It might be too early to mention this but there is a possibility of new nodular iron blocks for the Y. Lots of improvements including drop in lifters, 4" bore and maybe even longer strokes.
NO, it isn't me thinking about doing this and it is definitely not a certainty at this point.
Just something to get y'all thinking and I must say it would be cool!
By ALL AMERICAN RACER - 15 Years Ago
aren't we forgetting something?
DID THEY STRAIGHTEN OUT OIL PASSAGES?
what's nodular iron?
It's the next logical step! Imagine that, a true 400+ci Y!
you've been reading this
impartial article on Y blocks, haven't you?
http://www.eatonbalancing.com/blog/2009/07/05/the-ford-y-block-engine/
little 292 will be just fine
By Grizzly - 15 Years Ago
Americanracer, Nodular iron is an iron alloy that is stronger than cast iron. First used by ford for cranks and high strength castings for improvements in strength and weight. FE blocks were nodular iron and saw an improvement in strength and weight over the Y block (there were also improvements in casting technology) Cheers Warren
By aussiebill - 15 Years Ago
Grizzly (11/8/2011)
Americanracer, Nodular iron is an iron alloy that is stronger than cast iron. First used by ford for cranks and high strength castings for improvements in strength and weight. FE blocks were nodular iron and saw an improvement in strength and weight over the Y block (there were also improvements in casting technology) Cheers Warren And we cant forget the nodular iron 9" diff centers that made them reliable in big HP cars.
John, So many questions, do you have more details? Will there be a weight advantage? Will the block use currently available parts? How will bore spacing issues with cracking be sorted? Does dropin lifters mean "Roller"? Will the blocks be cost effective for street use? Thanks Warren
Bill, Yes! look for the "N" Cheers Warren
By Hollow Head - 15 Years Ago
Just wondering. Why not go to all alloy block with removable cylinders to save the weight ? Ok, not so cost effective....
By JPotter57 - 15 Years Ago
292 might be fine, but 400+ sounds a heap better, much easier to make big power that way. Even with the smaller bore though, the drop in lifter bores would be a huge plus. Can you imagine an all new roller cam in the Y? Nice. Would be cool if the price would be at or less than a Genesis FE block too.
By RB - 15 Years Ago
John make sure they increase the cam to crank centerline so increasing the stroke is more achievable
I meant to say center to center cam/crank distance
The 4.6 and 5.4 is already an alloy block of Y design, change too many things and you may as well just put a modern block in there.
By Ivan M. Thoen - 15 Years Ago
If this is a wish list, four bolt mains and an o-ring rear crank seal.
There is little set in stone at this point. In fact it might not even happen. These are some of the ideas I heard from the person thinking about the project:
Lifter Bores would be .875" so they would accept FE solid or roller lifters
Cross bolted mains ala 427
Raised cam to allow longer stroke
4.00" bore minimum, perhaps 4.125"
Side oiler.
Nodular iron casting.
The block would probably be heavier than stock unless areas can be found to reduce thickness because there would be MORE material around the mains. Material might be removed around the valley area to offset some extra material in the main bearing area.
A one piece rear seal would be nice be no existing Y crank would fit.
The existing bore centers are the same as SBF, Windsor and M motors so 4.125" bore should be possible without trouble.
Of course the 292/312 main bore argument will still be had as will 1/2" vs 7/16" head bolts.
Way too soon to discuss price.
Re the 4.00 inch bore minimum: Does it mean that at least a 4" bore must be used or that it will be able top support a 4" bore at least. The latter will be best because limiting it to a 4" only crowd will not make a good seller. Making it an option for the guy who is having difficutly finding a good 312 block or simply doesn't want to mess with a used 292 block will be ideal. Re the mains and head bolts: To one not at all experienced with casting, it seems that it will be easy to satisfy both demands with a difference in machining alone. Is that not the case? Surely it will affect the cost slightly to offer both options. But here again, limiting it to a performance only crowd does not seem wise. Is there any other crank which is similar enough to allow the correct external appearance, with the cast timing cover and all yet allowing for cheap aftermarket crank options. If so, perhaps the block could also be machined to allow for the use of this crank instead of a stock Y crank.
