y-block lifters
Posted By lameyer 16 Years Ago
DANIEL TINDER
Posted 15 Years Ago
Posts: 1.8K, Visits: 154.7K
John Mummert (1/14/2011)
If you are using .502" OD bronze guides I would recommend even more clearance. .0022-.0025". The bronze is not dimensionally stable until many heat cycles.
When it comes to sizing valve guides my motto is: If the guide has a couple 10,000ths more clearance than might be required the customer will never know it. If it has a couple 10,000ths too little he will hate you.
John/Ted,
Since determining accurate clearance specs. (within a few 10,000ths) seems to depend on the quality of the measuring tool & experience of the mechanic, can you suggest any specific/extra break-in/run precautions that might possibly help to counteract stainless/bronze guide clearance that COULD be just a bit under the safe margin?
6 VOLTS/POS. GRD. NW INDIANA
Y block Billy
Posted 15 Years Ago
Posts: 1.6K, Visits: 5.2K
Thanks for the clarity John,
Now I am wondering if it wouldn't be wise to break in an engine with the weaker push rods, just in case there is binding this weakest link would be an easy change, rather than broken lifters, rockers etc.
55 Vicky & customline
DANIEL TINDER
Posted 15 Years Ago
Y block Billy (1/16/2011)
If guides that bind initially would eventually loosen up during break-in, and the more flexible worn pushrods do not create a mismatch/wear problem for certain with rocker/lifter mating surfaces, and the changed geometry resulting from likely head/deck milling would allow enough adjustment without a damaging type of rocker interference, and the the old pushrods don't create another kind of problem during run-in (if they bend or jump out), then sounds like a GREAT idea!
Posted 15 Years Ago
Posts: 7.6K, Visits: 206.1K
DANIEL TINDER (1/15/2011)
John/Ted,
Tight is tight.  Running the engine on the cool side with tight guides might delay a problem but once the valves get hot enough and especially once any throttled load is put on them, the possibility of an exhaust valve sticking in a guide that has minimal clearance is still going to be quite high. Use of the early skinny pushrods might save a lifter at the expense of a doubled up pushrod though but if there’s that much doubt about the guide clearance, it really should be addressed before the engine is fired up.  There’s very few places where being on the tight side clearance wise anywhere in an engine is not the potential for a problem versus being on the loose side.
DANIEL TINDER
Posted 15 Years Ago
And babying the motor until some guide wear is realized likely not feasible I assume, since hard acceleration is needed to break in the rings properly?
RB
Posted 15 Years Ago
Posts: 662, Visits: 16.7K
Jerry C took the heads to R&R Performance in Spring Lake Park MN.
This is a very reputable race shop that builds a lot of Fords
He had the heads disassembled and the guides checked for clearance.. Brian, the machinist, determined that the clearance was at the minimum he would recommend, however there was no galling or scuffing that would indicate the valve got tight in the guide during testing. Jerry is having additional clearance added per John's recommendation. The guides have thin wall bronze liners. I think Jerry has finally completed the grieving process and is ready to pull the motor apart, replace the injured parts and try again.. He wanted to make sure nobody thought he was pointing fingers at any supplier.. Stuff happens, parts break, sometimes without obvious explanation. The vendor should not be responsible for random failures
Hopefully in the next few months we will have repairs made and be able to resume testing..
Posted 15 Years Ago
Royce.  Was it an intake or exhaust lifter that broke?  Just curious but if it was an exhaust lifter, it just adds fire to a tight exhaust guide being the root of the problem.  Same question goes for the broken rocker arm but it being bushed makes the cause of breakage in that case questionable even if it was an exhaust rocker.  I recognize that the rocker assemblies had been recently R&R’ed by Rocker Specialists but do you know the age of the rocker arm that gave up?
RB
Posted 15 Years Ago
Ted, I checked with Jerry and it was an intake valve that had the lifter failure and the rocker arm failure
EBird1
Posted 15 Years Ago
Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)Normally aspirated (28 reputation)
Posts: 21, Visits: 158
Just pulled our 312 down today and surprisingly half the lifter fell our the wrong directions.
A definate fatigue break with the FOMCO stamped on the reverse side.
46yblock
Posted 15 Years Ago
Posts: 1.2K, Visits: 7.8K
That is a Crying picture.  Doubt if it is possible but sure hope worse damage didnt result.  Quite the first post!  Welcome!
