idaho211
Visits: 11.6K
Ted, Thank you for running all of those tests on the different heads. One comparison I see is the Stock G head was 5HP less and 9 ft/lbs more than a stock C1TE head? I thought the C1TE heads would be alot worse. I am in the process of changing out my C1TE heads for a pair of G heads on my 272. Now I am wondering if it will make much of a difference in horse power/torque. What do you think?
Pete 55Tbird
Visits: 93.2K
Ted Once again a great job. Thank you for all your time and effort. Seeing the results of the cylinder head test and having facts and hard data as opposed to myth, urban ledgends and speculation makes me smile. Since I remember the day when the Yblock G heads were just the ones with the larger intake valves already in them and not the object of almost magical regard this helps to put it into perspective. In the case of the G heads maybe you really do not get what you pay for after all. So don`t believe everything you hear. Pete
Y block Billy
Posts: 1.6K,
Visits: 5.2K
Great job as always Ted! Great info.
mctim64
Posts: 2.4K,
Visits: 5.0K
Thanks for the testing Ted! You do us all a great service.  But I think I will benefit even more when I can bolt those "G" heads on my engine at Bonneville. I plan on making two full runs with the C1TE heads that are on the engine now (very similar to the ones tested) then swap for the old "Brick" heads and we can see what that change makes on the course.  I also have a Mummert intake to run, but I have a ported "B" on the engine now and will run that with the "G" heads to get an apples to apples test. As long as my +.060 292 bottom end will hold up and the truck handles good I should be able to make quite a # of runs to compare set ups. Next year hopefully some CNC ported Mummert heads, I think that is what I will need for a D/PP reacord.
skygazer
Visits: 1.5K
Awesome info, Ted! Thanks for the amazing work putting this together. It's interesting that the high-compression stock C heads weren't that far off in power from the stock G heads! It's easy for me to lust for the "best" heads, but the G head valves are only slightly larger and the chamber volume is only slightly smaller. These numbers prove that the difference really isn't that great, from a practical point of view. You may have just saved me some bucks! Thanks again! Now, if I could only stop lusting for that tri-power...
YellowWing
Visits: 1.8K
Thank you Ted ! Wish I had this info when I built my engine, very happy with the way it runs but for the amount it cost to go to G heads I probably would have just done work to my C's.
1956 Fairlane Victoria (ORREO)
Overlooking Beautiful Rimrock AZ
yalincoln
Visits: 4.9K
Great work, thank you very much, and thanks to all who helped out.
Glen Henderson
Posts: 1.4K,
Visits: 7.5K
And the ported 113 made more power that the G with less compression.
Glen Henderson
Freedom is not Free
Letohatchee, AL
Some interesting data. In most cases, an increase in compression or port/valve work increase power except in the case of the larger valve C0AE's and the 10.6:1 G's, which performed well but weren't at the top of the G list. It looks like reasonable street performance can be had with virtually any head. Are you going to score these using the Engine Masters format?
46yblock
Visits: 7.8K
There is some amazing information in that chart! A thankyou isnt sufficient, but "Thankyou!" Ted.