By suede57ford - 15 Years Ago
I really like the idea and would try one. It sure would make this y-block ultimate performance easier. The more modifications the better. All I really would be concerned about is that it still looks like a Y-block on the outside, so it looks like it belongs in my '57 Ford.
By PF Arcand - 15 Years Ago
Due to costs, trials & tribulations, likely well exceeding what John Mummert (& others previously) expereinced with the Heads project, I doubt this will ever happen. How would it ever pay for itself ?. But if I'm wrong, one way to save weight would be to reintoduce the discontinued aluminum Timing Covers...
By Ted - 15 Years Ago
Paul. Passion will drive many projects where the financials are not feasible. My own preferences for design changes on a new block offering would include the following standard features: >4” bore with the capability to go out to a 4.125” bore. >292 main bearing sizes. >Cross-bolt mains for the main journal caps. Add billet caps as an option if they are not standard. >Oil filter pad made into the block (no plate required) which would also help with the main cap cross-bolting at the #4 main. >Additional motor mount pads in front of the originals like the ’65 and up FE’s. This would allow the engines to go into later model Fairlanes, Mustangs, Galaxies, and pickups/trucks using FE motor mounts assuming that the firewall clearance with the rear located distributors is not a problem. >Additional bellhousing bolt pattern(s) on back of block to accommodate other Ford family bellhousing patterns (ie. FE and/.or SBF). >The block is still designed to accommodate original production crankshafts, cylinder heads, timing covers, oil pans, etc. >Raised camshaft would be nice but that involves a specialized timing set. With the raised camshaft is also the change in valve train geometry which may be a potential issue when the cylinder heads are installed. With a 4.125” bore and the current camshaft to crank centerline, the cubic inch capability would be 428 with a currently doable 4.00” stroke so it’s difficult to justify raising the camshaft. >That’s a definite yes for the 0.875” lifter bores. And here is a past thread on the ‘new block’ topic. http://forums.y-blocksforever.com/Topic12901-11-1.aspx
Y block Billy (11/9/2011) The 4.6 and 5.4 is already an alloy block of Y design, change too many things and you may as well just put a modern block in there.
I see where you're going. What we need is a stacked port conversion for 4.6 and 5.4.
By LordMrFord - 15 Years Ago
charliemccraney (11/11/2011)
Y block Billy (11/9/2011) The 4.6 and 5.4 is already an alloy block of Y design, change too many things and you may as well just put a modern block in there.I see where you're going. What we need is a stacked port conversion for 4.6 and 5.4.
Haha! So John can only make new heads for Mod motor and call it the new Y.
Then we can call SBC with center bolt valve cover conversion also the Y-Block.
LordMrFord (11/11/2011) Then we can call SBC with center bolt valve cover conversion also the Y-Block.
Only if it's a two bolt style, and a small block wouldn't work. It'll have to be an LS.
By Don Woodruff - 15 Years Ago
Lets look at setting it up for 351 W/C crankshaft,camshaft dimensions. We could then use SBF componets and stroker cranks. Dampners would become more available. Would need some Fab for T birds tho. Hope I live long enough.
It is difficult to say where this will lead. Just like the head, it seems like there is a blank sheet of paper but when you get into it there are many dimensions and locations that can't be changed.
One problem we need to face is the lack of replacement 312 main bearings. They are getting expensive and Clevite has discontinued them for all practical purposes. FM still makes them but jobber price is around 240.00. Has anyone tried the Ebay imports?
If we go to a 351 crank then the flywheel won't fit and as Don pointed out the T-Bird damper won't fit.
Raising the cam will be complicated by the possibility that the cam gear might hit inside the timing cover.
The more special parts required, the fewer number of people will choose to use the block
RE the 351 crank, is it close enough that the difference could be only in the machining of the block? Even with a new flywheel, a 351 crank could be a cheaper option than possibly finding a 312 crank to stroke and I suspect that many people who go for this block will be stroking. And I'd bet that many going the stroker route will opt for a billet flywheel or prefer an sfi aproved flywheel, in which case there will be no savings on the flywheel. On many of the engines I've taken apart, the stock flywheels were no good, visible cracks, and replacement is necessarry. What's the issue with the bird damper? If it won't work, doesn't it mean that the other dampers won't? I can see potential issues with the front crank seal, though. I realize that a foreign crank won't be for everybody, but if it can be optional, it would be neat. I don't think a small block cam is a good idea. We'll loose the firing order.
