Lincoln Versailles front spindles..57 Tbird
Posted By MarkMontereyBay 14 Years Ago
MarkMontereyBay
Posted 14 Years Ago
Posts: 733, Visits: 3.8K
Will Lincoln Versailles front spindles fit the 57 Tbird without reaming? I am using 15 inch aftermarket wheels so caliper fit should be okay. I also came across the bushings used for Granada/Monarch spindles for Mustang/Cougar. Don't know if they will fit our range of Ford/Tbirds.
http://www.mustangsteve.com/tierodbushings.html
57 Black Tbird 312/auto
Posted 14 Years Ago
Posts: 3.7K, Visits: 497.8K
I have been told that reaming is not required on the Versailles spindles.
Posted 14 Years Ago
Last Active: 6 days ago
That is correct Paul.The Versailles used  a bigger lower ball joint than the Granada even though the spindle itself is identical to the Granada one.No reaming required.
slumlord444
Posted 14 Years Ago
Posts: 1.2K, Visits: 137.8K
What years Versales work?
GREENBIRD56
Posted 14 Years Ago
Posts: 1.7K, Visits: 102.7K
To add to what these guys are saying - none of the funny little bushing inserts you mentioned will be required either - the ball joint pin is a direct fit into the lower mount of the Lincoln steering knuckle.
Posted 14 Years Ago
Lincoln Versailles 75-80.If you find a source with more than 2 post it.I am sure someone will buy the extras.
MarkMontereyBay
Posted 14 Years Ago
Does anyone have part numbers for both right and left front Lincoln Versailles spindles?
Thanks,
Mark
old cars
Posted 14 Years Ago
Posts: 18, Visits: 1.3K
Thanks for the info guysSmile now to find them my 54 mercury would stop better it now pulls to one side or the other I never know which way its goingw00t
Posted 14 Years Ago
The kits listed on ebay would also work on your Mercury.I dont know that its a bad price giving you everything including spindles ready to install.I think one listing claims they are "New' spindles as opposed to used but could I be wrong about that.You are correct about "no pull"to the sides.I can pretty well take my hands(loosely of course)off the wheel and hit the brakes hard and not see the wheel move at all.
MarkMontereyBay
Posted 14 Years Ago
A member of FordFE.com chased down the Versailles spindle part numbers:
Right D7DY 3105A
Left D7DY 3106A
