Visits: 7.8K
...and how about a guess as to what it is?
Visits: 498.2K
Carb mounted on the head???
Visits: 4.4K
Yep, it is pretty obvious it is only half an engine. Where's the other four cylinders?
Regards
Rick - West Australia Do Y Blocks Downunder run upside down? Gravity Sucks!!
Posts: 2.0K,
Visits: 131.2K
Uh...let me see...  ...is that a Y fuel pump mounted upside down?
Visits: 349
hemi plug wires
RED
Visits: 3.8K
Willys/Knight (Jeep) Sleeve Valve engine?
57 Black Tbird 312/auto
Should be under the hood of the truck rather than in the bed, on a tire.
Posts: 1.8K,
Visits: 11.4K
46yblock (7/28/2011)
...and how about a guess as to what it is? Willys jeep? or continental engine.
Visits: 6.0K
That's probably a Nash.
Paul, Boonville,MO
Visits: 7.8K
Paul, I think you are technically right! It is a 58-59 Rambler American 195.6 engine. It seemed so strange and was so cheap I couldnt pass. No intake manifold!?
