New blocks?
Posted By John Mummert 15 Years Ago
John Mummert
Posted 15 Years Ago
Posts: 919, Visits: 7.5K
It might be too early to mention this but there is a possibility of new nodular iron blocks for the Y. Lots of improvements including drop in lifters, 4" bore and maybe even longer strokes.
NO, it isn't me thinking about doing this and it is definitely not a certainty at this point.
Just something to get y'all thinking and I must say it would be cool!
http://ford-y-block.com
ALL AMERICAN RACER
Posted 15 Years Ago
Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)Normally aspirated (37 reputation)
Last Active: 14 Years Ago
Posts: 37, Visits: 101
aren't we forgetting something?
DID THEY STRAIGHTEN OUT OIL PASSAGES?
what's nodular iron?
Ford 292 & Fordomatic
removed from '64 F100
Posted 15 Years Ago
It's the next logical step! Imagine that, a true 400+ci Y!
ALL AMERICAN RACER
Posted 15 Years Ago
you've been reading this
impartial article on Y blocks, haven't you?
http://www.eatonbalancing.com/blog/2009/07/05/the-ford-y-block-engine/
little 292 will be just fine
Grizzly
Posted 15 Years Ago
Posts: 281, Visits: 1.9K
Americanracer,
Nodular iron is an iron alloy that is stronger than cast iron. First used by ford for cranks and high strength castings for improvements in strength and weight. FE blocks were nodular iron and saw an improvement in strength and weight over the Y block (there were also improvements in casting technology)
Cheers
Warren
http://forums.y-blocksforever.com/Uploads/Images/41f30774-424d-428d-9c7a-e351.jpg Grizzly (Aussie Mainline)
aussiebill
Posted 15 Years Ago
Posts: 1.8K, Visits: 11.4K
Grizzly (11/8/2011)
Americanracer,
Cheers
Warren
And we cant forget the nodular iron 9" diff centers that made them reliable in big HP cars.Smile
 Down Under, Australia
Grizzly
Posted 15 Years Ago
John,
So many questions, do you have more details?
Will there be a weight advantage?
Will the block use currently available parts?
How will bore spacing issues with cracking be sorted?
Does dropin lifters mean "Roller"?
Will the blocks be cost effective for street use?
Warren
Grizzly
Posted 15 Years Ago
Bill,
Yes! look for the "N"
Cheers
Warren
Hollow Head
Posted 15 Years Ago
Posts: 1.0K, Visits: 3.8K
Just wondering. Why not go to all alloy block with removable cylinders to save the weight BigGrin? Ok, not so cost effective....
JPotter57
Posted 15 Years Ago
Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)Supercharged (176 reputation)
Posts: 144, Visits: 1.2K
292 might be fine, but 400+ sounds a heap better, much easier to make big power that way. Even with the smaller bore though, the drop in lifter bores would be a huge plus. Can you imagine an all new roller cam in the Y? Nice. Would be cool if the price would be at or less than a Genesis FE block too.
James Potter
`57 Fords International
`57 Custom Tudor
`57 Fords International National Director
Pass Christian, MS (near Gulfport/Biloxi)