John, all of those niggling little details. The cam gear hitting the timing cover is a problem. All of the messy little details. Cam bearings retaining the Y firing order are available, that should not be a problem. A 3.75 inch stroke would be very desireable. I believe 3.85 stroker cranks are available. The T bird dampner is much longer, pullies set farther from the block, than the passenger/truck dampner. Possibly pullys could be grafted on the front of the dampner. This would be quite a project, but a needed one.
Don Woodruff (11/11/2011) The T bird dampner is much longer, pullies set farther from the block, than the passenger/truck dampner. Possibly pullys could be grafted on the front of the dampner.
I'm obviously not understanding something. The bird damper is longer than the truck/ car dampers yet fits on a stock Y which all have the same crank snout/timing cover seal dimensions. So if a car/truck damper will work somehow with a 351 crank, then how will the bird damper not work?
Charlie: The crank snout on the 351 is much shorter than a Y, so neither passenger nor Bird damper is a direct fit. Also, the back end of the 351 crank is shorter and has no flywheel flange. To rework a 351 crank would probably cost as much or more than a stroker 312 crank.
Ok, so plain and simply a unique damper will be required regardless of Bird or car/truck.
A 3.75" 351 crank can be had for under $600.00. 3.75" is on the very fringe of what is possible with a stock Y crank and very likely means custom crank or maybe several 312 cranks before finding one that will work. So $600 plus a readily available flywheel, $300 and a special damper, $400ish, and at least a custom crank timing gear, $150ish, is that not a better price than a custom crank or possibly several stock cranks to achieve the same goal?? It will be for me, but I know some of you have 312 cranks stashed away as if you picked them from trees. I pretty well consider the flywheel, rods, pistons, and damper a non issue since most people considering something like this will be getting them anyway and whether using a Y crank or another crank. They'll pretty well be as expensive.
If the same casting cannot be machined differently to accommodate both cranks or it simply adds too much to the cost, then a 351 crank isn't a good idea. 2 castings obviously would not be feasible.
With that, I will drop the foreign crank idea.
Charlie the accesories,water pump, generator, power steering pump are placed farther forward in T bird applications. Thus the drive pullies on the crank are placed farther forward. All of these problems could be bypassed by grafting some semblence of the 351 W front of the block configuration if it would not offend the purist too much. accomadation would have to be made for the front engine mount. Man every rock turned over uncovers the effects of 50+ years of evolution. I do not know of any other crankshaft from any mfg that could be used.
I most likely want ever have one of these if they do come about, but my two cents if you want a 351 then it makes sense to get a 351, if you want a y block then get a yblock. I understand where you are coming from Charlie, but I would much rather see someone come up with an affordable aftermarket crank for the yblock. Just my opinion.
Glen Henderson (11/12/2011) I understand where you are coming from Charlie, but I would much rather see someone come up with an affordable aftermarket crank for the yblock. Just my opinion.
Actually, I had a whole paragraph about just that written but then I realized it might hijack the thread.
By pegleg - 15 Years Ago
John Mummert (11/11/2011) If we go to a 351 crank then the flywheel won't fit and as Don pointed out the T-Bird damper won't fit. Since we can purchase aftermarket Windsor cranks for peanuts that would be a thought. How about purchase them from Scat/Coast with the rearmain and flange UNMACHINED, the machine the flange to Y block dimensions. Those cranks are available now with 351 bearing sizes in anything from 2.87 through 4" + strokes. Don't know what the snout size is but sleeving the damper or reducing the front crank diameter is not a major issue.
Lot of questions here and may be a little off topic but, When the molds for the Y's ended up in Argentina, did they ever get drop in lifters? Are the molds for the blocks/cranks still kicking around there? If there is enough demand, why can't someone be found to make a run of cranks that won't break the bank? The Argie's did a good job of switching the heads to small block style and I recently watched some videos on youtube of some nice argie cars with blowers and all fitted to y's. Maybe we have to go kicking around Argentina for a while and bring back some of the tooling or have them make some batches and send them here, it may be cheaper than having the stuff made here. Just throwing out other options here!
