Removing Fordomatic
Posted By ALL AMERICAN RACER 14 Years Ago
yalincoln
Posted 13 Years Ago
Supercharged (573 reputation)Supercharged (573 reputation)Supercharged (573 reputation)Supercharged (573 reputation)Supercharged (573 reputation)Supercharged (573 reputation)Supercharged (573 reputation)Supercharged (573 reputation)Supercharged (573 reputation)
Posts: 378, Visits: 4.8K
i think he's trying to remove the trans without removeing the bellhouseing?
ALL AMERICAN RACER
Posted 13 Years Ago
Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)
Posts: 37, Visits: 101
gentlemen
it's a Cruiso-O-Matic not a Ford O Matic
http://www.fordification.com/tech/images/cruiseomatic10.jpg
Happy New Years!
Ford 292 & Fordomatic
removed from '64 F100
snowcone
Posted 14 Years Ago
Supercharged (364 reputation)Supercharged (364 reputation)Supercharged (364 reputation)Supercharged (364 reputation)Supercharged (364 reputation)Supercharged (364 reputation)Supercharged (364 reputation)Supercharged (364 reputation)Supercharged (364 reputation)
Posts: 169, Visits: 5.9K
aussiebill (12/11/2011)
MoonShadow (12/11/2011)
English not his first language perhaps? Chuck
Maybe not, but i just couldnt think that removing the bell housing bolts/trans boltscould be complicated enough torequire a question on it, unless he,s messing with us?More info on members backgrounds, age, etc can be a help in understanding situations.Smile Just a suggestion.
Strange one Bill
His other posts refer to more technical items such as manufacturing manifolds himself, and then he can't unbolt a transmission.
No punctuation in any posts either so it is difficult to read at times
Gary - 1958 Star Customline and 1940 Ford Deluxe Hotrod
aussiebill
Posted 14 Years Ago
Posts: 1.8K, Visits: 11.4K
Maybe not, but i just couldnt think that removing the  bell housing bolts/trans bolts could be complicated enough to require a question on it, unless he,s messing with us? More info on members backgrounds, age, etc can be a help in understanding situations.Smile Just a suggestion.
 Down Under, Australia
Posted 14 Years Ago
Posts: 4.6K, Visits: 38.5K
The Master Cylinder
Posted 14 Years Ago
Posts: 974, Visits: 6.2K
aussiebill (12/7/2011)
I CANT FOLLOW ANY OF THESE POSTS?Smile
Your not the only one... Wink
ALL AMERICAN RACER
Posted 14 Years Ago
aussie bill
it's about unbolting trans/bellhousing from engine
and then trans from bellhousing
so i can go racing with it
vrooom!
aussiebill
Posted 14 Years Ago
ALL AMERICAN RACER (12/7/2011)
johnny reb
trans to bellhousing bolts
are just regular
when unbolting bellhousing from engine
did run across 'last' bolt
bottom left ( sitting in driver's seat )
bolt has to be loosened through
access hole in bellhousing
ALL AMERICAN RACER
Posted 14 Years Ago
johnny reb
are just regular
CORRECTION: sure I had one last bolt to loosen
but there are TWO access holes on passenger
side of bellhousing to engine
took quick look and hole did line up with another bolt hole
think other bolt had fallen outSmile
jonnireb
Posted 14 Years Ago
Supercharged (114 reputation)Supercharged (114 reputation)Supercharged (114 reputation)Supercharged (114 reputation)Supercharged (114 reputation)Supercharged (114 reputation)Supercharged (114 reputation)Supercharged (114 reputation)Supercharged (114 reputation)
Posts: 107, Visits: 1.4K
Check n & see if the  bolt screws in from the front of belllhousing at the right(passenger) side.
55f100
West Monroe,La.
