New Bonneville Race Truck
Posted By 57FordPU 16 Years Ago
57FordPU
Posted 14 Years Ago
Posts: 726, Visits: 73.6K
Thanks for the story, very interesting stuff.  The 56 looks great too!  I have been keeping (Kiwi) Steve Davies in the loop with this build and he has given me great feedback.  Hope to see you at El Mo and Bonneville this year.
BurnsRacing981@gmail.com
57FordPU
Posted 14 Years Ago
Bill, I need to stir up some emotions from time to time in order to keep me motivated.  Nothing like a blower on top of anything to get the juices flowing.  Initial shake down runs at El Mirage will be naturally aspirated just to make sure the wheels don't fall off and to get my category "D" (125 to 149 mph) driver's license.  If all goes well there will be a turbo (or turbo's) later at Bonneville.
Headers have been fabed for some time, but finally finished welding all seams.
Exhaust will exit ahead of the front wheels.
Hollow Head
Posted 14 Years Ago
Posts: 1.0K, Visits: 3.8K
Charlie, if you are going to use big enough turbos with those headers, you may end up to break a hole to your hood. Looks as high installation as in our dragster Wink...
Y block Billy
Posted 14 Years Ago
Posts: 1.6K, Visits: 5.2K
Exhaust in front of the front tires? Very clever, i see what you are doing. If you exhaust them so they
Are blowing down on the front of the tire and drill dimples in the
Tire back wards to rotation so they cup the exhaust, once you are rolling you could take it out of gear and run by front wheel drive turbine power!
Every little bit counts!
55 Vicky & customline
57FordPU
Posted 14 Years Ago
Now that makes me smile.  Convenience is only one reason to exit in front of the tires (it is nice to not have to deal with crossmembers, starters and steering).  Also there is a low pressure area that builds just behind the front bumper.  By running the exhaust into that area, it reduces the low pressure and therefore creates less drag.
57FordPU
Posted 14 Years Ago
Exhaust is finished and has room due to engine set back.
Hollow Head
Posted 14 Years Ago
Looks weird enough Wink. Fresh ideas are always welcome but have you had any thoughts about heat build up that is generated under the hood with that system? Ofcourse you will take intake air from a ducting placed behind the grille? Usually, the hottest spot in exhaust is the place where the x-pipe is.
57FordPU
Posted 14 Years Ago
Engine compartment heat buildup would certainly be a problem if left as is.  I have purchased 100' of heat wrap for the headers and I will check to see if more attention is needed.  Heat shields would be the next step.  Intake air will come from a hood scoop.
Hollow Head
Posted 14 Years Ago
Charlie, here is one idea about intake air. If you use a hood scoop, that itself creates an aerodynamic obstacle over the hood and the airflow has to do 90 degree travel down the carb. You have good openings at the front bumber to take air from there by ducting. Hood would be smooth and would not harm the airflow over the car. Gross sectional area at the front stays the same and you get the same pressurized airflow to carbs although it has to travel that same 90 degree down to carb under the hood. Don't know if that has any effect to speed but...
Posted 14 Years Ago
Charlie, that or the base of the windshield. we talked about this before I invited myself for dinner!
