Y-oh-Y
Visits: 931
Looking to buy a holley 2300 350cfm, manual choke carb for my 60 F100 292. I would like either a good useable or a core. I tightened mine 1/148309 of a turn too much, broke an ear. Thanks, Mark
46yblock
Visits: 7.8K
PM sent.
Posts: 3.3K,
Visits: 238.8K
If it was a good carb before the break, J.B. Weld It back together, using a flat surface under it.. Not much to lose!
Y-oh-Y
Visits: 931
PF Arcand (5/7/2012) If it was a good carb before the break, J.B. Weld It back together, using a flat surface under it.. Not much to lose!Thanks for the suggestion. I have it rigged with some rtv and a large, thick washer for now. With so many unknown things that can go wrong on this truck it bothers me to have something that I know is going to fail at the most murphy moment. Mark
Y-oh-Y
Visits: 931
Still looking for an inexpensive carb/core. Thanks
lyonroad
Visits: 3.1K
Y-OH-Y, I have a Holley 2 bbl carb that came with my '56 M100. You can have it if you want. I have no idea what CFM it is. Is there something I should look for to id it?
Mark
Grizzly
Visits: 1.9K
Y-OH-Y, Why don't you just buy a new carb base? These are available through either holley or are available as an aftermarket copy. About $50-60 if you look. Your not the first nor will you be the last to break a base. cheers Warren
Grizzly (Aussie Mainline)
lyonroad
Visits: 3.1K
Y-OH-Y, I did some checking and I think the carb I have is 500CFM.
Mark
Y-oh-Y
Visits: 931
Thank you for looking. Mark lyonroad (5/8/2012) Y-OH-Y, I did some checking and I think the carb I have is 500CFM.
Y-oh-Y
Visits: 931
I have been looking, most I have found have been closer to $100. I was hoping someone might have one on a shelf that could be had cheap. I have found american rebuilts for $180, and new for $240, just need to keep it running for now. Thanks, Mark Grizzly (5/8/2012)
