Fuelpump replacement
Posted By kidcourier 14 Years Ago
kidcourier
Posted 14 Years Ago
Supercharged (127 reputation)Supercharged (127 reputation)Supercharged (127 reputation)Supercharged (127 reputation)Supercharged (127 reputation)Supercharged (127 reputation)Supercharged (127 reputation)Supercharged (127 reputation)Supercharged (127 reputation)
Posts: 127, Visits: 8.8K
     Lost a fuel pump this weekend(bummer) so does anyone know if the aftermarket makes one for the Y-block (Edelbrock,Holly,etc.) Part #? Thought I saw something on the Forum about the early FE pump would interchange,anybody try this?If so,Year--model--Part #.Check with Napa and they have a stock replacement for $90,early '62--390 FE lists $35. Appreciate the help guys!  KID
Posted 14 Years Ago
Posts: 4.6K, Visits: 38.5K
You are correct. The early FE pumps work great. Most aftermarket shops have them in Holley etc. I use a stock pump for a HiPo 427 on mine. Chuck in NH
Glen Henderson
Posted 14 Years Ago
Posts: 1.4K, Visits: 7.5K
1973 F100 with a 360 from NAPA, has a nice canister filter as an added bonus.
Glen Henderson
Freedom is not Free
Letohatchee, AL
old cars
Posted 13 Years Ago
Posts: 18, Visits: 1.3K
I just but a 73 -360 FP on my 54 mercury works great a BIG THANKSSmile
Y block Billy
Posted 13 Years Ago
Posts: 1.6K, Visits: 5.2K
They were $29 at napa with canister filter and all but I think they are like $31 now.
55 Vicky & customline
Posted 13 Years Ago
Posts: 3.7K, Visits: 323.2K
Kid:
Do you have vacuum wipers?  All the pumps mentioned above are without the vacuum booster.  If you need the booster, you'll have to pony up the $90 for the replacement.
Frankenstein57
Posted 13 Years Ago
Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)Supercharged (159 reputation)
Posts: 131, Visits: 891
Mine was blowing oil out pretty bad, I found two new FE pumps on ebay super cheap. The arm looks identical, also the bolt flange. I mocked up both pumps today, one even fits up to a hardline going to a garbage can filter. Looks like it fits just fine.
thanks, Mark
iowa fords
Posted 13 Years Ago
Last Active: 10 Months Ago
Posts: 138, Visits: 3.9K
You must not have the original 256 in your 54 Merc
tom in iowa
54 Merc wagon
54 sunvalley
old cars
Posted 13 Years Ago
Yes it still has the 256 in it.Smile
iowa fords
Posted 13 Years Ago
I am a little confused, I tried putting a 54 double acting fuel pump on my 56 292 which is installed in my 54 Merc, and found the 54 bolts were too small in dia. and would not cover the hole for the fuel pump arm, it was like the pump was upside down.
tom in iowa
54 Merc wagon
54 sunvalley
