Finnish Y-block Drag Racer
Posted By Hollow Head 14 Years Ago
Hollow Head
Posted 14 Years Ago
Posts: 1.0K, Visits: 3.8K
So, Jyrki (yfreak57) is now first ever certified Y-block drag racer here in Finland. He drove five license runs at 5th round of Finnish Championship series race at Motopark track. Runs were not extremely good, thus we had problems with trans brake in all runs. Overflow cans water hose got loose on one run and sprayed Jyrkis helmet and he had to lift. On one run, little amount of oil came up from dipstick tube and he lifted on that one too. Then he hassled badly one run after he had to wait over half an hour at the water pot because former driver oiled 660 ft of another track and they had to clean it. At the last run we raised boost pressure a little to 14 psi and due that or that earlier mentioned water problem and overheating, we blowed the head gasket and number one filled up with water. We found that out right when we tried to go to run number 6, but water was dripping from under exhaust manifold. Then we pulled the plug from #1 and thats it. Race was over, because we went there to race, not to wrench Tongue. We had no spares along and you know, here in Finland it's little hard to find Y-block gaskets from another drivers w00t.  But, we made a new Finnish Y-block Record by 11.818s and 187 km/h. Car really has potential to lot better times, but we are still learning... And, what is good also, we got the car certified to 7,50 and slower times! Here is some pics anyway.
mctim64
Posted 14 Years Ago
Posts: 2.4K, Visits: 5.0K
Nice pix!  Sorry you had trouble but that's racing. Tongue  Nice patch on the jacket. Wink
LordMrFord
Posted 14 Years Ago
Posts: 687, Visits: 9.3K
Hollow Head (8/21/2011)
I thought you left there to get drunk.
Hyvinkää, FI
Hollow Head
Posted 14 Years Ago
Simo, absolutely not for that, but we did that too BigGrin. I'm still having a headache w00t...
Hollow Head
Posted 14 Years Ago
More pix from Pro Photographer...
I think that last one is the ONE that Jyrki screwed by making burn out without towers permission Smile. Starting line judge didn't like about that w00t! It can happen to rookies.
glrbird
Posted 14 Years Ago
Last Active: 5 Months Ago
Posts: 616, Visits: 7.1K
Here in the states we call that "new car blues". Happens to everyone. Do you have some type of pan evacuation system on the engine? That will help stop pushing the dip stick tube out, and help seal the rings. You guys have come a long way and will get everything sorted out i am sure. Great looking car.
Gary Ryan San Antonio.TX.
Hollow Head
Posted 14 Years Ago
Found some water... w00t.
Could be better open up the other side too?
Glen Henderson
Posted 14 Years Ago
Posts: 1.4K, Visits: 7.5K
I have never seen intake valves that look those.
Glen Henderson
Freedom is not Free
Letohatchee, AL
Posted 14 Years Ago
Last Active: 18 minutes ago
Posts: 3.7K, Visits: 322.9K
Seppo:
Yes, I would recommend you look at the other side.  Did you run the engine through a few heat/cool cycles and retorque the heads before hitting it with boost?  You should do that.
Posted 14 Years Ago
Seppo, Just out of curiosity, what are you using for head bolts/studs?
