Visits: 39.5K
Darn Charlie you blowed it up real good! That little engine served you well for quite a while though.
LordMrFord
Visits: 9.3K
wow!
 Hyvinkää, FI
57FordPU
Visits: 73.6K
57FordPU
Visits: 73.6K
After complete disassembly of the engine and positioning the truck for modifications, I made a list of things to do. I have all winter, but you know how that goes, so I better get started.
BurnsRacing981@gmail.com
ian57tbird
Visits: 21.7K
HI Charlie. You forgot to list: Repaint hood.
57FordPU
Visits: 73.6K
You are correct Ian. Actually I intend to put a scoop on the hood as part of the new ideas for engine bay cooling. I'll add it to the list. First is out with the air bag system.
57FordPU
Visits: 73.6K
Coil springs are back in.  Switching from 3.50 to 2.75.
57FordPU
Visits: 73.6K
The 3rd member is back in with 2.75 ratio (hope I can make enough power to push that!). Installed a drain plug for easier changes in the future.
57FordPU
Visits: 73.6K
I mocked up the engine and transmission to aide in fabricating a new frame cross member for the top loader 4-speed. I just lost confidence in the T-5 I was running before.
Has the T5 been problematic?
