The Master Cylinder
Visits: 6.2K
Mike, is your leak at the block? Maybe the oil filter plate is warped... I sure you know the drill of taking it off and wacking it with a hammer, in a controlled, precise manner, of coarse.
46yblock
Visits: 7.8K
Yes it is at the block. I have reformed the plate in the past. It seems to dribble all around that area. Really tired of fartnig around with it. Did I read somewhere that John Mummert has a good strong, machined, cannister to spin-on adapter?
Last Active: 10 hours ago
Visits: 39.3K
Check out this link for an article by the late Walt Knuckles on this subject. Chuck http://www.y-blocksforever.com/tech/html/oil_filter.html
46yblock
Visits: 7.8K
Walt Knuckles procedure is the method I used.
Nick Brann
Last Active: 14 Years Ago
Visits: 1.9K
Hi Mike, Don't know if this will help but another filter that will work is the NAPA Gold #1085 for Chrysler applications. Approx. 3 5/8" tall. Good luck, Nick Brann - K.C., MO
46yblock
Visits: 7.8K
Nick, thanks a lot. I bet that is the filter I was looking for, and Chrysler seemed to be bangin around in the memory.
Visits: 498.2K
46yblock (7/16/2011)
paul2748 (7/16/2011) NAPA Gold 1335 - about 2 1/2 inches tallBetween the two possible angled adapters and Paul's lead on the shortie, hopefully I can get this chronic leaking to stop. Paul, I am curious how you have that information  ? I saw it on the net somewhere so I went and bought one. Mac's has a very sturdy adapter and they also have an extra thick gasket.
Rono
Posts: 1.3K,
Visits: 80.0K
Mike; For what it's worth, I use a Hastings #F107 short filter Rono
Ron Lane, Meridian, ID
46yblock
Visits: 7.8K
I am logging all these numbers in a file  .
kidcourier
Visits: 8.8K
Okay,one more----Motorcraft FL 300 about 1/2 the length of a Motorcraft FL-1A KID