I thought I read some where some of the late Argentine blocks had the drop in lifters, cannot remember where, possibly the Y block mag.
By glrbird - 15 Years Ago
In 1971, the engine was modified to accept a new-style cylinder head with a different valve arrangement (E-I-E-I-E-I-E-I versus E-I-I-E-E-I-I-E), new intake and exhaust manifolds and was renamed Fase II (Phase II). In this form, the 292 Fase II continued into the eighties in the F-100, and was also used in the Argentine Ford Fairlane (built from 1969-1982, and based heavily on the U.S. 1968 model). All Argentine versions of this engine feature a cast crankshaft rather than the forged example that equipped US heavy duty engines. The 292 version was also produced by Ford of Brazil and equipped the Brazilian LTD starting in 1969. Both the 272 and 292 engines were replaced on Brazilian cars by the 302 engine starting on 1976 model year. There should some parts left down there.
I guess I caused some confusion with the T-Bird damper comment. I only mentioned them because they are so unusual and expensive.
I've already done research on import cranks and there are no forgings in China with a long enough snout to make a Y-Block crank.We did have Crower make a crank using a SB scrub forging that has enough material for the flywheel flange but the snout is short. Also, big $$$$.
Have done some research on having cranks cast and machined over here. This is a good possibility if I get caught up on heads, intakes and timing covers. Good luck with that.
I considered having cranks cast off shore but knew they would be in the Lincoln Nebraska speed shop about 10 minutes after I got them. Not interested in doing their R&D for them.
Back to the block: I would like to see rocker oiling similar to Ted's modification with the 3 oil holes connected together. Ted's idea of doing away with the oil filter adapter seems like good idea. Multiple bellhousing bolt patterns would be good but likely only blocks like the FE with the started above the crank centerline could be made to work. Maybe the Mod Motor? Not sure where the starter is located.
By yalincoln - 15 Years Ago
does anyone know if they stayed with the standard bolt pattern on the phase II, and what tranny's did they use?
John, the Moldex cranks that Ted is using are pretty pieces, but big $$$$. I think a good cast crank would be a winner with 2" rod journals and longer strock. I know how hard it is to find a 312 crank anymore and too have it worked over like Ted did mine, is pretty expensive also. By the way I shipped your valve covers today.
Like Pat, I like the idea of a 4" bore block cross bolted mains, and improved oiling, but like Glen, I'll probably never be able to own one. For my money, I would rather see an Eagle or at least Scat quality crank, to enable me to build a 340+ inch stroker for less money than it currently costs. A forged crank would be nice, but not necessary. Now, given an unlimited amount of money to build the ultimate Y, make mine aluminum with billet caps, and some of those oh so cool aluminum South American Weslake heads with Mummert's expertise laid on `em.
By feadam - 15 Years Ago
whos looking at doing block
feadam (11/29/2011) whos looking at doing blockYou,re all dreamin! The shear $ cost would be prohibitive to all but a few top end racers and hence the development and short run costs would stop it there. Looking for gigantic street HP is confusing things here which apply mostly to race car applications. Theres plenty of reliable strong street combo,s allready available through JM and others with facts and figures available on this forum. And the argy blocks had normal mushroom lifters, only known block that had drop in lifters was the werby? block and thats another part of history. Anyhow thats my Xmas thoughts.
By davis - 15 Years Ago
yeah, what he said^^.
no way a new block. neat history on the argentine blocks and weslake heads too.
The block project is an unusual situation that would not be done to make a profit. I can't explain the details but there are other reasons to do it. So it is still possible. Is it necessary? I don't know, but some will want one anyway.
I don't try to use logic when it comes to classic cars. If you want to be practical go down to the dealer and buy a new FORD. 20K will buy you a new one with better brakes, handling and creature comfort than we could put in a 50 year car with a huge budget. Add to that a warranty.
