SMALL BLOCK IN A 56 ???????????
Posted By THRASHER 14 Years Ago
drof75
Posted 14 Years Ago
Normally aspirated (35 reputation)Normally aspirated (35 reputation)Normally aspirated (35 reputation)Normally aspirated (35 reputation)Normally aspirated (35 reputation)Normally aspirated (35 reputation)Normally aspirated (35 reputation)Normally aspirated (35 reputation)Normally aspirated (35 reputation)
Posts: 35, Visits: 248
Go to this site http://www.57fordsforever.com/
You will all the info you need/
Buz Mills
Dallas, TX
MontyRay2
Posted 14 Years Ago
First Time Poster
Posts: 2, Visits: 249
Adding fuel to the fire...
First of all, if I had a nice original car with a Y-block, I would not change it. I own a 1957 Fairlane, a '56 Mercury convertible, and a Model A roadster, all with Y-block engines.
So, why would you replace a Y-block with a 302?
If you have no engine (or a bad Y-block) in your car, here are the reasons why you should consider a 302:
(1) Cost. To do a proper rebuild on a stock Y-block, you can spend between $2,000 and $3500. But you can buy a running 302 from mid-80's to 1992 from a Crown Victoria, Thunderbird, Town Car, etc. and have the bonus of an overdrive transmission to go with it. Generally speaking, if needed, you can put rings, bearings, and a timing chain in one of these engines and not spend a lot of money; because most of the engines have very little taper in the cylinder walls.
(2) Oil Leaks (in Y-block). Y-blocks are prone to oil leaks, particularly the rear main seals, whereas the 302 is usually oil-tight.
(3) Overheating. Less of a problem in a 302 than in a Y-block.
(4) Fuel Economy. If you use fuel injection on a 302, fuel economy and driveability are much improved. I drove my 1956 Mercury Monterey hardtop with a 302 HO (from an '87 Mark VII) to the 100th Anniversary of Ford Motor Company in 2003. With the cruise set at 80 and the a/c running full-blast, the car got 24 MPG on a used engine which had 140,000 miles (with EFI).
On the other hand...
I would NOT put a 302 in an original Crown Victoria, Sunliner, etc., because it would devalue the car. But, if you have a sedan or wagon, it doesn't seem to make much difference. However, I WILL put a Y-block in my '56 Chevy!
Posted 14 Years Ago
(1) True, a 302 is cheaper to rebuild. However, you're forgetting the cost to swap and get it all working. Whether that cost is your time or cash dollars, it can get expensive quickly. How expensive depends on your skills and capability. I do suppose that the right person could get it done for less, but most people could not. To keep it apples to apples, when a running Y could be found and installed, the 302 is not cheaper even if the Y still needs rings, bearings, and a timing chain.
(2) Y blocks prone to oil leaks?? Many Y blocks are now 48+ years old. Yes, worn out engines leak. 302s suffer the same fate. When they have been rebuilt and sealed correctly, they don't leak.
(3) Overheating?? I guess this could have the same cause as above, 48+ years old. Renew the cooling system and everything is good. A 302 will not magically unclog a radiator, repair rusted vanes on the pump impeller, or fix a generally poor design of the car in regard to cooling.
(4) This seems to be true in the trucks if and only if it is an 80s or newer roller cammed, fuel injected 302. Anything less and it is down on power and economy. Can't speak for the cars, but I think it's safe to assume that they would follow the same trend. So if you choose your 302 wisely, yes it can be better in the economy department, but most are just a waste of time and money. There is a guy on one of the Ford truck sites who is putting one of the later injected 302s into his truck but converted to a carb. It's not done yet, so I have no economy results.
A good, fresh Y just has torque that you can't get from a small block, at least not without a lot of modification. The only way to understand is to drive one. Sadly, most don't have that option, only the aforementioned worn out 48+ year old engines that, understandably, will be dogs, as any worn out (pic your favorite engine, enter here) will be. Plus, they sound a whole lot better.
yourcarparts
Posted 14 Years Ago
First Time Poster
First Time Poster (3 reputation)First Time Poster (3 reputation)First Time Poster (3 reputation)First Time Poster (3 reputation)First Time Poster (3 reputation)First Time Poster (3 reputation)First Time Poster (3 reputation)First Time Poster (3 reputation)First Time Poster (3 reputation)
Last Active: 14 Years Ago
Posts: 3, Visits: 1
Just to ad a bit, offered all of the regulars on this web page are prejudiced, but if your Victoria is relatively stock bodied (?) and not some insane personalized, it will be value more with a stock web page avoid than in some personalized kind... our mid Sixties Fords c/w Y-Blks, are suffering from a recovery of interest lately..
Car Mats
LordMrFord
Posted 14 Years Ago
Posts: 687, Visits: 9.3K
Why to worry about car value if you'll never gonna sell it?
Hyvinkää, FI
speedpro56
Posted 14 Years Ago
Posts: 1.3K, Visits: 9.2K
My take on that is the 60s y-blocks were somewhat down on power compared with the mid to late 50s. Give alittle more time as the hp parts become more widespread and available, that should change as gearheads start enjoying the extra power these engines produce. Not just 312s but 272s and 292s as well. Hot Rod magzines are talking about the sb chevy and LS series not being as exciting as they once were because there's so many transplants with them that things are slowly changing back to original and other makes now.
-Gary Burnette-
Posted 14 Years Ago
Last Active: 5 days ago
If your going to do that put in a Ch-----et. A buddy a my found a 2-Door 56 Ranch Wagon like that, drove it for 2 years, put on a set of American 5 spokes and sold it for $17K .
With indiffence to putting a Y-Block in anything....My personal preferance is a 302 GMC 6 preferably with a 12 port on it. If it won't fit-we won't quite.....................JD.
4thgen57
Posted 14 Years Ago
Hitting on all eight cylinders (11 reputation)Hitting on all eight cylinders (11 reputation)Hitting on all eight cylinders (11 reputation)Hitting on all eight cylinders (11 reputation)Hitting on all eight cylinders (11 reputation)Hitting on all eight cylinders (11 reputation)Hitting on all eight cylinders (11 reputation)Hitting on all eight cylinders (11 reputation)Hitting on all eight cylinders (11 reputation)
Posts: 11, Visits: 133
My 57 custom with a 272 Y sat for 20 years. When I first fired it up the rear main dumped 2 qts of oil on the ground. Shut it off, added oil and Ive been driving it for 13 years without leaking a drop!!!!
grandpas4dr56
Posted 14 Years Ago
Normally aspirated (29 reputation)Normally aspirated (29 reputation)Normally aspirated (29 reputation)Normally aspirated (29 reputation)Normally aspirated (29 reputation)Normally aspirated (29 reputation)Normally aspirated (29 reputation)Normally aspirated (29 reputation)Normally aspirated (29 reputation)
Posts: 29, Visits: 860
I was born durring Reagan's second term so i got the way before my time on the y blocks but as mentioned before if you know how to work on an engine and read you can work on a y block.
Dont judge me, you dont know my situation.
skygazer
Posted 14 Years Ago
Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)Supercharged (194 reputation)
Posts: 112, Visits: 1.5K
Fun quote:
I Drove my '55 t-bird to the doctors office with my Dad. 292 with milled 113 heads, mild Mummert cam, '57 intake, stock exhaust manifolds, 2" pipes & chambered mufflers. I have to admit that it sounds glorious!
I get out of the car, and a guy comes up to me... "what you got in there, a 428?"
What a riot! Sadly, I didn't have time to give the guy a history lesson.
