            By ALL AMERICAN RACER - 14 Years Ago
            what's the best way to get transmission off
  292 engine?
  note:engine and tranny are on the ground
            By paul2748 - 14 Years Ago
            Unbolt it
  Do the flex plate bolts first.
            this tranny has screen on back of
  bellhousing
  looks like we got the racing version of trans
            By MoonShadow - 14 Years Ago
            Your sure its not just an air cooled version? Chuck
            By Moz - 14 Years Ago
            wow you mean to tell me theres a racing version of the ford o matic where do you get one
            that was a joke
  does have a screen on back of
  bellhousing right above transmission
  probably to let heat rise up and out
  from converter
  think they figured out later
  better to just keep dust out in there
  around converter seal and trans front seal
            trans is off of engine
  had to give up on taking
  trannny off of bellhousing because
  of bottom passenger side bolt inaccessible
  still don't know what's going on there
            By jonnireb - 14 Years Ago
            Check n & see if the  bolt screws in from the front of belllhousing at the right(passenger) side.
            johnny reb
  trans to bellhousing bolts
  are just regular
  when unbolting bellhousing from engine
  did run across 'last' bolt
  bottom left ( sitting in driver's seat )
  bolt has to be loosened through
  access hole in bellhousing
  CORRECTION: sure I had one last bolt to loosen
  but there are TWO access holes on passenger
  side of bellhousing to engine
  took quick look and hole did line up with another bolt hole
  think other bolt had fallen out
            By aussiebill - 14 Years Ago
             ALL AMERICAN RACER (12/7/2011)  johnny reb trans to bellhousing bolts  are just regular  when unbolting bellhousing from engine did run across 'last' bolt bottom left ( sitting in driver's seat ) bolt has to be loosened through access hole in bellhousingI CANT FOLLOW ANY OF THESE POSTS?
            aussie bill
  it's about unbolting trans/bellhousing from engine
  and then trans from bellhousing
  so i can go racing with it
  vrooom!
            aussiebill (12/7/2011)
  Your not the only one...
            English not his first language perhaps? Chuck
             MoonShadow (12/11/2011)  English not his first language perhaps? ChuckMaybe not, but i just couldnt think that removing the  bell housing bolts/trans bolts could be complicated enough to require a question on it, unless he,s messing with us? More info on members backgrounds, age, etc can be a help in understanding situations.  Just a suggestion.
            By snowcone - 14 Years Ago
            aussiebill (12/11/2011)
 MoonShadow (12/11/2011)  English not his first language perhaps? ChuckMaybe not, but i just couldnt think that removing the bell housing bolts/trans boltscould be complicated enough torequire a question on it, unless he,s messing with us?More info on members backgrounds, age, etc can be a help in understanding situations.   Just a suggestion.
  Strange one Bill
  His other posts refer to more technical items such as manufacturing manifolds himself, and then he can't unbolt a transmission.
  No punctuation in any posts either so it is difficult to read at times
            By ALL AMERICAN RACER - 13 Years Ago
            gentlemen
  it's a Cruiso-O-Matic not a Ford O Matic
  http://www.fordification.com/tech/images/cruiseomatic10.jpg
  Happy New Years!
            By yalincoln - 13 Years Ago
            i think he's trying to remove the trans without removeing the bellhouseing?
            By Y block Billy - 13 Years Ago
            My thoughts ecxactly YaLincoln, Is the starter removed?
            The picture you sent the link of, is from 64-74 V8 and 65 up I6, Are you sure you have a Y block? Y's ended in 64. (in the states anyway)
            va lincoln
  drivetrain (engine & tranny) was pulled out of pickup truck.
  i bought it still all bolted together and brought it home.
  i DID unbolt tranny from bellhousing first.
  why not? this thing weighs a ton.
  bellhousing is cast iron.
  tranny and tailshaft are cast iron.
  i got to move this around to clean it.
  yblock billy
  starter came off with accessories.
  carb, generator, dist, fuel pump and various lines.
  that's my bellhousing in attachment in every detail.
  screen on back, mounts, round access holes and odd shaped opening on drivers side.
  yep. it's a y block.C1TE heads.
  have a nice day!
             ALL AMERICAN RACER (1/3/2012)
  why not?
  Good way to screw up the torque converter and pump for two reasons "why not?".
            By aussiebill - 13 Years Ago
             ALL AMERICAN RACER (1/3/2012)  va lincoln drivetrain (engine & tranny) was pulled out of pickup truck. i bought it still all bolted together and brought it home. i DID unbolt tranny from bellhousing first. why not? this thing weighs a ton. bellhousing is cast iron. tranny and tailshaft are cast iron. have a nice day!I have never seen a cast iron tailshaft?  i,m guessing you,re a young guy and new to cars etc, it would help us help to understand you a little better if you didnt mind giving somebackground, thanks
            By kevink1955 - 13 Years Ago
            Now Your gona make me look, I have a Ford O Matic in storage that (I think) has a cast iron tailshaft. It's sitting next to an FMX with an alum tail shaft that is much shorter than the Ford O tail. One day they are going to be combined into an FMX O Matic for my 56 Fairlane.
             kevink1955 (1/3/2012)  Now Your gona make me look, I have a Ford O Matic in storage that (I think) has a cast iron tailshaft. It's sitting next to an FMX with an alum tail shaft that is much shorter than the Ford O tail. One day they are going to be combined into an FMX O Matic for my 56 Fairlane.Kev, you are mixing up tail shafts with g.box extension housings. the tail shaft connects the trans to the diff!!
            You guys are right, the Ford O Matic I have in storage does have an alum tail shaft, it's so covered in crud I had to use a magnet to verify it was not alum. It's also about 7 inches longer than the FMX standing next to it. Bill, In the US the rear most part of the trans that accepts the slip yoke and speedo gear is commonly called the tailshaft housing, do you call it something different?
            kevink1955 (1/4/2012)
 You guys are right, the Ford O Matic I have in storage does have an alum tail shaft, it's so covered in crud I had to use a magnet to verify it was not alum. It's also about 7 inches longer than the FMX standing next to it. Bill, In the US the rear most part of the trans that accepts the slip yoke and speedo gear is commonly called the tailshaft housing, do you call it something different?  Kev, i was thinking that later, yes, if i remember rightly you call our "tail shaft", the "drive shaft" from what i see here. And you refer to the rear trans housing as the tailshaft? but was referred to as "tailshaft" and not tailshaft "housing" in 1st and 2nd replies, strange when the housing is not a shaft! but got the general idea.
            It's great no matter where we call home that the "Y" brings us all together and we manage to understand each other. I bet that puting the timing gears on with the marks 12 pins apart on the drivers side could be a problem when you sit in the Right seat to drive