We own old cars because we want to, not because it makes sense.
aussiebill (11/29/2011)
feadam (11/29/2011) whos looking at doing block You,re all dreamin! The shear $ cost would be prohibitive to all but a few top end racers and hence the development and short run costs would stop it there. Looking for gigantic street HP is confusing things here which apply mostly to race car applications. Theres plenty of reliable strong street combo,s allready available through JM and others with facts and figures available on this forum. And the argy blocks had normal mushroom lifters, only known block that had drop in lifters was the werby? block and thats another part of history. Anyhow thats my Xmas thoughts.  Didn't someone say that about the new heads for y blocks Mind, if new blocks were to become available I hope the wait isn't as long Cheers Warren
John Mummert (11/29/2011)
I don't try to use logic when it comes to classic cars. . . .
I totally agree John. If we didnt love these old hulks, we'd all be driving a prius or some other disposable car.
John Mummert (11/29/2011) I don't try to use logic when it comes to classic cars. If you want to be practical go down to the dealer and buy a new FORD. 20K will buy you a new one with better brakes, handling and creature comfort than we could put in a 50 year car with a huge budget. Add to that a warranty.
I don't exactly agree. I'm not trying to compete with a focus, or camry, or even a Mustang. I want to embarrass Ferraris and Lamborghinis and the like, or at least give them a good competition. I can do that for much less than the 6 figure sum required for most of those, and less maintenance cost. It ain't gonna be cheap, but it ain't gonna be 6 figures either. Granted I can achieve the same goal with a new Mustang and some mods, but older vehicles have far more style, trucks in particular. What's more embarrassing to the Ferrari or Lamborghini owner? To be beaten by a 2012 Mustang, or a 1961 Ford?
John Mummert (11/29/2011) The block project is an unusual situation that would not be done to make a profit. I can't explain the details but there are other reasons to do it. So it is still possible. Is it necessary? I don't know, but some will want one anyway. I don't try to use logic when it comes to classic cars. If you want to be practical go down to the dealer and buy a new FORD. 20K will buy you a new one with better brakes, handling and creature comfort than we could put in a 50 year car with a huge budget. Add to that a warranty.
We own old cars because we want to, not because it makes sense.I agree, for less than 30K you can have a 2012 Mustang GT that will out perform 95% of the best hot rods. I want one but the satisfaction of driving a old car is nostalga, the need to be unique. I truly enjoy that.
By grovedawg - 15 Years Ago
Back to the blocks.... I'd love to see this progress. I'll patiently wait and watch this progress, and if it becomes a reality and is feasible then I would seriously consider using one.
History is shaped by the people who keep pushing when others say it can't be done.
By rick55 - 15 Years Ago
Just maybe the emphasis of this site would change to all engines of Y block configuration if a new block was produced. If you want more power/cubic inches and a few modern touches you could always use an FE block cos that technically is a Y Block and I believe C$&v are now making a Y Block. For me the beauty of these engines is that they are nostalgic and overlooked and there is nothing like some uninformed clod trying to figure out what engine it is.
Here in Oz there is a slowly developing interest in our engines because they are different. If they were modernized they would lose their uniqueness. Even the sound of them turning over is unique.
I realize some people would not agree with me but I have immense love and trust in these old engines. My car has always got me there and back with reliability. Why fix what ain't broke?
The efforts of John Mummert in manufacturing aluminum heads is commendable and satisfies the needs of people who just have to have "G" heads which are getting scarce. But in essence, the heads don't change the engines designation as a "Y BLOCK".
For me I will just stick with what I have.
I trust I haven't upset too many of you, after all it is the season of good cheer. I hope you get what you wished for for Christmas and stat safe.
Regards
I don't agree. The design of an FE block is deep skirted like a Y Block but it is not a Y Block. There are so many unique things that make the Y Block. The same logic could be used to say that a small block Chevy technically is a small block Ford, (the blocks are similar enough), but you're not going to convince a Ford or Chevy guy of that. And if we had used that logic, the Y Block would not have been developed as far as it has been. There will always be easier options but they are not as rewarding.
