landspeedy
Visits: 342
MoonShadow (5/5/2013) Man does that nose look slippery in the straight on view. Nice looking ride. ChuckChuck,I need to make the car as slippery as possible,after all its just a little ol Y Block!!!!!!!!!!!!!
its not how fast you go, its how you go fast.
Can or should you make some sort of fairing for the shocks and axle?
Visits: 39.1K
I've often wondered about a V shaped fairing on the axle instead of the lightening holes. Anything to change a surface from flat to tapered would seem to help. Also anybody ever done any work with covers on the inside of the wheels? Thats another area to disturb the air flow. Moon discs on the outside are nearly standard but why not on the inside? Could be as simple as an aluminum disc attached to the spindles or axle flange. Just dreaming out loud. Chuck
landspeedy
Visits: 342
charliemccraney (5/7/2013) Can or should you make some sort of fairing for the shocks and axle?Charlie, Yes I think it is legal to add a suspension faring,I just have'nt had time to address that part yet.
landspeedy
Visits: 342
MoonShadow (5/7/2013) I've often wondered about a V shaped fairing on the axle instead of the lightening holes. Anything to change a surface from flat to tapered would seem to help. Also anybody ever done any work with covers on the inside of the wheels? Thats another area to disturb the air flow. Moon discs on the outside are nearly standard but why not on the inside? Could be as simple as an aluminum disc attached to the spindles or axle flange. Just dreaming out loud. ChuckChuck,I do have aluminum disc's on the inside of my front wheels. Every little bit helps!!!!!!!!!!!!!!!!!!!
mctim64
Last Active: 9 days ago
Posts: 2.4K,
Visits: 5.0K
Three more months.
landspeedy
Visits: 342
mctim64 (5/9/2013) Three more months.Yep,not long now. Are you going to Elmirage? If you do keep her straight!!!!!!!!!! See ya in August.
mctim64
Posts: 2.4K,
Visits: 5.0K
I will be running the dragster at Eagle Field on Saturday, go home late afternoon (2 hours drive time), load up the Uni and then head to Elmo to run on Sunday. (4 1/5 hours drive time) Pray for me.
landspeedy
Visits: 342
Sounds like a weekend of fun to me!!!!!!!!!!!!!!!!!!!
Good luck & go fast.
landspeedy
Visits: 342
Well I have some forward progress. She is "back in black" 576 HP back from Ted waiting to be set in place. And a bunch of little stuff.
