reputation)Supercharged (77 reputation)Supercharged (77 reputation)Supercharged (77 reputation)
Posts: 66, Visits: 354
I just completed the HEI conversion to the stock distributor with Duraspark internals installed. Was a bit of work but seems to work good. Mounted the HEI module remotely on the firewall on a piece of aluminum to act as heat sink and lots of air flow. All pieces collected were $66 plus my time. Not driven yet but idle quality seems better and throttle response crisper. Set to 17 intial and mech advance 38 and total max with vacuum advance 50 same as old set-up. Waiting for roads to clear up and get back together from other mods.
Scott
Lord Gaga
Posted 13 Years Ago
Are resistor plug wires needed with the HEI conversion???????????
"FREE SAMPLE"
Posted 13 Years Ago
Only if you want to hear your radio. And they do actually work better on the street.
Lord Gaga
Posted 13 Years Ago
Thanks Frank. I've got solid core wires on it now and really don't want to go through the ordeal of installing those Taylor 8mm wires in the wire holders (1957) if I don't have to. And funny thing, I have no static AT ALL on the stock T&C radio with the solid cores. (The car has the factory condensers on the generator and voltage regulator, that's it) .
"FREE SAMPLE"