It took about 10 years to get new heads for the Y-Block & a new 4 Bbl intake manifold, & that only happened due to the interest & perserverence of John Mummert. We should be thankful just for that! A new block? It seems highly unlikely to ever happen. Our favorite engine is a nostalgia item. A new & substantially altered engine wouldn't be the same. As already mentioned, it would seem more realistic to try to get replacement parts made, such as 312 Cranks, main bearings for the same & quality cam bearings & lifters, along with other parts. Where would anyone get parts for a new semi "orphan" engine?.. A bigger Ford nostalgia engine already exists. The F.E. dates from 1958. As for the need for more power, recent developments have resulted in substantial increases, thanks largely to Mummert & Ted Eaton. Just take a look at the recent 337 cu. in street engine test, that Mummet issued, apparently for automatic tranmission cars. 293 H.P. & 420 Ft Lbs torque at under 5500 RPM! That's better than one of G.M.s upper SBC crate engines, which is rated at 385/385. For street users, which is likely most of us, how much power is realistic, especially from a nostalgia engine?..
Thanks for the response Charlie. I agree with your sentiments entirely and was merely playing the devil's advocate.
I am in awe of the advances made by Ted Eaton, John Mummert and others, but this has all been done with the Y BLOCK. Their results bear testament to how good the basic design was. I would be reluctant to jump on the band wagon of replacing the basic block with later technology. This to me is the essence of the beast.
Regards
I will be in line to buy a new block. The short block is the foundation upon which the engine is built. What we are left with is a diminishing supply of 50 year old pieces. John Mummert has stepped up to build modernized heads and intake, A modernized block using readily available componets that cosmetically resembles the orginal equipment will be fine. There at least 3 manufacturers of FE blocks out there, only one of which resembles the original in appearance. They are all selling. John has trouble keeping up with demand for his products. Those that insist on original parts should hope the aftermarket produces new parts. More of the old parts will be left for them. Don W.
Agree with others, a Y block is unique, Keep a Y block, bigger bores is great, bigger cam etc, but keep it to fit conventional Y block parts. I drive a 50 year old car because i want the feel of a 50 year old car, you want it to feel new, jump in something new. Merry Christmas!
Correction; In my post of Dec. 20th it states that Mummert's recent proposed crate engine, tested at 293 H.P. & 420 lb ft. It should have read, just slightly short of "393" H.P..
PF Arcand (12/20/2011) It took about 10 years to get new heads for the Y-Block Paul. Actually took considerably less than that once Rick's half hearted effort flopped. More like 4 years.
By PF Arcand - 14 Years Ago
Frank: Didn't Dove give it a look before Speedsmith/Rick ?
By SkylinerRon - 14 Years Ago
Probably the biggest part of the market for a "new" Y-block would be 55-57 T-bird resto's. Y's seem to be getting somewhat more desirable for street rods too. Toss in racers and some trucks also. With a new block & crank you could build a brand new Y-block. (w/o any Ford parts). Ron.
By pegleg - 14 Years Ago
Paul, They did. I think Ted has more info on that effort.
By aussiebill - 14 Years Ago
SkylinerRon (1/1/2012)
Probably the biggest part of the market for a "new" Y-block would be 55-57 T-bird resto's. Y's seem to be getting somewhat more desirable for street rods too. Toss in racers and some trucks also. With a new block & crank you could build a brand new Y-block. (w/o any Ford parts). Ron. I personally think the actual cost of these proposed new blocks once known will determine how many everyday buyers are out there. I would certainly like one.
By grovedawg - 14 Years Ago
If it was reasonably priced I buy one as well.
By John Mummert - 14 Years Ago
I talked to Verne Schumann today about the new blocks. He is the person who is looking at doing them. He said the project looks good to go. He will be submitting a more complete description in a release in Y-Block Mag soon. But for now:
Nodular iron block
4.125" bore
.875" lifter bore with oil galley for hydraulic lifters
Solid roller, flat-tappet, hydraulic roller, hydraulic flat-tappet compatible
Raised cam shaft for larger stroke
Cross bolted steel main caps machined to oil top and bottom
Accepts Y-Block crankshafts or replacement Y-Block strokers
292 Main bearing dimension
Other features to follow.
Retail price 3900.00 50 orders required to make it go.
Something to ad to your wish list.
