SMALL BLOCK IN A 56 ???????????
Posted By THRASHER 14 Years Ago
THRASHER
Posted 14 Years Ago
Turbocharged (51 reputation)Turbocharged (51 reputation)Turbocharged (51 reputation)Turbocharged (51 reputation)Turbocharged (51 reputation)Turbocharged (51 reputation)Turbocharged (51 reputation)Turbocharged (51 reputation)Turbocharged (51 reputation)
Posts: 47, Visits: 445
What headers will work if I put a 302 or 351 Windsor in my  Victoria ?
slumlord444
Posted 14 Years Ago
Last Active: 5 Months Ago
Posts: 1.2K, Visits: 137.8K
I can't understand why anyone would want to do that?
THRASHER
Posted 14 Years Ago
The Y-Block angines are WAY before my time. I know the small block Ford engines and parts are plenty.Just my opinion Tho
Posted 14 Years Ago
Posts: 4.6K, Visits: 39.4K
Not only are Y-Block parts easy to find there is a LOT of movement in the aftermarket for parts like Aluminum heads etc. Why pull one of the fifties best engines? My 2 cents. Chuck
PS I expect you will hear from D. Thrasher too! He's a real Y's guy. BigGrin
junkyardjeff
Posted 14 Years Ago
Posts: 813, Visits: 3.4K
You will need to keep your desire for latemodel motors quiet on here,I will have to admit my 55 has a 351 but will be going back to Y power when I get the money. If you dont need to have full length headers you might want to look into the 80s to 90s truck shorty headers.
speedpro56
Posted 14 Years Ago
Posts: 1.3K, Visits: 9.2K
I used to have a 390 HP FE in my 56 crown. It did run great but built my 312 back up and it,s in it now and no way the 390 would catch it, thanks to the new HP parts available for the Y-Block, The 390 rated at 335 hp and the Y-Block somewhere close to 430 to 450 hp and a LOT more fun. Plus the 390 lowered the value on the crown way too much, so a lesson was learned.Tongue
-Gary Burnette-
Posted 14 Years Ago
They're way before my time, too. But the fact of the matter is that it's essentially the same thing. If you can work on a small block, I guarantee you'll be alright with a Y Block. Actually, I'd say if you can work on an engine, you'll be fine with a Y.
I don't know if anyone here can help with your header question, but I will give you some things to think about.
Unless you go with a fuel injected, roller cammed 302, you'll be way down on torque. This means the car will be slower, less fun to drive, and get worse mileage - and you do a lot of work, or pay someone a good bit of money to do this. That just doesn't make sense.
If you're going to go through the hassle of a swap, make it count. I wouldn't consider anything smaller than a 351, but if I was forking out the dough or spending the time, I'd go big block, 390, 460, something like that. If I'm going through all that, I want to notice it.
I don't know your skill level or circumstances but a swap will involve a lot more than may appear at first glance, money and/or time and/or skill. Make sure it is something you can really take on so that it does not become another butchered, unfinished engine swap car for sale.
I really can't think of any reason to swap, other than for power. If you need 600+ streetable hp, I can understand. Otherwise, it just doesn't make sense; there's not a whole lot to gain.
Why are you considering a swap?
Posted 14 Years Ago
Back in the day (early Seventies) I did see some small block Fords in the mid Fifties Ford cars but I saw none with headers.  The 271HP 289 hi-po exhausts were used quite a bit on those conversions though.  Regarding performance, a local guy pulled his 312 from his chopped top ’56 Victoria and installed a ‘hopped up’ and bored 302 SBF.  His comments after doing this was he was very disappointed with the performance of the 302 versus that of the 312.  His observations centered around the low end grunt he saw with both engines.
Y block Billy
Posted 14 Years Ago
Posts: 1.6K, Visits: 5.2K
Homemade!
I take it this aint the Doug Thrasher because isn't he a Y guru anyway!
If your going to butcher up a 56 victoria with a small block, you may as well butcher it up with homemade headers.
Just my 2 cents.
55 Vicky & customline
Y block Billy
Posted 14 Years Ago
Forgot to ask, is that a 50's Victoria or a late 80's 90's victoria, they had small blocks anyway.
