Wanted Weiand Drag Star 6x2 Intake manifold
Posted By BIGREDTODD 15 Years Ago
BIGREDTODD
Posted 15 Years Ago
Supercharged (349 reputation)Supercharged (349 reputation)Supercharged (349 reputation)Supercharged (349 reputation)Supercharged (349 reputation)Supercharged (349 reputation)Supercharged (349 reputation)Supercharged (349 reputation)Supercharged (349 reputation)
Posts: 324, Visits: 2.4K
Guys,
didn't really want to start a discussion on the application woes of a 6x2 manifold. Fact is, this manifold will join my Weiand v/c set, and end up on one of 2 things at this point. Either a rowdy Y-block in a 1960's-era wooden V-drive (that is currently housing the neglected 375hp 390" that was originally in my '61 Starliner) or in a hoodless roadster or coupe. Either way, the "WOW" factor is what I'm after.
I'm moved by everyone's concern...really, I am.
Oh, yeah...still looking for a 6x2 Weiand Drag starBigGrin
Todd in Central California...about half way between Fresno and Sacramento
1956 Thunderbird - 1960 F-100 - 1961 Starliner - 1961 Imperial
glrbird
Posted 15 Years Ago
Posts: 616, Visits: 7.1K
Tod
Have you put out the word on the H.A.M.B., Lots of carbs look GOOD!
Gary Ryan San Antonio.TX.
gekko13
Posted 15 Years Ago
Supercharged (201 reputation)Supercharged (201 reputation)Supercharged (201 reputation)Supercharged (201 reputation)Supercharged (201 reputation)Supercharged (201 reputation)Supercharged (201 reputation)Supercharged (201 reputation)Supercharged (201 reputation)
Posts: 128, Visits: 2.6K
PF Arcand (5/9/2011)
JMO: Can you elaborate on your statement that 2 Bbl carbs are rated differently than 4 Bbls?. Holley 94s for instance were nominaly rated at 150 or 155 cfm. So, on paper, 6 of them = 900 to 930 CFM. I'll suggest just for discussion, that's likely far more cfm than most Y-blks can handle, unless they have a substantialy oversize displacement & serious performance up grades.
Flow ratings for carburetors are measured at pressure drop of 1.5 inches of mercury for 3 and 4 barrel units and 3.0 inches for 1 and 2 barrels.  So, to compare a 150 cfm Holley 94  to a 4 barrel, you have to multiply it by .707.  That equals about 106 cfm.  106 cfm times 6 equals 636 cfm.  You can see that the maximum flow is not that much as compared to a dual quad set up.  The dreaded throttle response is, IMO, usually attributable to poor tuning or initial set up.  I have seen several 6 x 2 and even 8 x 2 installations that run fairly well up to a point.   Ultimately they fall short on power because they just can't flow even as much as a couple of small 4 barrels.
BIGREDTODD
Posted 15 Years Ago
glrbird (5/10/2011)
Tod
Yeah, sure did...
BTW, thanks for "getting it" Gary. Apparently I should have posted this on the general discussion board.
Guys, it's not that I don't appreciate the comments and informed opinions, but I really don't care about how tempermental a 6x2 is. I don't care about net performance output, and I know that probably a "B" manifold would run better and be more drivable. A fuel injected 5.0 would be also run better and be more drivable, as would an FE, or a 455 Olds, or a 500" Caddy...all of which are options in-hand. I don't care to be ordinary, or practical for the end result here.
I am looking for a 6x2 Drag star. PERIOD. Not looking for lecturesRolleyes.
Grizzly
Posted 15 Years Ago
Posts: 281, Visits: 1.9K
Todd,
Have you see these http://kustoms.com.au/osc/product_info.php?cPath=22&products_id=31. I'm not associated with the company nor have any info on them. I was just searching the net and remembered your post.
Cheers
Warren
http://forums.y-blocksforever.com/Uploads/Images/41f30774-424d-428d-9c7a-e351.jpg Grizzly (Aussie Mainline)
BIGREDTODD
Posted 15 Years Ago
Grizzly (5/17/2011)
Todd,
Cheers
Warren
Beautiful manifold, but kinda steep for the amount of work still required to make it ready to bolt-on...and I'd really rather match my Weiand valve covers Wink
Posted 15 Years Ago
gekko13 (5/10/2011)
[quote][b]
Flow ratings for carburetors are measured at a pressure drop of 1.5 inches of mercury for 3 and 4 barrel units and 3.0 inches for 1 and 2 barrels. So, to compare a 150 cfm Holley 94 to a 4 barrel, you have to multiply (the cfm) by .707. That equals about 106 cfm. 106 cfm times 6 equals 636 cfm. You can see that the maximum flow is not that much as compared to a dual quad set up.
THANKS gekko13! While I've known that two barrel carbs were rated at a different pressure drop than 4 barrel carbs, I never was clear as to how to compare their flow ratings.
Going a bit further with this issue, the Holley 94 was upgraded over time using different venturi sizes and different venturi enhancements. The Ford EBU6 carb (Holley knock-off) used on '56 Fords had 1 1/16 venturis, 1 3/8 throttle plates, an automatic choke, and annular (?) style venturi boosters. They were rated at 245 cfm.
For those of us fiddling with 3x2 set-ups, your multiplier tells me that using one of these would flow ~173 cfm (in four barrel language) and the three together would be rated at ~520 cfm when put together. Six together would be 1,039 cfm!?! My recollection is that the '57 teapots were rated at 330 cfm each or 660 on a 2x4 set-up.
While a good four barrel is perhaps the best way to go performance-wise, especially with John Mummert's new manifold, I love the looks of the multiple carbs, air cleaners, and the linkage! Smile
Posted 15 Years Ago
Well, Todd, it's the end of June. Are you still holding out for a Weiand 6x2 manifold or are you ready to look at another brand?
See ebay listing number 120741744796. This is an Offenhauser unit. It intrigues me because it takes 4 bolt carburetors.
The linkage for one of these set-ups must be something else! Whistling
Hope this helps! Smile
Regards,
The Master Cylinder
Posted 15 Years Ago
Posts: 974, Visits: 6.2K
I know it's not what you are looking for but there is a Offy manifold on E-Bay...
http://cgi.ebay.com/ebaymotors/Y-BLOCK-FORD-6X2-INTAKE-312-292-OFFY-RAT-ROD-GASSER-/120741744796?pt=Vintage_Car_Truck_Parts_Accessories&hash=item1c1cc4d09c#ht_500wt_1124
weiand
Posted 15 Years Ago
First Time Poster
First Time Poster (1 reputation)First Time Poster (1 reputation)First Time Poster (1 reputation)First Time Poster (1 reputation)First Time Poster (1 reputation)First Time Poster (1 reputation)First Time Poster (1 reputation)First Time Poster (1 reputation)First Time Poster (1 reputation)
Last Active: 15 Years Ago
Posts: 1, Visits: 1
I have weiand Drag star model # WD6.  not sure if anyone is intersted.  Willing to give up cheap!  getting ready to move.w00t
