Cylinder head comparison on the 312
Posted By Ted 15 Years Ago
Posted 15 Years Ago
Last Active: 6 days ago
Posts: 7.5K, Visits: 206.0K
Here are the ‘very summarized’ results of how sixteen different pairs of heads recently performed on the 312 dyno mule.  A pair of the ECZ-C’s and C1TE-D’s was a before and after milling comparison which  jumps the number of published tests to eighteen.  The same carburetor, intake, headers, timing, and valve lash was used in all these tests.  The camshaft is a Crower Monarch with 0.450” lift, 238°@0.050”, ground on 110° lobe centers, and installed 2° advanced or 108° intake lobe centerline.    The intake manifold is an unported Mummert dual plane paired up with a 750cfm vacuum secondary Holley sitting atop a 2” oval opening carb spacer.  1.6:1 roller rockers are being used for all tests.  Total ignition timing is 38° BTDC.  For these particular test results, the headers are used with mufflers which helps to keep this particular information set comparable.  The degree or amount of porting when performed on the heads is not listed on this particular chart.
Cylinder Head
Peak HP
Peak Torque
Comp Ratio
Ported
Mummert Aluminum
377
368
9.8:1
Yes
Mummert Aluminum
354
356
9.8:1
No
113
333
350
9.2:1
Yes
G
328
350
9.4:1
Yes
G
324
349
10.6:1
Yes
G
304
337
9.6:1
Yes
G
302
337
9.2:1
Yes
G - stock
290
344
9.2:1
No
471
296
332
8.3:1
Yes
ECZ-C – stock
288
336
9.0:1
No
ECZ-C – stock
280
335
8.6:1
No
ECZ-C – stock
273
330
8.1:1
No
ECZ-C       after milling
295
339
9.0:1
Yes
ECZ-C       before milling
290
334
8.4:1
Yes
C1TE-D    after milling
297
337
9.0:1
Yes
C1TE-D    before milling
295
335
8.4:1
Yes
COAE-A - stock
283
332
8.7:1
No
COAE-A w/larger valves
273
328
8.9:1
No
A special thanks goes out to those of you that donated heads, shipping, and/or funds to make all this happen.  For those of you that sent funds without any name(s) on the envelopes, an extra thanks also.  This testing has generated a plethora of information which is being put together for a series of articles for the Y-Block Magazine.
