57FordPU
Visits: 73.6K
Hi, Dennis, it's ok, they are snap-on.
BurnsRacing981@gmail.com
pintoplumber
Posts: 1.0K,
Visits: 164.3K
Are you allowed to have those clothespins?
Dennis in Lititz PA
57FordPU
Visits: 73.6K
Back to the 338" Y-Block build. Next is relieving the block.
57FordPU
Visits: 73.6K
Good eye Charlie, my comment of a 2.008" big end was the rod ID, not the journal. The journals are 1.889".
Charlie, I think what he notices is that the stroke is longer than can be acquired with only machining to a 2.00" journal. The maximum with that would be about 3.480 if starting with a pristine 292 crank.
57FordPU
Visits: 73.6K
Bill, first of all, you can email me anytime. You have great questions and I'm happy to share the best I can. The crank was just offset ground. The rod lengths are 6.320". The wrist pin dia. is 9.12 and the comp height is 1.650" and the big ends are 2.008".
cos
Visits: 119.6K
Hello Carlie Thanks for reply. To get stroke you have from a 292 crank you must have offset ground crank for Hon. size rod bearings or welded crank,right? Which rods and lenght did you use? Your pistons are custom, what wrist pin diameter and comp. height did you end up with? I have many questions, I will send e-mail if ok? Bill Oregon
57FordPU
Visits: 73.6K
Bill, the new engine is quite different than the previous Y-Block. This block has 338 cu. in. while the last one had 258. The new short block has a bore of 3.875 and a stroke of 3.580. The 258 had all off the shelf parts, de-stroked 1954, 239 crank with a 2.99 through, scruby 6 cyl rods and 1980 Ford Taurus pistons. The 338 has a 292 Ford truck forged crank, NASCAR rods, and custom Racetech pistons. The cam is the same in both engines. It is relatively mild except for the lifts of .556 intake and .553 exhaust based on a stock 1:54 rocker ratio. The lobe seperation is 114 and the duration at .050 lift is 254 intake and 267 exhaust. All the cams I have used have been re-grinds from stock units. Oregon Cams has been great to give me wonderful results in both normally aspirated (57 Ford pu) and turbo cams (current race car).
cos
Visits: 119.6K
Hello I may have overlooked your new engine specs. Can you tell us about it, or point me that way ?Thanks Bill Oregon
57FordPU
Visits: 73.6K
The heads are back from Tim McMaster. Now I need to assemble the engine with the new stroker short block, but first I need to clay the valves.
