                Visits: 38.4K
                I wonder if we should have a "how to do it" section on the forum for articles like head posting etc. I know there is a tech section off the home page but people don't seem to find it. Just a thought Jim? Chuck in NH
			    Y's guys rule! Looking for McCullouch VS57 brackets and parts. Also looking for 28 Chrysler series 72 parts. And early Hemi parts.
            Hollow Head
                Posts: 1.0K,
                Visits: 3.8K
                Ted (8/23/2011)
 I’m assuming you are running posted heads?  Definitely switch the head bolts to a true grade eight bolt though.  You might consider upgrading to a ½” head bolt also so that the head bolt torque values can be increased.  Keep at it as you’ll eventually get the ‘new car’ bugs worked out.      Heads are C0AE, so they are posted. Question about ARP studs: What stud would be long enough to reach up to oil pan attaching level from main bolt holes and even ½ to 1 inch above the oil pan level to bolt main girdle between the block and the oil pan?
			      Seppo from Järvenpää, Finland www.hollowheads.net (just click the hole in the head to proceed)
                Posts: 7.5K,
                Visits: 205.8K
                Hollow Head (8/24/2011)  .......Question about ARP studs: What stud would be long enough to reach up to oil pan attaching level from main bolt holes and even ½ to 1 inch above the oil pan level to bolt main girdle between the block and the oil pan?For the main support girdles, I’m using studs and hardware found in the Granger catalog.  They are coarse threaded on both ends.  On these, there’s enough thread to torque the main caps down without the girdle in place and then with the proper spacers, lay the girdle on top of those nuts and then another set of nuts to hold the girdle in place.  Double nutted when the assembly is in place.  When cutting out the girdle, if you’ll leave some material in the girdle on the engines right side, you’ll incorporate some windage control into the girdle.  Here’s a picture.
			      Lorena, Texas  (South of Waco)
            Hollow Head
                Posts: 1.0K,
                Visits: 3.8K
                Jep, we are planning very similar set up, exept that we are going to fab new main caps tall enough to touch that girdle and then just bolt all together.
            grovedawg
                Visits: 622
                Ted that girdle looks very nice.  What thickness of metal are you using?
			    Heber City, UT (15 mins outside of Park City- basically it's in the mountains)
  55 Effie
                Posts: 7.5K,
                Visits: 205.8K
                grovedawg (8/30/2011)  Ted that girdle looks very nice. What thickness of metal are you using?3/8” thick.
            Hollow Head
                Posts: 1.0K,
                Visits: 3.8K
                Ted, do you happen to have any girdles to sell or is it possible to make more of those. You sure have the drawings and it might be even cheaper to buy from you than discover the wheel again and manufacture those here in Finland   .
            Hollow Head
                Posts: 1.0K,
                Visits: 3.8K
                10 minutes of license runs from GoPro helmet cam   . http://www.youtube.com/watch?v=OhJsFw-4LLo
            aussiebill
                Posts: 1.8K,
                Visits: 11.4K
                Hollow Head (8/31/2011)
 Ted, do you happen to have any girdles to sell or is it possible to make more of those. You sure have the drawings and it might be even cheaper to buy from you than discover the wheel again and manufacture those here in Finland   .  Ted, i,d be interested in 1 if anything comes of seppo,s inquirey. regards bill.
			       AussieBill            YYYY    Forever Y Block     YYYY  Down Under, Australia
            57FordPU
                Visits: 73.6K
                Ted, I would also like to piggy back on these requests for a girdle.  If we are going to step up the speed on these Y-Blocks (especially turbocharged), we need to do everything possible to hold them together for a WOT three mile ride.
  BurnsRacing981@gmail.com
