Wanted Weiand Drag Star 6x2 Intake manifold
Posted By BIGREDTODD 15 Years Ago
BIGREDTODD
Posted 15 Years Ago
Supercharged (349 reputation)Supercharged (349 reputation)Supercharged (349 reputation)Supercharged (349 reputation)Supercharged (349 reputation)Supercharged (349 reputation)Supercharged (349 reputation)Supercharged (349 reputation)Supercharged (349 reputation)
Posts: 324, Visits: 2.4K
As it says, I'd like to find a nice Weiand 6x2 Drag Star Manifold...
Let's all accept the fact that a 6x2 set-up isn't practical and get over it. I still would like to find one. And, for the record, I don't recall ever saying it was for street useWink
Might consider an Edelbrock FM 657 as well, but would prefer a Weiand. If you have a nice Weiand, I might trade my extra set of Edelbrock Y-Block valve covers for it...valve covers aren't for sale, outside of the right trade deal...
Please shoot me an email if you have one...
bigredtodd@hotmail.com
Todd
Todd in Central California...about half way between Fresno and Sacramento
1956 Thunderbird - 1960 F-100 - 1961 Starliner - 1961 Imperial
Rono
Posted 15 Years Ago
Posts: 1.3K, Visits: 80.0K
Todd;
These intakes do have a real WOW factor, but I can tell you from experience, they really are not meant for street use and in my opinion, more trouble than they are worth. If your planning a race-only application, that's a different story.  I had an Edlebrock #657 with 6 Holly 94's. The only way I could get it to run at all was to use only the outer 4 carbs running straight, non progressive linkage and blocking off the middle two carbs. I also had to plumb-in a remote t-stat housing. I sold the entire set-up on ebay years ago and went with dual quads which I'm really happy with. Anyway, just my two cents worth. Hope you don't mind.
Rono
yblock32deuce
Posted 15 Years Ago
Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)Supercharged (200 reputation)
Posts: 173, Visits: 1.5K
been running 6 2s on my 32 cpe on and off for 5 years. ran 3 2s last year, and although they were ok and ran fine, just not the wow factor that the 6 2s have. it is also true that they are not quite as responsive as other setups on the street, but set up properly , do not seem to require any more special treatment than any other carb setup past a single carb setup.i am running off the middle 2 with progressive linkage on the other 4 and mileage is 18 mpg on a fairly stout 312 in my 2800 lb. cpe. BigGrin
BIGREDTODD
Posted 15 Years Ago
I often find embracing theoretical impracticality, if only for the sake of avoiding the mundane, to be a worthwhile effort amongst the other present stress in my life...
In other words, still looking for a Weiand 6x2 Drag Star BigGrin
Posted 15 Years Ago
Y-B 32 Duece is the only person I've heard of in years that has run a 6 carb log manifold setup on the street for any reasonable length of time. Essentially they are a single plane racing item, and somewhat noted for poor low end throttle response. Unless a person has a good knowledge of tuning carbs & lots of patience, best forget about it...
gekko13
Posted 15 Years Ago
Supercharged (201 reputation)Supercharged (201 reputation)Supercharged (201 reputation)Supercharged (201 reputation)Supercharged (201 reputation)Supercharged (201 reputation)Supercharged (201 reputation)Supercharged (201 reputation)Supercharged (201 reputation)
Posts: 128, Visits: 2.6K
Todd, if the lack of a suitable manifold is the only thing holding you back, why not fabricate one?  Back in the day, Bruce Crower marketed "U-Fab" log manifold kits.  These were just flanges and tubing which could be welded together at a fraction of the cost of the fancy cast aluminum pieces.  By building a manifold you also can control the parameters such as runner length, plenum volume, and carburetor choice.  Remember that the cfm rating of a 2 barrel is rated differently than a 4 barrel so even 6 of the old Holley 94's flow less than a small dual quad setup, BTW.   I think you could build a system that had decent drivability and performance + the visual pop you seek.  In your favor, the Y-Block has a dry manifold (separate valley cover), no distributor hole and the coolant outlets can be plumbed with flanges and hose.  JMO
Posted 15 Years Ago
Posts: 4.6K, Visits: 39.4K
I've seem them as simple as some curved exhaust tubing welded to intake flanges with a box welded on top to hold the carbs. Depends on what exact look you want. A long runner, semi tunnel ram U-Fab six duece manifold would be bitchin! w00t Chuck in NH
yalincoln
Posted 15 Years Ago
Posts: 382, Visits: 4.9K
yes, with 6 or 8 weber carbs!!!
Posted 15 Years Ago
JMO: Can you elaborate on your statement that 2 Bbl carbs are rated differently than 4 Bbls?. Holley 94s for instance were nominaly rated at 150 or 155 cfm. So, on paper, 6 of them = 900 to 930 CFM. I'll suggest just for discussion, that's likely far more cfm than most Y-blks can handle, unless they have a substantialy oversize displacement & serious performance up grades.
aussiebill
Posted 15 Years Ago
Posts: 1.8K, Visits: 11.4K
PF Arcand (5/9/2011)
Guys, let him run what he likes, Smile, theres an old saying i like; " Run what you brung!  and hope you brung enough?" SmileBigGrinTongue
 Down Under, Australia
