New blocks?
Posted By John Mummert 15 Years Ago
aussiebill
Posted 14 Years Ago
Posts: 1.8K, Visits: 11.4K
SkylinerRon (1/1/2012)
Probably the biggest part of the market for a "new"  Y-block would be 55-57 T-bird resto's.
Y's seem to be getting somewhat more desirable for street rods too.
Toss in racers and some trucks also.
With a new block & crank you could build a brand new Y-block. (w/o any Ford parts).
Ron.
I personally think the actual cost of these proposed new blocks  once known will determine how many everyday buyers are out there. I would certainly like one.Smile
 Down Under, Australia
grovedawg
Posted 14 Years Ago
Last Active: 14 Years Ago
Posts: 246, Visits: 622
If it was reasonably priced I buy one as well.
Heber City, UT (15 mins outside of Park City- basically it's in the mountains)
55 Effie
John Mummert
Posted 14 Years Ago
Posts: 919, Visits: 7.5K
I talked to Verne Schumann today about the new blocks. He is the person who is looking at doing them. He said the project looks good to go. He will be submitting a more complete description in a release in Y-Block Mag soon. But for now:
Nodular iron block
4.125" bore
.875" lifter bore with oil galley for hydraulic lifters
Solid roller, flat-tappet, hydraulic roller, hydraulic flat-tappet compatible
Raised cam shaft for larger stroke
Cross bolted steel main caps machined to oil top and bottom
Accepts Y-Block crankshafts or replacement Y-Block strokers
292 Main bearing dimension
Other features to follow.
Retail price 3900.00 50 orders required to make it go.
Something to ad to your wish list.
http://ford-y-block.com
aussiebill
Posted 14 Years Ago
John Mummert (1/9/2012)
Nodular iron block
4.125" bore
John, thanks for info and putting block in perpesctive for the potential buyers, may be quite a block, and obviously suit the racers out there, keeping in mind the other parts required to get it going and intense head work or your alloy heads. I.m not knocking it but earlier mentioned there were guys saying they wanted one but  i could see the whole package costing more than most average guys would pay, i would want one but would like to see some proposals re parts, ratio,s and estimated hp range.etc. i know i,m jumping the gun here but  just thinking aloud.Smile
aussiebill
Posted 14 Years Ago
4.125" bore
Was wondering what you thought re 4 1/8" proposed bores, there would,nt be much water between cylinders, so would that rule it ouBigGrint as street driven engine , or could it cool enough.?
Posted 14 Years Ago
Production engines with siamesed bores (no coolant between cylinders) are pretty common. SO I'd think it will work for the street if necessary.
So is this $3900 required before any R&D or after it's all figured out, and a good prototype has been made, then he wants $3900?
aussiebill
Posted 14 Years Ago
charliemccraney (1/9/2012)
Charlie, i guess we should aim questions at verne, but john mentioned Verne would mention it in next y block mag. I,m happy and interested in this block but just trying to say that there are a few yelling its great, lets go etc but reality check will be final costs, components etc and think 50 blocks as 1st run would be optimistic. but lets hope it can work.Smile
Posted 14 Years Ago
4.125” bore and a 4.125” stroke.  441 cubic inches.  Hmm. Makes for a very, very, torquey street engine.  And with a roller camshaft, the possibilities are way out there.  And a hydraulic roller at that.
Glen Henderson
Posted 14 Years Ago
Posts: 1.4K, Visits: 7.5K
Sounds very interesting, if it is fully machined at that price, sounds reasonable. I know for a fact, that you can spend $1,000 or more for machine work on a 292. Just like with John's heads, when you just look at the price, ouch. But when you step back and look at the cost of a set of good iron heads, $1400/$1800 for ported posted G's, the price looks reasonable. One other thought that I have for what it is worth, is that we can't compare the cost of low volume y block parts to more common sbf or scrub parts that are most likely made off shore.
Glen Henderson
Freedom is not Free
Letohatchee, AL
Don Woodruff
Posted 14 Years Ago
Posts: 190, Visits: 1.6K
OK next up is a crankshaft.
The most you can get is a 3.62 with a 2 inch journal (a bit more with undersize.
