My Oregon cam regrind came in yesterday.  It is grind #218, mild, I & E duration at .050 is 225 degrees, duration 260, lobe separation 108,intake centerline 108.
I need to settle on a target static compression.  Does this dynamic cranking compression sound right?  154 psi.  Here are the variables that I plugged in giving the calculated 154 figure..  Alt. 1330, bore 3.86, stroke 3.44, rod length 6.25, intake .020 before closing is at 58 degrees ABDC, static compression 9.7:1.  The 154 psi seems lower than expected so I would like someone else to have a go at the numbers.
