New Bonneville Race Truck
Posted By 57FordPU 16 Years Ago
57FordPU
Posted 5 Years Ago
Posts: 726, Visits: 73.6K
Hey, Chuck.  I had to smile when you mentioned a tailgate.  In the back of my head I see a tailgate open to about 45 degrees or so to make a spoiler.  It would raise eyebrows to have it supported back there at an angle with chains.Tongue
BurnsRacing981@gmail.com
Posted 5 Years Ago
Posts: 4.6K, Visits: 39.5K
Some pretty chrome chains but welded solid at the proper angle. I actually had something in mind like the Porsche Whale Tail that would flatten at speed!
57FordPU
Posted 5 Years Ago
http://forums.y-blocksforever.com/uploads/images/c48bddb2-1252-4390-9ba2-755c.jpg
http://forums.y-blocksforever.com/uploads/images/3639fa17-7614-462e-bac7-60ad.jpg
http://forums.y-blocksforever.com/uploads/images/4c1d63c1-d781-4582-ad0a-8b77.jpg
http://forums.y-blocksforever.com/uploads/images/3978510d-a3e8-41a8-a0fa-9175.jpg
Lots of welding.
bird55
Posted 5 Years Ago
Posts: 1.1K, Visits: 58.8K
Charly, good to see this new project of yours!. I've been away from the site for a long, long time. It's good to come back and see work like yours being done.
57FordPU
Posted 5 Years Ago
Thanks, Alan.  I will try to post progress as it happens.  I still have the stroker/turbocharged Y-Block to refresh.
57FordPU
Posted 5 Years Ago
It is time to start the re-assembly of the 338 cu. in. turbo Y-Block.
Cleaning the block for a new cylinder cross-hatch and hot tank.
http://forums.y-blocksforever.com/uploads/images/4aaf4ebb-6d50-4be4-a6bf-936c.jpg
57FordPU
Posted 5 Years Ago
Honing just enough to get a new cross hatch pattern.
http://forums.y-blocksforever.com/uploads/images/ef4a72ff-899d-40b1-82bd-1239.jpg
57FordPU
Posted 5 Years Ago
Getting ready to install the crank.  Only .0005" runout, thanks Tim for some outstanding machine work.
http://forums.y-blocksforever.com/uploads/images/4393d2ed-ff58-4929-a8db-ded0.jpg
57FordPU
Posted 5 Years Ago
Miking pistons for new rings.  This time I will use a gapless top ring.  Notice a larger first ring land?  A miss communication with the piston builder resulted in a larger top ring land and now requires a spacer ring.
http://forums.y-blocksforever.com/uploads/images/4db5e594-a735-4ce4-ba4a-154d.jpg
57FordPU
Posted 5 Years Ago
I miked the lobe lifts and they were all at spec with the cam card.  I had originally thought the cam had gone flat, but that was not the case.
http://forums.y-blocksforever.com/uploads/images/2b8a3cc3-5c8c-4b19-b007-7cc1.jpg
