Last Active: 6 days ago
Posts: 7.5K,
dropped 57 (7/30/2011) Ted, in your opinion,would it be a safe performance mod. to bolt a set of the aluminum heads on a freshly rebuilt 272/292, giving that all necessary factors will be to spec, or new. and do you think that an upgrade like this would net gains comparable to those charted?. Thanks for your time. portland, oregon.Aluminum heads added to a 292 are expected to show similar improvements in performance. And for most scenarios, this would still be on pump gas. There’s nothing fancy about the 312 dyno mule being used for the cylinder head testing in that it’s using cast pistons with the original design wide rings, stock rods, etc. The major changes on the bottom end are the camshaft change and the balancing of the rotating assembly.
Posts: 3.3K,
Visits: 238.8K
The varied comparisons of the "C" & "G" heads is interesting. Ignoring various cost factors & going strickly with Teds' findings, shows stk to stk that the "G" head is noticeably superior in peak power. Up 17 h.p. & 14 lb ft over the "C" heads. When you start comparing stock, milled & or ported heads the water gets murky. Yes, "C"s can be brought fairly close by milling to 9 to 1, resulting in being just 2 h.p. & 8 lb.ft. down. Then ad porting gets them 5 h.p. up, but still 5 lb ft. down, close but all that machining & porting isn't free. And the stk "G"s still maintain the best stk torque rating. And of course the other figures indicate that if suitably modified, they have a lot more potential...
yalincoln
Visits: 4.9K
hi ted, were you using 1.64 valves in the truck heads?
dropped 57
Last Active: 15 Years Ago
Visits: 357
rev.johnchoppermohamedjerryleejames
Posts: 7.5K,
charliemccraney (7/27/2011) .......Are you going to score these using the Engine Masters format?Charlie. I’ll work on putting the head test in a scoring format in the near future. I’m thinking two scoring formats where one format is 2500-3500 rpms (street driving) and then the 2500-5500 rpm format representing overall performance. For simplicity I’ll keep the chart in the current order and not rearranged in descending or ascending order based on the scores. The current order on the chart has the heads grouped by casting number and does tend to help when comparing heads within a group.
Posts: 7.5K,
PF Arcand (7/29/2011) Another thing interesting is the wide divergence of results from the various ported "G" heads. Obviously there's a lot more to porting those heads than just hogging them out. I believe John Mummert has alluded to this fact in YBM in the past. Did he supply any of the "G" heads by chance?Although John donated a stock set of ECZ-C heads for the test, John didn’t do any porting on them. John only had a hand in porting the aluminum heads but none of the others. And you’re right on the differences in the G head performances. Valve angles, quality of the port work, valve sizes, and combustion chamber shrouding are just a few of the variables in determining how a cylinder head ultimately performs.
Posts: 3.3K,
Visits: 238.8K
Posts: 7.5K,
marvh (7/29/2011) Ted: A question on the mule engine. Are you using the Best gaskets and how deep is the pistons in the hole? Marv. I’m using the Best Gasket #572 head gaskets on the 312 dyno mule and the pistons are 0.025” in the hole. Keep in mind that the Mummert aluminum heads utilize a 60cc combustion chamber and that by itself will be a compression ratio increase with all else being the same. The stock combustion chamber measurements for the G heads are typically rated at 69cc’s while the stock ‘113’ heads are rated at 72cc’s. If converting from steel shim to composition head gaskets, then add another ~4½ cc’s for the extra volume afforded by the thicker head gaskets.
marvh
Visits: 16.7K
Ted:
Just wondering when I get to installing the Mummert heads whether I need to "0" deck the engine or not as I am running steel shims now with flat tops 0.015" in the holes.
Thank you for the ton of info in the test.
marv
Posts: 7.5K,
idaho211 (7/28/2011) Ted, ..... One comparison I see is the Stock G head was 5HP less and 9 ft/lbs more than a stock C1TE head? I thought the C1TE heads would be alot worse. I am in the process of changing out my C1TE heads for a pair of G heads on my 272. Now I am wondering if it will make much of a difference in horse power/torque. What do you think?Be sure to look at that ‘Ported’ column on the chart as that separates the stock from the modified heads. The C1TE heads were ported so they will not be a stock to stock comparison when looking at the stock 'G' heads. The C1TE heads used in the test were prepared by Tim McMaster to demonstrate that the C1TE heads could be a viable alternative to the the harder to find ‘G’ heads when properly prepared. On the other hand, the stock COAE heads should be comparable to stock C1TE head performance so use the stock COAE performance numbers for your stock to stock comparison.