John Mummert (1/9/2012) I talked to Verne Schumann today about the new blocks. He is the person who is looking at doing them. He said the project looks good to go. He will be submitting a more complete description in a release in Y-Block Mag soon. But for now: Nodular iron block 4.125" bore .875" lifter bore with oil galley for hydraulic lifters Solid roller, flat-tappet, hydraulic roller, hydraulic flat-tappet compatible Raised cam shaft for larger stroke Cross bolted steel main caps machined to oil top and bottom Accepts Y-Block crankshafts or replacement Y-Block strokers 292 Main bearing dimension Other features to follow. Retail price 3900.00 50 orders required to make it go. Something to ad to your wish list.
John, thanks for info and putting block in perpesctive for the potential buyers, may be quite a block, and obviously suit the racers out there, keeping in mind the other parts required to get it going and intense head work or your alloy heads. I.m not knocking it but earlier mentioned there were guys saying they wanted one but i could see the whole package costing more than most average guys would pay, i would want one but would like to see some proposals re parts, ratio,s and estimated hp range.etc. i know i,m jumping the gun here but just thinking aloud.
John Mummert (1/9/2012) ...... 4.125" bore Was wondering what you thought re 4 1/8" proposed bores, there would,nt be much water between cylinders, so would that rule it ou t as street driven engine , or could it cool enough.?
Production engines with siamesed bores (no coolant between cylinders) are pretty common. SO I'd think it will work for the street if necessary.
So is this $3900 required before any R&D or after it's all figured out, and a good prototype has been made, then he wants $3900?
charliemccraney (1/9/2012) Production engines with siamesed bores (no coolant between cylinders) are pretty common. SO I'd think it will work for the street if necessary.
So is this $3900 required before any R&D or after it's all figured out, and a good prototype has been made, then he wants $3900?Charlie, i guess we should aim questions at verne, but john mentioned Verne would mention it in next y block mag. I,m happy and interested in this block but just trying to say that there are a few yelling its great, lets go etc but reality check will be final costs, components etc and think 50 blocks as 1st run would be optimistic. but lets hope it can work.
By Ted - 14 Years Ago
4.125” bore and a 4.125” stroke. 441 cubic inches. Hmm. Makes for a very, very, torquey street engine. And with a roller camshaft, the possibilities are way out there. And a hydraulic roller at that.
Sounds very interesting, if it is fully machined at that price, sounds reasonable. I know for a fact, that you can spend $1,000 or more for machine work on a 292. Just like with John's heads, when you just look at the price, ouch. But when you step back and look at the cost of a set of good iron heads, $1400/$1800 for ported posted G's, the price looks reasonable. One other thought that I have for what it is worth, is that we can't compare the cost of low volume y block parts to more common sbf or scrub parts that are most likely made off shore.
By Don Woodruff - 14 Years Ago
OK next up is a crankshaft. The most you can get is a 3.62 with a 2 inch journal (a bit more with undersize.
Don Woodruff (1/10/2012)
OK next up is a crankshaft. The most you can get is a 3.62 with a 2 inch journal (a bit more with undersize. Don, i think there was mention of moving the cam tunnel higher to allow bigger strokes, thus different timing set?
He's saying that 3.62 is about the biggest you can get with a stock crank so aftermarket cranks which allow for even larger strokes will be the next logical step.
charliemccraney (1/10/2012) He's saying that 3.62 is about the biggest you can get with a stock crank so aftermarket cranks which allow for even larger strokes will be the next logical step.yes charlie, thats part of the package of additional parts that will become necessary toward building one of these, would be nice?
By Grizzly - 14 Years Ago
Charlie & Bill, With the increase in bore size a standard 312 (3.44")crank will net 368cu, an offset ground 3.61" will see 385, using a setup similar to Ted's EMC engine at 4.00" will net 427. Getting a range of cams that will take advantage of the roller lifters and the higher ramp rates is the priority. Why have the capacity and not fill it? cheers Warren
Cranks are in short supply in the US. Vern Schumann is a very sharp old time Ford racer going back at least to the Y blocks. I remember he was credited with coming up with a way to "post" heads to prevent failures. The guy has all kinds of knowledge. We are very lucky to have John, Vern and Ted carrying the Y banner. I am sure he will come up with a very good design.
By jonnireb - 14 Years Ago
Mighty right.
By Daniel Jessup - 14 Years Ago
I will chime in with Don about the Y block guys that have invested all of the time and $ into research and development. I don't think we say enough about what these guys do when it comes to hands-on engine work and testing or plunking down the money to get things done. They put their money where their mouth is. Most of us know John and Ted through the website here, but I don't think I've ever heard of Verne on the internet anywhere. I can vouch for him too. The last set of Y block parts I ordered from him were right on the money - especially those cam bearings...just loved that outer groove in the center bearing. Durabond set IIRC. The timing set I got from him was quality too.
By Missouri Mike - 14 Years Ago
I was talking to Verne yesterday. He made mention that he was about 80% along on the new block, planned to have something ready by Oct or Nov '12, the $3900 price was what he was shooting for as a retail number, and casually mentioned 575 HP. And yes, he knows y blocks. He raced them roundy round and quarter mile starting in the 50's into the 60's. He told me he had been a Ford sponsored racer and apparently now has some very significant manufacturing contacts. Missouri Mike
Missouri Mike (1/11/2012)
I was talking to Verne yesterday. He made mention that he was about 80% along on the new block, planned to have something ready by Oct or Nov '12, the $3900 price was what he was shooting for as a retail number, and casually mentioned 575 HP. And yes, he knows y blocks. He raced them roundy round and quarter mile starting in the 50's into the 60's. He told me he had been a Ford sponsored racer and apparently now has some very significant manufacturing contacts. Missouri Mike Thanks mike for the update.
Missouri Mike (1/11/2012) I was talking to Verne yesterday. He made mention that he was about 80% along on the new block.... and casually mentioned 575 HP.
575 HP.... You've piqued my interest.
By ScottY - 14 Years Ago
I'm Gobsmacked!!!!!!!!!!!!! All I can say is "You Bloody Ripper!!!!!!!!!!!!" And "Y" NOT! Would sure wake that Gasser up Cusso! lol
By feadam - 14 Years Ago
are they taking deposits for blocks or not to that point yet?
I talked to Verne Schumann recently and he sounded a little surprised that he hasn't had many inquiries. I think a lot of people still don't believe this could happen. I think it will if some interest is shown.
I don't know if he wants actual deposits but some interest would help.
Verne can be reached at 563-381-2416 CST Iowa
John, Do you have an email address for him. Thanks Warren
I do not have an E mail addy, best I can do is a fax # 563-381-2409 DW
Thanks Don,
Verne Schumann needs additional verbal commitments on the new production Ford Y cylinder blocks. At this point he needs enough potential buyers to make this project viable as the current list of potential buyers is too short to make this happen. If you think you might be interested in a brand new 4.125” bore capable block, then give him a call and get your name on the list. No upfront money is required. His contact information is: Schumann’s Sales and Service
227 W Mayne St., Box 128
Blue Grass,
Iowa 52776
Phone: 563 – 381 – 2416.
Here are links to previous discussions regarding the blocks. http://forums.y-blocksforever.com/Topic65514-5-1.aspx http://forums.y-blocksforever.com/Topic73248-6-1.aspx http://forums.y-blocksforever.com/Topic12901-11-1.aspx Let me add “Let’s not get hung up on crankshafts”. Those will come if the blocks happen. In the meantime, the proposed block can still use factory cranks as 292 main bearing sizing is being used in the new block design.
Ted, thanks for the update. Unfortunately there are people out there who will never hear about the new block unless the word is spread in other places. Maybe the HAMB, if it hasn't been already.
By my calcs an offset ground 312 crank would net 386 c.i.
3.75" stroke= 401, 4" stroke = 427.6 c.i.
John. Thanks for the tip. I’ve posted this over on the HAMB site. Maybe that will help to get the word out just a bit further.
By jrw429 - 14 Years Ago
John Mummert (11/12/2012) 4" stroke = 427.6 c.i.
wow, then if you do a new set of heads we could have a 427 SOHC Y-block!
By ejstith - 14 Years Ago
John Mummert (11/8/2011) It might be too early to mention this but there is a possibility of new nodular iron blocks for the Y. Lots of improvements including drop in lifters, 4" bore and maybe even longer strokes.
Just something to get y'all thinking and I must say it would be cool!p
Man, would that be the coolest thing or what?? !! I have always wondered if anyone had ever tried to weld up the lifter holes & re-bore them to take drop in lifters...
